如題,wifi模塊是mt6620,集成在板子上面的。
安裝教程修改itop-set文件之后,再修改wpa_supplicant.conf文件。重啟開發(fā)板。
但是,wifi模塊附近的led并沒有亮,在Ubuntu系統(tǒng)里面無線網(wǎng)絡(luò)也是灰色的。
查看啟動時(shí)的系統(tǒng)串口日志發(fā)現(xiàn):
- [ 6.943863] VFS: Mounted root (ext4 filesystem) on device 179:2.
- [ 6.949862] Freeing init memory: 220K
- [ 6.954851] Failed to execute /linuxrc. Attempting defaults...
- mountall: Event failed
- [ 8.525460] CPU1: shutdown
- [ 14.133707] CPU2: shutdown
- [ 19.261819] init: Failed to create pty - disabling logging for job
- [ 19.285670] init: Failed to create pty - disabling logging for job
- [ 19.293451] mtk_stp_GPS_chrdev driver(major 191) installed.
- [ 19.302123] init: Failed to create pty - disabling logging for job
- * Starting Userspace bootsplash[ OK ]
- [ 19.415120] init: Failed to create pty - disabling logging for job
- [ 19.491937] init: Failed to create pty - disabling logging for job
- [ 19.506428] init: Failed to create pty - disabling logging for job
- [ 21.280545] [WMT-C][E]wmt_core_stp_init(717):no hif info!
- [ 21.284471] drivers/mtk_wcn_combo/common/core/wmt_core.c, 718, (0)
- [ 21.291479] [WMT-C][E]opfunc_pwr_on(1058):wmt_core_stp_init fail (-1)
- [ 21.298271] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1059, (0)
- [ 21.304530] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(1), value(0) iR)
- [ 21.312304] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 21.318314] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(0), value(0) iR)
- [ 21.326024] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 21.391308] init: Failed to create pty - disabling logging for job
- [ 21.400263] init: Failed to create pty - disabling logging for job
- [ 23.330172] [WMT-CTRL][E]wmt_ctrl_ul_cmd(540):wait signal timeout
- [ 23.335010] [WMT-C][E]wmt_core_ctrl(559):failed: id(3), type(0), value(0) iR)
- [ 23.344260] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 23.435632] [WMT-C][E]wmt_core_stp_init(717):no hif info!
- [ 23.435667] drivers/mtk_wcn_combo/common/core/wmt_core.c, 718, (0)
- [ 23.435707] [WMT-C][E]opfunc_pwr_on(1058):wmt_core_stp_init fail (-1)
- [ 23.435743] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1059, (0)
- [ 23.435866] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(1), value(0) iR)
- [ 23.435904] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 23.435985] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(0), value(0) iR)
- [ 23.436023] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 23.436156] [WMT-C][E]wmt_core_ctrl(559):failed: id(3), type(0), value(0) iR)
- [ 23.436194] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 23.585640] [WMT-C][E]wmt_core_stp_init(717):no hif info!
- [ 23.585675] drivers/mtk_wcn_combo/common/core/wmt_core.c, 718, (0)
- [ 23.585713] [WMT-C][E]opfunc_pwr_on(1058):wmt_core_stp_init fail (-1)
- [ 23.585749] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1059, (0)
- [ 23.585867] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(1), value(0) iR)
- [ 23.585906] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 23.585986] [WMT-C][E]wmt_core_ctrl(559):failed: id(5), type(0), value(0) iR)
- [ 23.586024] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 23.586153] [WMT-C][E]wmt_core_ctrl(559):failed: id(3), type(0), value(0) iR)
- [ 23.586191] drivers/mtk_wcn_combo/common/core/wmt_core.c, 560, (0)
- [ 23.652098] [WMT-C][E]opfunc_func_on(1170):func(3) pwr_on fail(-2)
- [ 23.660258] drivers/mtk_wcn_combo/common/core/wmt_core.c, 1171, (0)
- [ 140.112600] init: Failed to create pty - disabling logging for job
- [ 140.127310] init: Failed to create pty - disabling logging for job
- [ 140.143866] init: Failed to create pty - disabling logging for job
- [ 140.156505] init: Failed to create pty - disabling logging for job
- [ 140.168729] init: Failed to create pty - disabling logging for job
- speech-dispatcher disabled; edit /etc/default/speech-dispatche[ 140.188583] inb
- r
- [ 140.206966] init: Failed to create pty - disabling logging for job
- [ 140.232260] init: Failed to create pty - disabling logging for job
- saned disabled; edit /etc/default/saned
- [ 140.269808] init: Failed to create pty - disabling logging for job
- [ 140.284353] init: Failed to create pty - disabling logging for job
- [ 140.309545] init: Failed to create pty - disabling logging for job
- [ 140.327651] init: Failed to create pty - disabling logging for job
- [ 140.345977] init: Failed to create pty - disabling logging for job
- Last login: Thu Nov 23 02:21:22 UTC 2017 on tty1
- [ 140.398203] init: Failed to create pty - disabling logging for job
- [ 140.472072] init: Failed to create pty - disabling logging for job
- [ 140.649203] init: Failed to create pty - disabling logging for job
- [ 140.693059] init: Failed to create pty - disabling logging for job
- Welcome to Linaro 12.04 (GNU/Linux 3.0.15 armv7l)
- New release '14.04.5 LTS' available.
- Run 'do-release-upgrade' to upgrade to it.
應(yīng)該怎么辦?
