查看: 4286|回復(fù): 3
關(guān)于switch語(yǔ)句,一段關(guān)于單片機(jī)動(dòng)態(tài)數(shù)碼管程序的問(wèn)題,新人求幫忙
ID:247525 發(fā)表于 2017-12-16 18:04 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
直接上程序
include <reg52.h>               //包含寄存器的庫(kù)文件
sbit  ADDR0 = P1^0;
sbit  ADDR1 = P1^1;
sbit  ADDR2 = P1^2;
sbit  ADDR3 = P1^3;
sbit  ENLED = P1^4;
unsigned char code LedChar[] = {   //用數(shù)組來(lái)表示數(shù)碼管真值表
    0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
    0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8e,
    unsigned int counter = 0;
    unsigned char j = 0;
    unsigned long stopwatch =0;
    unsigned char LedNumber[6]={0};
    ENLED = 0; ADDR3 = 1;P0 = 0XFF;   //74HC138和P0初始化部分
    TMOD = 0x01; //設(shè)置定時(shí)器0為模式1
    TH0  = 0xFC;
    TL0  = 0x67; //定時(shí)值初值,定時(shí)1ms
    TR0  = 1; //打開(kāi)定時(shí)器0
        if(1 == TF0)             //判斷定時(shí)器0是否溢出
            TF0 = 0;
            TH0 = 0xFC;        //一旦溢出后,重新賦值
            TL0 = 0x67;
            counter++;
            if(1000 == counter)     //判斷定時(shí)器0溢出是否達(dá)到1000次
                counter = 0;
                stopwatch++;                  //秒表數(shù)值一秒加1
                LedNumber[0] = stopwatch%10;
                LedNumber[1] = stopwatch/10%10;
                LedNumber[2] = stopwatch/100%10;
                LedNumber[3] = stopwatch/1000%10;  //數(shù)碼管顯示值計(jì)算
                LedNumber[4] = stopwatch/10000%10;
                LedNumber[5] = stopwatch/100000%10;
            switch(j)
            case 0: ADDR0=0; ADDR1=0; ADDR2=0; j++; P0=LedChar[LedNumber[0]];break;
            case 1: ADDR0=1; ADDR1=0; ADDR2=0; j++; P0=LedChar[LedNumber[1]];break;
            case 2: ADDR0=0; ADDR1=1; ADDR2=0; j++; P0=LedChar[LedNumber[2]];break;
            case 3: ADDR0=1; ADDR1=1; ADDR2=0; j++; P0=LedChar[LedNumber[3]];break;
            case 4: ADDR0=0; ADDR1=0; ADDR2=1; j++; P0=LedChar[LedNumber[4]];break;
            case 5: ADDR0=1; ADDR1=0; ADDR2=1; j=0; P0=LedChar[LedNumber[5]];break;
            default: break;
       }                   //數(shù)碼管動(dòng)態(tài)刷新部分
我的問(wèn)題就是,在最后的那個(gè)switch語(yǔ)句里面,執(zhí)行完case0不就是直接跳出switch了嗎,那不就是永遠(yuǎn)只能顯示一個(gè)數(shù)碼管了嗎?
實(shí)在是理解不過(guò)來(lái),求指點(diǎn)。。。。
ID:149988 發(fā)表于 2017-12-16 19:29 | 只看該作者
RE: 關(guān)于switch語(yǔ)句,一段關(guān)于單片機(jī)動(dòng)態(tài)數(shù)碼管程序的問(wèn)題,新人求幫忙
當(dāng)執(zhí)行case 0: ADDR0=0; ADDR1=0; ADDR2=0; j++; P0=LedChar[LedNumber[0]];break;時(shí),其中有一句j++;J將由0變成1,switch(j=1),于是將執(zhí)行case 1: ADDR0=1; ADDR1=0; ADDR2=0; j++; P0=LedChar[LedNumber[1]];break;語(yǔ)句。以此類推。
ID:155507 發(fā)表于 2017-12-16 19:54 | 只看該作者
程序是挨個(gè)CASE,CASE完了之后跳出SWich,不會(huì)跳飛回來(lái)來(lái)的。
Switch(ucValue)
case 'a':
       do something;
      break;
所有的Case 和default 做完操作后就跑到我這兒了;
1、不會(huì)出現(xiàn)不確定性,如果不在羅列的case分支中,則會(huì)直接退出switch。
2、一般寫(xiě)代碼的時(shí)候,在default分支中可能還會(huì)做一些操作,此時(shí)如果沒(méi)有default分支則不行。
3、養(yǎng)成良好的C語(yǔ)言代碼風(fēng)格很重要,即使這樣寫(xiě)沒(méi)有造成什么后果,但這樣的代碼對(duì)于閱讀和其他人的理解來(lái)說(shuō),也會(huì)造成一定的障礙,多打一行代碼不會(huì)很累人。
之所以有while(1)是為了使得程序一直在運(yùn)行,所以才有中斷操作的不斷執(zhí)行,否則程序只運(yùn)行一次就終止啦。
while(1)表示無(wú)限循環(huán)的執(zhí)行它{ }內(nèi)的語(yǔ)句,
跟j++類似,假設(shè)第一遍運(yùn)行,j應(yīng)該是0,case0完了之后跳出 j=1
ID:247525 發(fā)表于 2017-12-16 22:02 來(lái)自觸屏版 | 只看該作者
不倒翁.WZT 發(fā)表于 2017-12-16 19:29
當(dāng)執(zhí)行case 0: ADDR0=0; ADDR1=0; ADDR2=0; j++; P0=LedChar[LedNumber[0]];break;時(shí),其中有一句j++;J將由 ...
謝謝
