- //定義引腳
- int Pin0 = 8;
- int Pin1 = 9;
- int Pin2 = 10;
- int Pin3 = 11;
- int _step = 0;
- boolean dir = false;//正反轉(zhuǎn)
- int stepperSpeed = 1;//電機轉(zhuǎn)速,1ms一步
- //脈沖總數(shù),或者說步的總數(shù)
- int stepsum=0;
- void setup()
- pinMode(Pin0, OUTPUT);
- pinMode(Pin1, OUTPUT);
- pinMode(Pin2, OUTPUT);
- pinMode(Pin3, OUTPUT); }
- void loop()
- //進步機的驅(qū)動方式,有八種
- switch(_step){
- case 0:
- digitalWrite(Pin0, LOW);
- digitalWrite(Pin1, LOW);
- digitalWrite(Pin2, LOW);
- digitalWrite(Pin3, HIGH);
- break;
- case 1:
- digitalWrite(Pin2, HIGH);
- break;
- case 2:
- digitalWrite(Pin3, LOW);
- break;
- case 3:
- digitalWrite(Pin1, HIGH);
- break;
- case 4:
- break;
- case 5:
- digitalWrite(Pin0, HIGH);
- break;
- case 6:
- break;
- case 7:
- break;
- default:
- break;
- //判斷是正轉(zhuǎn)還是反轉(zhuǎn)
- if(dir)
- _step++;
- }else{
- _step--;
- //每八步一個驅(qū)動方式的循環(huán)
- if(_step>7){
- _step=0;
- if(_step<0){
- _step=7;
- delay(stepperSpeed);
- //計算脈沖數(shù),每4096個脈沖停1秒
- stepsum++;
- if(stepsum==4096)
- Serial.println(stepsum);
- stepsum=0;
- delay(1000);
復制代碼
用ardiuno實現(xiàn)的電機正反轉(zhuǎn)
正反轉(zhuǎn).doc
2017-12-23 14:03 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
18 KB, 下載次數(shù): 18, 下載積分: 黑幣 -5
如題
