查看: 3641|回復(fù): 1
stm8 spi 通信,獲得的數(shù)據(jù)都是0xff或是0xffff,這是哪里問題?
ID:240510 發(fā)表于 2017-12-22 11:21 | 顯示全部樓層 |閱讀模式
我采用的單片機(jī)是stm8L051系列的
這個(gè)是我spi配置的初始化函數(shù)
void MySPI_Init(void)
   /* SPI Periph clock enable */
   CLK_PeripheralClockConfig(SPI_CLK, ENABLE);
   /* Set the MOSI,MISO and SCK at high level */
   GPIO_Init(SPI_GPIO_PORT, SPI_MOSI_PIN, GPIO_Mode_Out_PP_High_Fast);
   GPIO_Init(SPI_GPIO_PORT, SPI_MISO_PIN, GPIO_Mode_In_PU_No_IT);
   GPIO_Init(SPI_GPIO_PORT, SPI_SCK_PIN, GPIO_Mode_Out_PP_High_Fast);
  /* Configure FLASH_CS as Output push-pull, used as Flash Chip select */
   GPIO_Init(SPI_GPIO_PORT, SPI_CS_PIN, GPIO_Mode_Out_PP_High_Fast);
   GPIO_ExternalPullUpConfig(SPI_GPIO_PORT,SPI_MISO_PIN,ENABLE);
    SPI_DeInit(SPI1);
    SPI_Init(SPI1, SPI_FirstBit_MSB, SPI_BaudRatePrescaler_2, SPI_Mode_Master,
            SPI_CPOL_High, SPI_CPHA_1Edge, SPI_Direction_2Lines_FullDuplex,
            SPI_NSS_Soft, (uint8_t)0x07);
    SPI_Cmd(SPI1,ENABLE);
#define SPI_CLK                   CLK_Peripheral_SPI1
#define SPI_SCK_PIN               GPIO_Pin_5                  /* PB.05 */
#define SPI_MISO_PIN              GPIO_Pin_7                  /* PB.07 */
#define SPI_MOSI_PIN              GPIO_Pin_6                  /* PB.06 */
#define SPI_CS_PIN                GPIO_Pin_4                  /* PE.04 */
#define SPI_GPIO_PORT          GPIOB                       /* GPIOE */
這些是我獲得額數(shù)據(jù)
0xff      0xffff
請問為什么獲得的都是這樣的數(shù)據(jù),是硬件問題還是程序配置問題
ID:240510 發(fā)表于 2017-12-22 11:44 | 顯示全部樓層
原來這是spi配置問題
spi配置如下
//   GPIO_Init(SPI_GPIO_PORT, SPI_MOSI_PIN, GPIO_Mode_Out_PP_High_Fast);
//   GPIO_Init(SPI_GPIO_PORT, SPI_SCK_PIN, GPIO_Mode_Out_PP_High_Fast);
   GPIO_ExternalPullUpConfig(SPI_GPIO_PORT,SPI_MOSI_PIN|SPI_SCK_PIN,ENABLE);
    SPI_DeInit(SPI1);
            SPI_CPOL_Low, SPI_CPHA_1Edge, SPI_Direction_2Lines_FullDuplex,
