查看: 2038|回復: 0
求教: 24LE1 與MAX7219數(shù)碼管模塊的接口程序問題
ID:166497 發(fā)表于 2017-12-15 12:58 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
下面的的程序在STC15W408AS單片機上顯示正常,與24LE1無線模塊連接好后,數(shù)碼管全亮顯示,
邏輯分析儀抓取的波形如下:請高手指點一二,謝謝
程序如下:
   #include "Nordic\reg24le1.h"
#include "MAX7219.H"
#include "stdint.h"
#include "API.h"
unsigned char disbuf[8];
void delayms(unsigned int ms)
        unsigned char i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
                        while(--j);
* Ãè  êö : ÅäÖà IO P0.0oíP0.1Îaêä3ö£¬P1.2oíP1.3Îaêäèë
* èë  2Î : ÎT
* ·μ»ØÖμ : ÎT
void IO_Init(void)
        P0DIR =0x03;           //Åä  0000 0011
        P1DIR = 0x00;           //ÅäÖÃ0000 1100
        //P1CON=0X00;
void disp( )
   unsigned char i;
   for(i=0;i<8;i++)
     Write_Max7219(i,disbuf[i]);
         IO_Init();        // I/O¿ú3õê¼»ˉ
          Init_MAX7219();
   disp();
                 disp();
                delayms(500);
#ifndef __MAX7219_H__
#define __MAX7219_H__
//#include <reg52.h>
#define uint  unsigned int
//¶¨òåMax7219¶Ë¿ú
sbit Max7219_pinCLK = P1^6;
sbit Max7219_pinCS  = P1^5;
sbit Max7219_pinDIN = P1^4;
extern void delayms(unsigned int ms);
//1|Äü£oÏòMAX7219(U3)D′èë×Ö½ú
//èë¿ú2Îêy£oDATA
//3ö¿ú2Îêy£oÎT
//ËμÃ÷£o
void Write_Max7219_byte(uchar DATA)
            uchar i;
                Max7219_pinCS=0;
            for(i=8;i>=1;i--)
            Max7219_pinCLK=0;
            Max7219_pinDIN=DATA&0x80;
            DATA=DATA<<1;
            Max7219_pinCLK=1;
//1|Äü£oÏòMAX7219D′èëêy¾Y
//èë¿ú2Îêy£oaddress¡¢dat
//3ö¿ú2Îêy£oÎT
//ËμÃ÷£o
void Write_Max7219(uchar address,uchar dat)
     Max7219_pinCS=0;
         Write_Max7219_byte(address);           //D′èëμØÖ·£¬¼′êyÂë1ü±àoÅ
   Write_Max7219_byte(dat);               //D′èëêy¾Y£¬¼′êyÂë1üÏÔê¾êy×Ö
         Max7219_pinCS=1;
void Init_MAX7219(void)
Write_Max7219(0x09, 0xff);       //òëÂ뷽꽣oBCDÂë
Write_Max7219(0x0a, 0x03);       //áá¶è
Write_Max7219(0x0b, 0x07);       //é¨Ãè½çÏT£»4¸öêyÂë1üÏÔê¾
Write_Max7219(0x0c, 0x01);       //μôμçģ꽣o0£¬ÆÕí¨Ä£ê½£o1
Write_Max7219(0x0f, 0x01);       //ÏÔê¾2aêÔ£o1£»2aêÔ½áêø£¬Õy3£ÏÔê¾£o0
#endif
