8路搶答器的匯編和仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2017-12-18 22:49 上傳
2017-12-18 22:50 上傳
- OK EQU 20H ;搶答開(kāi)始標(biāo)志位
- RING EQU 22H ;響鈴標(biāo)志位
- DATA0 EQU 36H ;搶答按鍵口數(shù)據(jù)存放地址
- ORG 0000H
- AJMP MAIN
- ORG 0003H
- AJMP INTT0
- ORG 000BH
- AJMP T0INT
- ORG 001BH
- AJMP T1INT
- ORG 0040H
- MAIN: MOV R1,#14H ;初設(shè)搶答時(shí)間為20s
- MOV R2,#1EH ;初設(shè)答題時(shí)間為30s
- MOV 38H,#3CH ;啟用錦囊時(shí)間從60s倒計(jì)時(shí)
- MOV TMOD,#11H ;設(shè)置未定時(shí)器/模式1
- MOV TH0,#0F0H
- MOV TL0,#0FFH ;越高發(fā)聲頻率越高,越尖
- MOV TH1,#3CH
- MOV TL1,#0B0H ;50ms為一次溢出中斷
- SETB EA
- SETB ET0
- SETB ET1 ;允許二個(gè)中斷,T0/T1
- CLR OK
- CLR RING
- SETB TR1
- SETB TR0 ;一開(kāi)始就運(yùn)行定時(shí)器,以開(kāi)始顯示FFF.如果想重新計(jì)數(shù),重置TH1/TL1就可以了
- START: MOV DATA0,#0FFH ;初始化
- MOV R5,#0BH
- MOV R4,#0BH
- MOV R3,#0BH
- ACALL DISPLAY ;未開(kāi)始搶答時(shí)候顯示FFF
- JNB P3.3,SELSUB0
- JNB P3.4,TZ3 ;倒計(jì)時(shí)調(diào)整
- JB P3.0,NEXT
- ACALL DELAY
- JB P3.0,NEXT ;去抖動(dòng),如果"開(kāi)始鍵"按下就向下執(zhí)行,否者跳到非法搶答查詢
- SETB EX0 ;開(kāi)放INT0
- ACALL BARK ;按鍵發(fā)聲
- MOV A,R1
- MOV R6,A ;送R1->R6,因?yàn)镽1中保存了搶答時(shí)間
- SETB OK ;搶答標(biāo)志位,在使用錦囊時(shí)用作判斷是搶答倒計(jì)時(shí)還是回答倒計(jì)時(shí)
- MOV R3,#0AH ;搶答只顯示計(jì)時(shí),滅號(hào)數(shù)
- AJMP COUNT ;進(jìn)入倒計(jì)時(shí)程序,"查詢有效搶答的程序"在COUNT里面
- NEXT: JNB P1.0,FALSE1
- JNB P1.1,FALSE2
- JNB P1.2,FALSE3
- JNB P1.3,FALSE4
- JNB P1.4,FALSE5
- JNB P1.5,FALSE6
- JNB P1.6,TZ1
- JNB P1.7,TZ2
- AJMP START
- TZ1: AJMP FALSE7
- TZ2: AJMP FALSE8
- TZ3: AJMP SELSUB1
- FALSE1: MOV R3,#01H
- AJMP ERROR
- FALSE2: MOV R3,#02H
- AJMP ERROR
- FALSE3: MOV R3,#03H
- AJMP ERROR
- FALSE4: MOV R3,#04H
- AJMP ERROR
- FALSE5: MOV R3,#05H
- AJMP ERROR
- FALSE6: MOV R3,#06H
- AJMP ERROR
- FALSE7: MOV R3,#07H
- AJMP ERROR
- FALSE8: MOV R3,#08H
- AJMP ERROR
- SELSUB0: MOV A,R1
- MOV B,#0AH
- DIV AB
- MOV R5,A
- MOV R4,B
- MOV R3,#0AH
- ACALL DISPLAY ;先在兩個(gè)時(shí)間LED上顯示R1
- JNB P3.5,INC0 ;P3.5為+1s鍵,如按下跳到INCO
- JNB P3.6,DEC0 ;P3.6為-1s鍵,如按下跳到DECO
- JNB P3.1,BACK0 ;P3.1為確定鍵,如按下跳到BACKO
- AJMP SELSUB0
- INC0: MOV A,R1
- CJNE A,#63H,ADD0 ;如果不是99,R2加1,如果加到99,R1就置0,重新加起。
- MOV R1,#00H
- ACALL DELAY1
- AJMP SELSUB0
- ADD0: INC R1
- ACALL DELAY1
- AJMP SELSUB0
- DEC0: MOV A,R1
- JZ SETR1 ;如果R1為0, R1就置99,
- DEC R1
- ACALL DELAY1
- AJMP SELSUB0
- SETR1: MOV R1,#63H
- ACALL DELAY1
- AJMP SELSUB0
- BACK0: AJMP START
- SELSUB1: MOV A,R2
- MOV B,#0AH
- DIV AB
- MOV R5,A
- MOV R4,B
- MOV R3,#0AH
- ACALL DISPLAY
- JNB P3.5,INC1
- JNB P3.6,DEC1
- JNB P3.1,BACK1
- AJMP SELSUB1
- INC1: MOV A,R2
- CJNE A,#63H,ADD1
- MOV R2,#00H
- ACALL DELAY1
- AJMP SELSUB1
- ADD1: INC R2
- ACALL DELAY1
- AJMP SELSUB1
- DEC1: MOV A,R2
- JZ SETR2
- DEC R2
- ACALL DELAY1
- AJMP SELSUB1
- SETR2: MOV R2,#63H
- ACALL DELAY1
- AJMP SELSUB1
- BACK1: AJMP START
- REPEAT:MOV A,38h ;使用錦囊時(shí)重新計(jì)時(shí)
- MOV R6,A
- CLR RING ;當(dāng)?shù)褂?jì)時(shí)進(jìn)入最后5秒的時(shí)候,啟用錦囊能消除蜂鳴
- COUNT:MOV R0,#00H ;重置定時(shí)器中斷次數(shù)
- MOV TH1,#3CH
- MOV TL1,#0B0H ;重置定時(shí)器
- RECOUNT:MOV A,R6 ;R6保存了倒計(jì)時(shí)的時(shí)間,之前先將搶答時(shí)間或回答時(shí)間給R6
- MOV B,#0AH
- DIV AB ;除十分出個(gè)位/十位
- MOV 30H,A ;十位存于(30H)
- MOV 31H,B ;個(gè)位存于(31H)
- MOV R5,30H ;取十位
- MOV R4,31H ;取個(gè)位
- MOV A,R6
- SUBB A,#07H
- JNC LARGER ;大于5s跳到LARGER,小于等于5s會(huì)提醒
- MOV A,R0
- CJNE A,#0AH,FULL ;1s中0.5s向下運(yùn)行
- CLR RING
- AJMP CHECK
- FULL: CJNE A,#14H,CHECK ;下面是1s的情況,響并顯示號(hào)數(shù)并清R0,重新計(jì)
- SETB RING
- MOV A,R6
- JZ QUIT ;計(jì)時(shí)完畢
- MOV R0,#00H
- DEC R6 ;一秒標(biāo)志減1
- AJMP CHECK
- LARGER: MOV A,R0
- CJNE A,#14H,CHECK ;如果1s向下運(yùn)行,否者跳到"停/顯示"
- DEC R6 ;計(jì)時(shí)一秒R6自動(dòng)減1
- MOV R0,#00H
- CHECK: JNB P3.1,QUIT ;如按下停止鍵退出
- JNB OK,CHECKK ;只在回答倒計(jì)時(shí)才有效
- AJMP NEXTT
- CHECKK:JNB P3.0,REPEAT ;判斷是否使用錦囊
- NEXTT: ACALL DISPLAY
- JB OK,ACCOUT;如果是搶答倒計(jì)時(shí),如是則查詢搶答,否者跳過(guò)查詢繼續(xù)倒數(shù)(這里起到鎖搶答作用)
- AJMP RECOUNT
- ACCOUT:MOV A,DATA0
- JNB ACC.0,TRUE1
- JNB ACC.1,TRUE2
- JNB ACC.2,TRUE3
- JNB ACC.3,TRUE4
- JNB ACC.4,TRUE5
- JNB ACC.5,TRUE6
- JNB ACC.6,TZ7
- JNB ACC.7,TZ8
- AJMP RECOUNT
- TZ7: AJMP TRUE7
- TZ8: AJMP TRUE8
- QUIT: CLR OK ;如果按下了"停止鍵"執(zhí)行的程序
- CLR RING
- AJMP START
- TRUE1: ACALL BARK
- MOV A,R2
- MOV R6,A ;搶答時(shí)間R2送R6
- MOV R3,#01H
- CLR OK ;因?yàn)榇痤}的計(jì)時(shí)不再查詢搶答,所以就鎖了搶答
- AJMP COUNT
- TRUE2:ACALL BARK
- MOV A,R2
- MOV R6,A
- MOV R3,#02H
- CLR OK
- AJMP COUNT
- TRUE3:ACALL BARK
- MOV A,R2
- MOV R6,A
- MOV R3,#03H
- CLR OK
- AJMP COUNT
- TRUE4:ACALL BARK
- MOV A,R2
- MOV R6,A
- MOV R3,#04H
- CLR OK
- AJMP COUNT
- TRUE5: ACALL BARK
- MOV A,R2
- MOV R6,A
- MOV R3,#05H
- CLR OK
- AJMP COUNT
- TRUE6: ACALL BARK
- MOV A,R2
- MOV R6,A
- MOV R3,#06H
- CLR OK
- AJMP COUNT
- TRUE7: ACALL BARK
- MOV A,R2
- MOV R6,A
- MOV R3,#07H
- CLR OK
- AJMP COUNT
- TRUE8: ACALL BARK
- MOV A,R2
- MOV R6,A
- MOV R3,#08H
- CLR OK
- AJMP COUNT
- ERROR: MOV R0,#00H
- MOV TH1,#3CH
- MOV TL1,#0B0H
- MOV 34H,R3 ;犯規(guī)號(hào)數(shù)暫存與(34H)
- HERE: MOV A,R0
- CJNE A,#06H,FLASH ;0.3s向下運(yùn)行->滅并停響
- CLR RING
- MOV R3,#0AH
- MOV R4,#0AH
- MOV R5,#0AH ;三燈全滅
- AJMP CHECK1
- FLASH: CJNE A,#0CH,CHECK1 ;下面是0.8s的情況,響并顯示號(hào)數(shù)并清R0,重新計(jì)
- SETB RING
- MOV R0,#00H
- MOV R3,34H ;取回號(hào)數(shù)
- MOV R5,#0BH
- MOV R4,#0BH ;顯示FF和號(hào)數(shù)
- AJMP CHECK1
- CHECK1: JNB P3.1,QUIT1
- ACALL DISPLAY
- AJMP HERE
- QUIT1: CLR RING
- CLR OK
- AJMP START
- DISPLAY:MOV DPTR,#DAT1 ;查表顯示程序,利用P0口做段選碼口輸出/P2低三位做位選碼輸出
- MOV A,R3
- MOVC A,@A+DPTR
- MOV P2,#0feH
- MOV P0,A
- ACALL DELAY
- MOV DPTR,#DAT2
- MOV A,R5
- MOVC A,@A+DPTR
- MOV P2,#0fdH
- MOV P0,A
- ACALL DELAY
- MOV A,R4
- MOVC A,@A+DPTR
- MOV P2,#0fbH
- MOV P0,A
- ACALL DELAY
- RET
- DAT1:DB 00h,06h,5bh,4fh,66h,6dh,7dh,07h,7fh,6fh,00H,71H
- ;"滅","1","2","3","4","5","6","7","8","9","滅","F"
- DAT2:DB 3fh,06h,5bh,4fh,66h,6dh,7dh,07h,7fh,6fh,00H,71H
八位搶答器.zip
(201.99 KB, 下載次數(shù): 38)
2017-12-18 13:32 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
