查看: 6225|回復(fù): 12
基于C51的LCD1602時(shí)鐘仿真(代碼注釋很詳細(xì))
ID:236686 發(fā)表于 2017-12-19 22:04 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
使用了 溫度傳感器  和DS1302時(shí)鐘芯片
單片機(jī)源程序如下(注釋部分很詳細(xì)):
#include<reg52.h>
#include<intrins.h>
#define uint  unsigned int
#define  LCD1602_DATA   P0   //定義P3口為定LCD數(shù)據(jù)口
sbit buzz=P2^7;
sbit LCD1602_RS=P1^2;
sbit LCD1602_RW=P1^1;
sbit LCD1602_E =P1^0;
sbit key_select=P3^2;    //定義選擇按鍵的IO口
sbit key_increment=P3^3; //定義自加按鍵的IO口
sbit key_decrement=P3^4; //定義自減按鍵的IO口
sbit key_detemine= P3^5; //定義確定按鍵的IO口
sbit SCLK=P1^5;
sbit DSIO=P1^6;
sbit RST=P1^7;
sbit DQ=P2^0;//定義DS18B20的數(shù)據(jù)通訊IO口為P2.4
unsigned char year;  //定義變量year,   用來(lái)存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的年份數(shù)據(jù)
unsigned char week;  //定義變量week,   用來(lái)存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的星期數(shù)據(jù)
unsigned char month; //定義變量month,  用來(lái)存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的月份數(shù)據(jù)
unsigned char day;   //定義變量day,    用來(lái)存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的日份數(shù)據(jù)
static unsigned char hour;  //定義變量hour,   用來(lái)存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的小時(shí)數(shù)據(jù)
static unsigned char minute;//定義變量minute, 用來(lái)存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的分鐘數(shù)據(jù)
static unsigned char second;//定義變量secode, 用來(lái)存儲(chǔ)從ds1302時(shí)鐘芯片中獲取的秒鐘數(shù)據(jù)
unsigned char temperature_integer;//定義變量temperature_integer,用來(lái)存儲(chǔ)讀取的溫度整數(shù)部分
unsigned char temperature_decimal;//定義變量temperature_decimal,用來(lái)存儲(chǔ)讀取溫度的小數(shù)部分
unsigned char set_time_state;   //當(dāng)值為1時(shí)進(jìn)入設(shè)計(jì)時(shí)間的循環(huán)中,當(dāng)為0時(shí)退出設(shè)計(jì)時(shí)間狀態(tài)
unsigned char lcd1602_add;      //記錄LCD1602數(shù)據(jù)指針地址
static unsigned char alarm_hour=7;           //存儲(chǔ)鬧鐘小時(shí)數(shù)據(jù)變量
static unsigned char alarm_minute=30; //存儲(chǔ)鬧鐘分鐘數(shù)據(jù)變量
static unsigned char hour_ten;         //   小時(shí)的十進(jìn)制
static unsigned char minute_ten;         //分鐘的十進(jìn)制
uchar        ditab[16]= {0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9}; //小數(shù)部分表格,用來(lái)計(jì)算方法獲取
static unsigned char *Week_dat[]={
"0000",
"Mon ",
"TUes",
"Wed ",
"Thur",
"Fir ",
"Sat ",
"Sun ",
unsigned char Temp_L,Temp_H;
函數(shù)名稱:delay_ms(uint x)
函數(shù)功能:延時(shí)一定時(shí)間
參數(shù):多少毫秒
void delay(uint x)//延時(shí)函數(shù)
    uchar i;
    while(x--)
        for(i=114; i>0; i--);
函數(shù)名稱:Delay7ms()
函數(shù)功能:延時(shí)7毫秒
輸入?yún)?shù):無(wú)
返回值:  無(wú)
特別說(shuō)明:晶振頻率工作在12MHZ情況下延時(shí)7毫秒
void Delay7ms()                //@12.000MHz
    unsigned char i, j;
    i = 82;
    j = 179;
    do
        while (--j);
    } while (--i);
函數(shù)名稱:Delay10us()
函數(shù)功能:延時(shí)10微秒
輸入?yún)?shù):無(wú)
返回值:  無(wú)
void Delay10us()                //@12.000MHz
    unsigned char i;
    _nop_();
    i = 2;
    while (--i);
函數(shù)名稱:Delay50us()
函數(shù)功能:延時(shí)50微秒
輸入?yún)?shù):無(wú)
返回值:  無(wú)
void Delay50us()                //@12.000MHz
    unsigned char i;
    _nop_();
    i = 22;
    while (--i);
函數(shù)名稱:Delay500us()
函數(shù)功能:延時(shí)500微秒
輸入?yún)?shù):無(wú)
返回值:  無(wú)
void Delay500us()                //@12.000MHz
    unsigned char i;
    _nop_();
    i = 247;
    while (--i);
函數(shù)名稱:Delay500ms()
函數(shù)功能:延時(shí)500毫秒
輸入?yún)?shù):無(wú)
返回值:  無(wú)
void Delay500ms()                //@12.000MHz
    unsigned char i, j, k;
    _nop_();
    i = 4;
    j = 205;
    k = 187;
    do
        do
            while (--k);
        } while (--j);
    } while (--i);
void Delay800ms()                //@12.000MHz
    _nop_();
    i = 7;
    j = 21;
    k = 96;
    do
        do
            while (--k);
        } while (--j);
    } while (--i);
函數(shù)名稱:LCD1602_write_com(uchar com)
函數(shù)參數(shù):要寫入的指令
函數(shù)功能:向lcd1602寫入一個(gè)指令
函數(shù)返回值:無(wú)
void LCD1602_Write_Com(uchar com)//寫指令
    LCD1602_E=0;
    LCD1602_RS=0;
    LCD1602_RW=0;
    LCD1602_DATA =com;
    LCD1602_E=1;
    delay(2);
    LCD1602_E=0;
函數(shù)名稱:LCD1602_write_date(uchar dat)
函數(shù)返回值:無(wú)
void LCD1602_Write_Date(uchar dat)//寫數(shù)據(jù)
    LCD1602_E=0;
    LCD1602_RS=1;
    LCD1602_RW=0;
    LCD1602_DATA =dat;
    LCD1602_E=1;
    delay(2);
    LCD1602_E=0;
函數(shù)名稱:LCD1608_Init()
函數(shù)參數(shù):無(wú)
函數(shù)功能:初始化LCD1602
函數(shù)返回值:無(wú)
void LCD1602_Init()//初始化LCD_1602
    delay(15);
    LCD1602_Write_Com(0X38);
    delay(5);
    delay(5);
    LCD1602_Write_Com(0X01);
    LCD1602_Write_Com(0X06);
    LCD1602_Write_Com(0X0c);
函數(shù):   void LCD1602_printf(uchar H,uchar L,uchar dat)
函數(shù)參數(shù):H表示行,L表示列,dat表示數(shù)據(jù)
函數(shù)功能:在指定的H行,第L+1個(gè)處開始寫入一個(gè)字符
函數(shù)返回值:無(wú)
void LCD1602_Printf(bit H,uchar L,uchar dat)
    if(H)
        LCD1602_Write_Com(0X80+0X40+L);
        LCD1602_Write_Date(dat);
        LCD1602_Write_Com(0X80+L);
函數(shù)名稱:LCD1602_ClS()
函數(shù)功能:清楚屏幕
函數(shù)返回值:無(wú)
void LCD1602_Cls()
    LCD1602_Write_Com(0x01);
函數(shù)名稱:void LCD1602_Printf_String(bit H,uchar L,uchar dat)
函數(shù)功能:H表示行,L表示列,dat表示數(shù)據(jù)
函數(shù)返回值:無(wú)
void LCD1602_Printf_String(bit H,uchar L,uchar* str)
    if(H)
        while(*str!='\0')
            LCD1602_Write_Date(*str++);
        while(*str!='\0')
函數(shù)名稱:bit Key_Select_Is_Dowm()
函數(shù)功能:檢測(cè)key_select按鍵是否被按下,按鍵被按下返回1,按鍵沒(méi)有被按下返回0
輸入?yún)?shù):無(wú)。
返回值:按鍵被按下返回1,按鍵沒(méi)有被按下返回0
    if(!key_select)
        Delay7ms();
        if(!key_select)
            return 1;
    return 0;
函數(shù)名稱:bit Key_Increment_Is_Dowm()
函數(shù)功能:檢測(cè)key_increment按鍵是否被按下,按下返回1,沒(méi)有被按下返回0
輸入?yún)?shù):無(wú)
返回值: 按鍵被按下返回1,按鍵沒(méi)有被按下返回0
    if(!key_increment)
        Delay7ms();
        if(!key_increment)
            return 1;
    return 0;
函數(shù)名稱:bit Key_Decrement_Is_Dowm()
函數(shù)功能:檢測(cè)key_decrement按鍵是否被按下,按下返回1,沒(méi)有被按下返回0
輸入?yún)?shù):無(wú)
    if(!key_decrement)
        Delay7ms();
        if(!key_decrement)
            return 1;
    return 0;
函數(shù)名稱:bit Key_determine_Is_Dowm()
函數(shù)功能:檢測(cè)key_determine按鍵是否被按下,按下返回1,沒(méi)有被按下返回0
輸入?yún)?shù):無(wú)
bit Key_Determine_Is_Dowm()
    if(!key_detemine)
        Delay7ms();
        if(!key_detemine)
            return 1;
    return 0;
函數(shù)名稱:void write_ds1302(uchar dat)
函數(shù)功能:向DS1302芯片寫入一個(gè)字節(jié)
輸入?yún)?shù):寫入的數(shù)據(jù)
返回值:無(wú)
void Ds1302_Write(uchar dat)//寫入一個(gè)字節(jié)
    uchar i;
    for(i=0; i<8; i++)
        DSIO=dat&0x01;
        SCLK=1;
        dat>>=1;
        SCLK=0;
函數(shù)名稱: read_ds1302())
函數(shù)功能:向DS1302芯片讀取一個(gè)字節(jié)
輸入?yún)?shù):無(wú)
返回值:  返回DS_1302讀取的一個(gè)數(shù)據(jù)
uchar Ds1302_Read()//讀出一個(gè)字節(jié)
    uchar i,tem=0;
    for(i=0; i<8; i++)
        tem>>=1;
        if(DSIO)
            tem|=0x80;
        SCLK=1;
        SCLK=0;
    return tem;
函數(shù)名稱: rest_ds1302()
函數(shù)功能:ds1302復(fù)位
輸入?yún)?shù):無(wú)
返回值:
void Ds1302_Rest()//ds1302復(fù)位
    RST=0;
    DSIO=0;
    RST=1;
函數(shù)名稱:write(uchar add,uchar addr)
函數(shù)功能:向DS1302寫入一個(gè)數(shù)據(jù)
輸入?yún)?shù):地址,數(shù)據(jù)
返回值:  無(wú)
void Ds1302_Write_Data(uchar add,uchar dat)//寫入一個(gè)數(shù)據(jù)
    uchar  t;
    t=dat/10;
    dat=dat%10;
    dat=t*16+dat; //轉(zhuǎn)化為BCD碼
    Ds1302_Rest();
    Ds1302_Write(add);
    Ds1302_Write(dat);
    RST=0;
    DSIO=0;
函數(shù)名稱:write_BCD(uchar add,uchar addr)
函數(shù)功能:向DS1302寫入一個(gè)BCD數(shù)據(jù)
返回值:  無(wú)
void DS1302_Write_BCD(uchar add,uchar dat)//寫入一個(gè)BCD數(shù)據(jù)
// uchar  t;
// t=dat/10;
// dat=dat%10;
// dat=t*16+dat; //轉(zhuǎn)化為BCD碼
    Ds1302_Rest();
    Ds1302_Write(add);
    Ds1302_Write(dat);
    RST=0;
    DSIO=0;
函數(shù)名稱:read(uchar add)
函數(shù)功能:讀出一個(gè)時(shí)間
輸入?yún)?shù):地址
返回值:  時(shí)間
uchar Ds1302_Read_Time(uchar add)//讀出一個(gè)時(shí)間
    uchar temp;
    Ds1302_Rest();
    Ds1302_Write(add);
    temp=Ds1302_Read();
    RST=0;
    DSIO=0;
    return temp;
函數(shù)名稱:Open_Wp()
函數(shù)功能:打開寫保護(hù)開關(guān),失之不可以對(duì)DS1302進(jìn)行寫操作
輸入?yún)?shù):無(wú)
返回值:  無(wú)
void Ds1302_Open_Wp()
    Ds1302_Write_Data(0x8e,0x80);
函數(shù)名稱:Colse_Wp()
函數(shù)功能:關(guān)閉寫保護(hù)開關(guān),使之可以對(duì)DS1302進(jìn)行寫操作
輸入?yún)?shù):無(wú)
返回值:  無(wú)
void Ds1302_Close_Wp()
    Ds1302_Write_Data(0x8e,0);
函數(shù)名稱:uchar Get_Ds1302_Year_BCD()
函數(shù)功能:獲取DS1302內(nèi)部年份寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無(wú)
返回值:  當(dāng)前DS1302芯片內(nèi)部存儲(chǔ)小時(shí),數(shù)值為BCD碼
    return Ds1302_Read_Time(0x8d);
函數(shù)名稱:uchar Get_Ds1302_Week_BCD()
函數(shù)功能:獲取DS1302內(nèi)部星期寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無(wú)
    return Ds1302_Read_Time(0x8B);
函數(shù)名稱:uchar Get_Ds1302_Month_BCD()
函數(shù)功能:獲取DS1302內(nèi)部月份寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無(wú)
    return Ds1302_Read_Time(0x89);
函數(shù)名稱:uchar Get_Ds1302_Day_BCD()
函數(shù)功能:獲取DS1302內(nèi)部日份占拇嫫魘藎ɑ袢〉鼻靶∈筆藎?
輸入?yún)?shù):無(wú)
    return Ds1302_Read_Time(0x87);
函數(shù)名稱:uchar Get_Ds1302_Hour_BCD()
函數(shù)功能:獲取DS1302內(nèi)部小時(shí)寄存器數(shù)據(jù)(獲取當(dāng)前小時(shí)數(shù)據(jù))
輸入?yún)?shù):無(wú)
    return Ds1302_Read_Time(0x85);
函數(shù)名稱:uchar Get_Ds1302_Minute        _BCD()
輸入?yún)?shù):無(wú)
uchar Get_Ds1302_Minute_BCD()
    return Ds1302_Read_Time(0x83);
函數(shù)名稱:uchar Get_Ds1302_Second_BCD()
輸入?yún)?shù):無(wú)
    return Ds1302_Read_Time(0x81);
函數(shù)名稱:Ds18b20_Init()        //
函數(shù)功能:DS18B20初始化        //
輸入?yún)?shù):無(wú)        //
返回值:返回為1表示DS18B20發(fā)出了存在信息,為0表示沒(méi)有?        //        //
uchar Ds18b20_Init()        //
    uchar  value; //定義一個(gè)變量value,用來(lái)保存中間結(jié)果。        //
    DQ=1;                                        //把總線拉為高電平。        //
    Delay10us();        //保持10us,目的是為了穩(wěn)定系統(tǒng)端口。        //
    DQ=0;                                        //初始化第一步,總線拉為低電平,低電平時(shí)間應(yīng)該保持480us-960us之間。                                                //
    Delay500us();        //這里選擇保持500us。        //
    DQ=1;                                        //初始化第二步:總線拉為高電平(釋放端口),用于下一步檢測(cè)DS18B20                                                        //
    Delay50us();        //延時(shí)50微妙。        //
    value=DQ;                        //檢測(cè)總線電平,并把值賦給變量value,返回為1表示DS18B20發(fā)出了存在信息,                                //
    //為0表示沒(méi)有發(fā)出存在信息        //
    Delay500us();        //檢測(cè)        總線電平后延時(shí)500us,為了穩(wěn)定系統(tǒng)總線。
    return value;        //返回value值        //
函數(shù)名稱: Ds18b20_Write_Date(uchar dat)
函數(shù)功能:向DS18B20中寫入一個(gè)數(shù)據(jù)
輸入?yún)?shù):要寫入數(shù)據(jù)的值
返回值:無(wú)
void Ds18b20_Write_Date(uchar dat)
    uchar i;                                        //定義局部變量i,用于循環(huán)計(jì)數(shù)
    for(i=0; i<8; i++)        //循環(huán)8次將寫入一個(gè)8位的數(shù)據(jù)
        DQ=1;                                                //把總線拉為高電平
        Delay10us();                //保持10us,目的是為穩(wěn)定系統(tǒng)端口。
        DQ=0;                                                //總線時(shí)間為低電平,保持時(shí)間大于1us后寫數(shù)據(jù)。
        _nop_();                                //空操作,延時(shí)1us。
        DQ=dat&0x01;                //向DS18b20中寫入一位數(shù)據(jù)。
        dat>>=1;                                //數(shù)據(jù)右移一位準(zhǔn)備寫入下一位,DS18B20先寫低位再寫高位。
        Delay50us();                //延時(shí)50us
        Delay10us();                //延時(shí)10us,為了DS18b20        采樣總線上的數(shù)據(jù)
        DQ=1;
        //        Delay10us();                //延時(shí)10us,為了DS18b20        采樣總線上的數(shù)據(jù)
    DQ=1;                                                        //釋放總線。
函數(shù)名稱:uchar        Ds18b20_Read_Date()
函數(shù)功能:從DS18B20中讀取一個(gè)字節(jié)數(shù)據(jù)
輸入?yún)?shù):無(wú)
返回值:讀取到的值
    uchar i, value;//定義中間變量
    for(i=0; i<8; i++)
        DQ=1;                                                //將總線拉為高電平
        Delay10us();                //保持10us,目的是為了讓系統(tǒng)端口穩(wěn)定。
        DQ=0;                                                //把總線拉為低電平。
        _nop_();
        _nop_();
        value>>=1;                                //1,延時(shí),2,數(shù)據(jù)右移一位,準(zhǔn)備讀下一位
        DQ=1;                                                //把總線拉為高電平準(zhǔn)備讀數(shù)據(jù)
        _nop_();
        _nop_();
        if(DQ)
            value|=0x80;
        DQ=1;                                                //釋放總線
    return value;                //返回讀取到的字節(jié)數(shù)據(jù)
函數(shù)名稱:uchar Get_Ds18b20_Temperature(bit Va
函數(shù)功能:讀取溫度程序
輸入?yún)?shù):輸入?yún)?shù)為0返回溫度的小數(shù),輸入?yún)?shù)為1則返回溫度的整數(shù)
返回值:讀取到的值
uchar  Get_Ds18b20_Temperature_Integer()//讀取溫度程序,參數(shù)為1,返回整數(shù),參數(shù)為小數(shù)
    unsigned char temp_integer;
    while(Ds18b20_Init());                //初始化DS18B20。
    Ds18b20_Write_Date(0xcc);        //跳過(guò)ROM命令。
    _nop_();
    Ds18b20_Write_Date(0x44);        //啟動(dòng)溫度轉(zhuǎn)換。
    // Delay500ms();
    while(!DQ);        //等待轉(zhuǎn)化完畢
    _nop_();
    Ds18b20_Write_Date(0xbe);        //啟動(dòng)溫度轉(zhuǎn)換。
    Temp_L=Ds18b20_Read_Date();                //讀取到溫度的低字節(jié)。
    Temp_H=Ds18b20_Read_Date();                //暫存讀取到的溫度低字節(jié)。
    temp_integer=(Temp_H<<4)+(Temp_L>>4);
    return temp_integer;                                                        //返回溫度的整數(shù)部分
函數(shù)名稱:uchar Get_Ds18b20_Decimal
函數(shù)功能:讀取溫度程序的小數(shù)部分
輸入?yún)?shù):無(wú)
返回值:讀取到的溫度的小數(shù)的值
uchar  Get_Ds18b20_Temperature_Decimal()//讀取溫度程序,參數(shù)為1,返回整數(shù),參數(shù)為小數(shù)
    unsigned char  temp_decimal;
                if(Temp_H&0x80)
                        Temp_L=~Temp_L;
    temp_decimal=ditab[Temp_L&0x0f];
    return temp_decimal;
函數(shù)名稱:void Update_Time()
函數(shù)功能:更新,年,周,月,日,小時(shí),分鐘,秒鐘的變量里的數(shù)據(jù)
輸入?yún)?shù):無(wú)
返回值: 無(wú)
void Update_Time()
    year  = Get_Ds1302_Year_BCD();  //更新年份數(shù)據(jù)
    week  = Get_Ds1302_Week_BCD();  //更新周數(shù)據(jù)
    month = Get_Ds1302_Month_BCD(); //更新月份數(shù)據(jù)
    day   = Get_Ds1302_Day_BCD();   //更新日期數(shù)據(jù)
    hour  = Get_Ds1302_Hour_BCD();  //更新小時(shí)數(shù)據(jù)
    minute= Get_Ds1302_Minute_BCD();//更新月份數(shù)據(jù)
    second= Get_Ds1302_Second_BCD();  //更新秒種數(shù)據(jù)
輸入?yún)?shù):無(wú)
返回值: 無(wú)
//void Update_Temperature()
//                //        temperature_integer=Get_Ds18b20_Temperature(1);
//                        //temperature_decimal=Get_Ds18b20_Temperature(0);
輸入?yún)?shù):無(wú)
返回值: 無(wú)
void Dispaly_Temperature()
    temperature_integer=Get_Ds18b20_Temperature_Integer();
    temperature_decimal=Get_Ds18b20_Temperature_Decimal();
    if(temperature_integer<127)
        LCD1602_Printf(1,10,'+');
        temperature_integer=~temperature_integer;
        LCD1602_Printf(1,10,'-');
    LCD1602_Printf(1,11,(temperature_integer/10)+48);
    LCD1602_Printf(1,12,(temperature_integer%10)+48);
    LCD1602_Write_Date('.');
    LCD1602_Printf(1,14,(temperature_decimal)+48);
    LCD1602_Write_Date('C');
函數(shù)名稱:Dispaly_Time()
函數(shù)功能:更新顯示年,周,月,日,小時(shí),分鐘,秒鐘
輸入?yún)?shù):無(wú)
返回值: 無(wú)
void Dispaly_Time()
    //LCD1602_Cls();
    LCD1602_Printf_String(0,0,"20");
    LCD1602_Printf(0,2,(year>>4)+48);            //year變量的高四位存儲(chǔ)年份的十位,取year的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(0,3,(year&0x0f)+48);   //year變量的低四位存儲(chǔ)年份的個(gè)位,取year的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Write_Date('/');
    LCD1602_Printf(0,5,(month>>4)+48);          //month變量的高四位存儲(chǔ)月份的十位,取month的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(0,6,(month&0x0f)+48);  //month變量的低四位存儲(chǔ)月份的個(gè)位,取month的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(0,8,(day>>4)+48);                  //day變量的高四位存儲(chǔ)日份的十位,取day的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(0,9,(day&0x0f)+48);          //day變量的低四位存儲(chǔ)日份的個(gè)位,取day的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
        LCD1602_Printf_String(0,12,Week_dat[week&0x0f]);    // 調(diào)用week_dat數(shù)組內(nèi)對(duì)應(yīng)數(shù)據(jù)
//    LCD1602_Printf(0,12,(week>>4)+48);    //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
//    LCD1602_Printf(0,13,(week&0x0f)+48);  //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
   // LCD1602_Printf_String(0,14,"th");
    LCD1602_Printf(1,1,(hour>>4)+48);     //hour變量的高四位存儲(chǔ)小時(shí)的十位,取hour的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,2,(hour&0x0f)+48);   //hour變量的低四位存儲(chǔ)小時(shí)的個(gè)位,取hour的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Write_Date(':');
    LCD1602_Printf(1,4,(minute>>4)+48);   //minute變量的高四位存儲(chǔ)分鐘的十位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,5,(minute&0x0f)+48); //minute變量的低四位存儲(chǔ)分鐘的個(gè)位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,7,(second>>4)+48);   //second變量的高四位存儲(chǔ)秒鐘的十位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,8,(second&0x0f)+48); //second變量的高四位存儲(chǔ)秒鐘的個(gè)位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
           year=(year>>4)*10+(year&0x0f);
        month=(month>>4)*10+(month&0x0f);
        day=(day>>4)*10+(day&0x0f);                                //由BCD碼轉(zhuǎn)變?yōu)槭M(jìn)制碼
        week=week&0x0f;
        hour=(hour>>4)*10+(hour&0x0f);
        minute=(minute>>4)*10+(minute&0x0f);
        second=(second>>4)*10+(second&0x0f);
    if((alarm_hour==hour)&&(alarm_minute==minute))          //鬧鐘檢測(cè)
        if(second%2)
            buzz=0;
            buzz=1;
        buzz=1;
    while(minute==0&&second==0) //整點(diǎn)報(bào)時(shí)
        if(minute==0&&second==0)
            buzz=0;
            buzz=1;
        Update_Time();
函數(shù)名稱: Set_Time()
函數(shù)功能:調(diào)整設(shè)置時(shí)間
輸入?yún)?shù):無(wú)
返回值: 無(wú)
void Set_Time()
    if(Key_Select_Is_Dowm())
        buzz=0;
        set_time_state=1;
        lcd1602_add=0x83;
        LCD1602_Write_Com(0x0f);//開顯示光標(biāo),并且光標(biāo)閃爍
        while(Key_Select_Is_Dowm());
        buzz=1;
    while(set_time_state)
        LCD1602_Write_Com(lcd1602_add);
            buzz=0;
            switch(lcd1602_add)
            case 0x83 :
                lcd1602_add=0x86;
                break;
            case 0x86 :
                lcd1602_add=0x89;
                break;
            case 0x89 :
                lcd1602_add=0x8d;
                break;
            case 0x8d :
                lcd1602_add=0xc2;
                break;
            case 0xc2 :
                lcd1602_add=0xc5;
                break;
            case 0xc5 :
                lcd1602_add=0xc8;
                break;
            case 0xc8 :
                lcd1602_add=0x83;
                break;
            default   :
                break;
            buzz=1;
        if(Key_Increment_Is_Dowm())
            buzz=0;
            switch(lcd1602_add)
            case 0x83:
                year++;
                if(year>99)
                    year=0;
                LCD1602_Printf(0,2,(year/10)+48);            //year變量的高四位存儲(chǔ)年份的十位,取year的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                LCD1602_Printf(0,3,(year%10)+48);   //year變量的低四位存儲(chǔ)年份的個(gè)位,取year的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                break;
            case 0x86:
                month++;
                if(month>12)
                    month=1;
                LCD1602_Printf(0,5,(month/10)+48);            //year變量的高四位存儲(chǔ)年份的十位,取year的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                LCD1602_Printf(0,6,(month%10)+48);   //year變量的低四位存儲(chǔ)年份的個(gè)位,取year的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                break;
            case 0x89:
                day++;
                switch(month)
                case 1:
                case 3:
                case 5:
                case 7:
                case 8:
                case 10:
                case 12:
                    if(day>31)
                        day=1;
                    break;
                case 4:
                case 6:
                case 9:
                case 11:
                    if(day>30)
                        day=1;
                    break;
                case 2:
                    if(year%4==0)
                        if(day>29)
                            day=1;;
                        break;
                    if(day>28)
                        day=1;
                    break;
                default :
                    break;
                LCD1602_Printf(0,8,(day/10)+48);          //month變量的高四位存儲(chǔ)月份的十位,取month的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                LCD1602_Printf(0,9,(day%10)+48);  //month變量的低四位存儲(chǔ)月份的個(gè)位,取month的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                break;
            case 0x8d:
                week++;
                if(week>7)
                    week=1;
//                LCD1602_Printf(0,12,(week/10)+48);    //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
//                LCD1602_Printf(0,13,(week%10)+48);  //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                break;
            case 0xc2:
                hour++;
                if(hour>23)
                    hour=0;
                LCD1602_Printf(1,1,(hour/10)+48);    //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                LCD1602_Printf(1,2,(hour%10)+48);  //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                break;
            case 0xc5:
                minute++;
                if(minute>59)
                    minute=0;
                LCD1602_Printf(1,4,(minute/10)+48);   //minute變量的高四位存儲(chǔ)分鐘的十位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                LCD1602_Printf(1,5,(minute%10)+48);   //minute變量的低四位存儲(chǔ)分鐘的個(gè)位,取minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                break;
            case 0xc8:
                second++;
                if(second>59)
                    second=0;
                LCD1602_Printf(1,7,(second/10)+48);   //second變量的高四位存儲(chǔ)秒鐘的十位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                LCD1602_Printf(1,8,(second%10)+48); //second變量的高四位存儲(chǔ)秒鐘的個(gè)位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
                break;
            default :
                break;
            while(Key_Increment_Is_Dowm());
            buzz=1;
//自減按鍵
        if(Key_Decrement_Is_Dowm())
            buzz=0;
            switch(lcd1602_add)
            case 0x83:
                if(year>0)
                    year--;
                    year=99;
                break;
            case 0x86:
                if(month>1)
                    month--;
                    month=12;
                break;
            case 0x89:
                switch(month)
                case 1:
                case 3:
                case 5:
                case 7:
                case 8:
                case 10:
                case 12:
                    if(day>1)
                        day--;
                        day=31;
                    break;
                case 4:
                case 6:
                case 9:
                case 11:
                    if(day>1)
                        day--;
                        day=30;
                    break;
                    break;
                case 2:
                    if(year%4==0)
                        if(day>1)
                            day--;
                            day=29;
        break;
                        if(day>1)
                            day--;
                            day=28;
                    break;
                default :
                    break;
                break;
            case 0x8d:
                if(week>1)
                   week--;
        week=7;
                break;
            case 0xc2:
                if(hour>0)
                    hour--;
        hour=23;
                break;
            case 0xc5:
                if(minute>0)
                    minute--;
        minute=59;
                break;
            case 0xc8:
                if(second>0)
                   second--;
        second=59;
                break;
            default :
                break;
            while(Key_Decrement_Is_Dowm());
            buzz=1;
        if(Key_Determine_Is_Dowm())
            buzz=0;
            set_time_state=0;   //設(shè)置完成,退出循環(huán)
            LCD1602_Write_Com(0x0c);//關(guān)閉光標(biāo)
            Ds1302_Close_Wp();//關(guān)閉DS1302寫保護(hù),使之可以對(duì)其進(jìn)行寫操作
            Ds1302_Write_Data(0x8c,year);
            Ds1302_Write_Data(0x88,month);
            Ds1302_Write_Data(0x8a,week);
            Ds1302_Write_Data(0x86,day);
            Ds1302_Write_Data(0x84,hour);
            Ds1302_Write_Data(0x82,minute);
            Ds1302_Write_Data(0x80,second);
                                                Ds1302_Open_Wp();//打開ds1302寫保護(hù),使之不可以對(duì)其進(jìn)行寫操作
            while(Key_Determine_Is_Dowm());
            buzz=1;
            break;
函數(shù)名稱:  set_alarm()
函數(shù)功能:設(shè)計(jì)鬧鐘時(shí)間
輸入?yún)?shù):無(wú)
返回值: 無(wú)
void set_alarm()
    LCD1602_Cls();                                                          //清除屏幕
    LCD1602_Printf_String(0,1,"alarm clock ");
    LCD1602_Printf(1,1,(alarm_hour/10)+48);    //week變量的高四位存儲(chǔ)周份的十位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,2,(alarm_hour%10)+48);  //week變量的低四位存儲(chǔ)周份的個(gè)位,取week的低四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,3,':');
    LCD1602_Printf(1,4,(alarm_minute/10)+48);   //alarm_minute變量的高四位存儲(chǔ)分鐘的十位,取alarm_minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,5,(alarm_minute%10)+48);   //alarm_minute變量的低四位存儲(chǔ)分鐘的個(gè)位,取alarm_minute的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,6,':');
    LCD1602_Printf(1,7,0+48);   //second變量的高四位存儲(chǔ)秒鐘的十位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    LCD1602_Printf(1,8,0+48); //second變量的高四位存儲(chǔ)秒鐘的個(gè)位,取second的高四位,+48就轉(zhuǎn)換為對(duì)應(yīng)數(shù)字的字符
    lcd1602_add=0xc2;                 //光標(biāo)初始化地址
    set_time_state=1;          //菜單標(biāo)志位置1
        LCD1602_Write_Com(lcd1602_add);        //光標(biāo)顯示地址
            buzz=0;                                        //蜂鳴器打開
            switch(lcd1602_add)
            case 0xc2 :
                lcd1602_add=0xc5;
                break;
            case 0xc5 :
                lcd1602_add=0xc2;
                break;
            default   :
                break;
            buzz=1;
            buzz=0;
            switch(lcd1602_add)
            case 0xc2:
                alarm_hour++;
                if(alarm_hour>23)
                    alarm_hour=0;
                break;
            case 0xc5:
                alarm_minute++;
                if(alarm_minute>59)
                    alarm_minute=0;
                break;
            default :
                break;
            buzz=1;
//自減按鍵
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
全部資料51hei下載地址:
LCD時(shí)鐘.zip (186.69 KB, 下載次數(shù): 156)
收藏收藏6 分享淘帖 頂 踩
無(wú)效樓層,該帖已經(jīng)被刪除
16#
15#
14#
ID:247623 發(fā)表于 2019-8-12 10:05 | 只看該作者
你們沒(méi)發(fā)現(xiàn)他的星期顯示是錯(cuò)誤的嗎,這個(gè)時(shí)間對(duì)應(yīng)的應(yīng)該是星期二,而不是星期三
ID:47652 發(fā)表于 2019-5-11 13:45 | 只看該作者
哈,產(chǎn)品級(jí)的資料了,謝謝樓主
ID:47652 發(fā)表于 2019-5-11 13:33 | 只看該作者
不錯(cuò)的資料
ID:432524 發(fā)表于 2018-11-24 19:21 來(lái)自觸屏版 | 只看該作者
樓主分享的資料很好。我做畢業(yè)設(shè)計(jì)剛好沒(méi)有頭緒,樓主給我了希望!
ID:426444 發(fā)表于 2018-11-24 18:45 來(lái)自觸屏版 | 只看該作者
感謝樓主分享
ID:432270 發(fā)表于 2018-11-24 13:42 | 只看該作者
樓主有做實(shí)物嗎?想要PCB圖
ID:432270 發(fā)表于 2018-11-24 13:19 | 只看該作者
很詳細(xì)啊,就是不知道樓主有沒(méi)有做實(shí)物。
ID:427653 發(fā)表于 2018-11-18 15:47 | 只看該作者
非常不錯(cuò)
5#
ID:267527 發(fā)表于 2017-12-28 09:33 | 只看該作者
看起來(lái)不錯(cuò)
ID:241586 發(fā)表于 2017-12-26 11:48 | 只看該作者
不錯(cuò)哦
ID:247086 發(fā)表于 2017-12-25 10:40 來(lái)自觸屏版 | 只看該作者
不錯(cuò)!
ID:236686 發(fā)表于 2017-12-19 22:06 | 只看該作者
附件里面包含了   proteus仿真文件  還有源程序
