查看: 1437|回復(fù): 0
新手求教 用的IAP15轉(zhuǎn)接板,沒有一點(diǎn)現(xiàn)象
ID:266083 發(fā)表于 2017-12-24 16:12 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define key_input P3
#define key_mask 0x0f
#define key_state_0 0
#define key_state_1 1
#define key_state_2 2
typedef  unsigned char uchar ;
typedef  unsigned int uint;
uchar tab[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar disbuf[] = {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07};
sbit buzzer=P0^6;
char Key_Read(void)
     static char key_state=0;
     char key_press,key_return=0;
     key_press=key_mask&key_input;
     switch(key_state)
            case key_state_0:
            if(key_press!=key_mask)
               key_state=key_state_1;
            break;
            case key_state_1:
            if(key_press==key_mask&key_input)
               if(key_press==0x0e)key_return=1;
               if(key_press==0x0d)key_return=2;
               if(key_press==0x0b)key_return=3;
               if(key_press==0x07)key_return=4;
               key_state=key_state_2;
            break;
            case key_state_2:
            if(key_press==key_state_0)
            key_state=key_state_0;
            break;
return key_return;
void Display(uchar which,uchar num)
     P2=0xc0;P0=0xff;P2=0x00;
     P2=0xc0;P0=disbuf[which];P2=0x00;
     P2=0xe0;P0=tab[num];P2=0x00;
void Time0() interrupt 1 using 3
     char i;
     TH0=(65536-1000)/256;
     TL0=(65536-1000)%256;
     i=Key_Read;
     if(i==1)Display(0,1);
     if(i==2)Display(7,1);
     if(i==3)buzzer=1;
     if(i==4)buzzer=0;
     ET0=0;
     TR0=1;
     EA=1;
Rebuild target 'Target 1'
assembling STARTUP.A51...
compiling main.c...
linking...
Program Size: data=36.0 xdata=0 code=346
creating hex file from "一個(gè)人的寂寞"...
"一個(gè)人的寂寞" - 0 Error(s), 0 Warning(s).
用的IAP15轉(zhuǎn)接板,沒有一點(diǎn)現(xiàn)象,暈死
