查看: 1952|回復(fù): 1
單片機INT0中斷計數(shù) 初學(xué)簡單程序
ID:257587 發(fā)表于 2017-12-22 08:31 | 顯示全部樓層 |閱讀模式
INT0中斷計數(shù)
       說明:每次按下計數(shù)鍵時觸發(fā)INT0中斷,中斷程序累加計數(shù),  計數(shù)值顯示在3只數(shù)碼管上,按下清零鍵時數(shù)碼管清零
ID:257587 發(fā)表于 2017-12-22 08:33 | 顯示全部樓層
#include<reg51.h> #define uchar unsigned char #define uint unsigned int //0~9的段碼 uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00}; //計數(shù)值分解后各個待顯示的數(shù)位 uchar DSY_Buffer[]={0,0,0}; uchar Count=0; sbit Clear_Key=P3^6; //數(shù)碼管上顯示計數(shù)值 void Show_Count_ON_DSY() {         DSY_Buffer[2]=Count/100;        //獲取3個數(shù)         DSY_Buffer[1]=Count%100/10;         DSY_Buffer[0]=Count%10;         if(DSY_Buffer[2]==0)   //高位為0時不顯示         {                 DSY_Buffer[2]=0x0a;                 if(DSY_Buffer[1]==0)   //高位為0,若第二位為0同樣不顯示                         DSY_Buffer[1]=0x0a;         }         P0=DSY_CODE[DSY_Buffer[0]];         P1=DSY_CODE[DSY_Buffer[1]];         P2=DSY_CODE[DSY_Buffer[2]]; } //主程序 void main() {         P0=0x00;         P1=0x00;         P2=0x00;         IE=0x81;        //允許INT0中斷         IT0=1;                //下降沿觸發(fā)         while(1)         {                 if(Clear_Key==0) Count=0;        //清0                 Show_Count_ON_DSY();         } } //INT0中斷函數(shù) void EX_INT0() interrupt 0 {         Count++;         //計數(shù)值遞增 }
