查看: 2333|回復: 1
有沒有大神來指導下,為什么p2.3口的電平不產(chǎn)生跳變,在二次輸入密碼時跳變?yōu)榈碗娖剑?/span>
ID:212728 發(fā)表于 2017-12-24 16:29 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
這是一個電子密碼鎖的程序,初始密碼輸入后選擇1在輸入密碼,這時P2.3卻無法變?yōu)榈碗娖,請大神看看有什么問題
#include<reg51.h>
#include<intrins.h.>
sbit RS = P2^0;
sbit RW = P2^1;
sbit E = P2^2;
sbit P2_3 = P2^3;
sbit P2_4 = P2^4;
sbit P2_5 = P2^5;
sbit reset = P2^6;
sbit Sound = P2^7;
sbit scl = P3^6;
sbit sda = P3^7;
sbit led = P3^0;
uchar scan_1[6];
uchar password_1[7];
uchar newpassword_1[6];
uchar password_4[7]={0,0,0,0,0,0,1};
uchar code scan[6]={"******"};
uchar code table[]={0x7b,0xed,0xeb,0xe7,0xdd,0xdb,0xd7,0xbd,0xbb,0xb7,0x7d,0x77};
uchar code table1[]={"Input Code"};
uchar code table2[]={"Function Select"};
uchar code table3[]={"Input Code Again"};
uchar code table4[]={"[1]Open [2]Reset"};
uchar code table5[]={"Input New Code"};
uchar code table6[]={"Comfirm New Code"};
uchar code table7[]={"Success!"};
uchar code table8[]={"Failure!"};
uchar code table9[]={"Warning!"};
uchar code Array1[]={ 0x1C, 0x20,0x20, 0x20,0x1C,0x20,0x18,0x20, 0x20,0x80,0xFF,0x20};
void Read_Code(uchar password[],uchar address,uchar num);
void Write_Code(uchar Data[],uchar address,uchar num);
void Start();
void stop();
void Ack();
void NoAck();
uchar read_byte();
void write_byte(uchar date);
void lcd_init();
void write_com(uchar com);
void write_data(uchar date);
void delay();
void delay_ms(uint z);
void print(uchar tab[],uchar len,uchar loc,bit res);
void num9();
void num10();
void num11();
void Test1();
void Test2();
void Sound_Delay(uchar n);
void Music();
void Alarm();
void Music1();
void errorMusic(uint t);
char scan_num=-1;           //鍵盤號數(shù)
uchar scan_len=0;           //輸入數(shù)的長度
uchar yes,key,flag;
uchar Sound_Signal;//定義音符大小
uchar Sound_Pace;//定義節(jié)拍大小
uchar Counter1;
uchar error;
        P2_3 = 1;                  //密碼鎖關(guān)
        P2_4 = 1;
        P2_5 = 1;
        Sound = 1;
        EA=1;                          //開總中斷
        EX0=1;                          //開外部中斷0
        IT0=1;                          //中斷0下降沿觸發(fā)
        TMOD=0x01;              //定時器0工作方式1
        TH0=0xff;
        TL0=0xff;
        ET0=1;                          //開定時器0中斷
        P1=0xf0;
        led = 1;
        if( reset == 0)          //如果鍵按下,則密碼清零,恢復出廠設(shè)置
                Write_Code(password_4,0,6);
        Read_Code(password_1,0,7);                  //從24C02中讀密碼
        if(password_1[6] == 1)            //之前對各卡的第七位分別寫入1,2,3
                flag = 1;
        if(password_1[6] == 2)
                flag = 2;
        if(password_1[6] == 3)
                flag = 3;
        lcd_init();                                                  //LCD初始化
                if(scan_num!=-1)
                        if(scan_num<=9)
                                num9();       //數(shù)字0~9處理
                        if(scan_num==10)
                                num10();      //刪除
                        if(scan_num==11)
                                if(scan_len == 6)
                                        num11();      //確定
                                        Music();
                                        if(key == 2)   //再次輸入新密碼后確認鍵
                                                key = 0;
                                                Test2();
                                                return;
                                        Test1();          //提示"Input Code"輸入的密碼確認后判斷是否正確
void Read_Code(uchar password[],uchar address,uchar num)           //從24C02中讀數(shù)據(jù)
        uchar i;
        for(i=0;i<num;i++)
                Start();                                            //開始信號
                write_byte(0xa0);                            //寫控制字
                Ack();                                                    //應答信號
                write_byte(address+i);                        //讀地址
                Ack();                                                    //應答信號
                Start();                                            //開始信號
                write_byte(0xa1);                            //讀控制字
                Ack();                                                //應答信號
                password[i] = read_byte();      //讀數(shù)據(jù)
                NoAck();                                                //非應答信號
                stop();                                          //停止信號
void Write_Code(uchar Data[],uchar address,uchar num)        //把數(shù)據(jù)寫到24C02
        uchar i;
        for(i=0;i<num;i++)
                Start();                                        //開始信號
                Ack();                                                //應答信號
                write_byte(address+i);                //寫地址
                Ack();                                                //應答信號
                write_byte(Data[i]);                //寫數(shù)據(jù)
                Ack();                                                //應答信號
                stop();                                                //停止信號
                delay_ms(10);
void Start()                  //開始信號
        sda = 1;
        delay();
        scl = 1;
        delay();
        sda = 0;
        delay();
void stop()                    //停止信號
        sda = 0;
        delay();
        scl = 1;
        delay();
        sda = 1;
        delay();
void Ack()                         //應答信號
        uchar i;
        scl = 1;
        delay();
        while((sda == 1)&&(i < 250))
                i++;
        scl = 0;
        delay();
void NoAck()  //非應答信號
        sda=1;
        delay();
        scl=1;
        delay();
        scl=0;
        delay();
uchar read_byte()         //讀字節(jié)數(shù)據(jù)
        uchar i,k;
        scl = 0;
        delay();
        sda = 1;
        delay();
        for(i = 0;i < 8;i++)
                scl = 1;
                delay();
                k = (k<<1)|sda;
                scl = 0;
                delay();
        return k;
void write_byte(uchar date)                //寫字節(jié)數(shù)據(jù)
        uchar i,temp;
        temp = date;
                temp = temp<<1;
                scl = 0;
                delay();
                sda = CY;
                delay();
                scl = 1;
                delay();
        scl = 0;
        delay();
        sda = 1;
        delay();
void lcd_init()
        //uchar i;
        write_com(0x38);                //設(shè)置16*2顯示,5*7點陣,8位數(shù)據(jù)接口
        write_com(0x0c);                //設(shè)置開顯示,不顯示光標
        write_com(0x06);                //寫一個字符后地址指針加1
        write_com(0x01);                //顯示清0,數(shù)據(jù)指針清0
        write_com(0x80 + 0x03);        //設(shè)置數(shù)據(jù)地址指針位置
        /*for(i = 0;i <10;i++)
                write_data(table1[i]);
                delay_ms(5);
        }與下句語句等價 */
        print(table1,10,0x83,1); //LCD顯示“Input Code”
/*LCD顯示,輸出函數(shù)*/
        uchar i,n;
        if(res==1)
                write_com(0x01);             //光標復位
        write_com(loc);                         //設(shè)置顯示起始位置
        for(n=0;n<len;n++)
                i=tab[n];
                write_data(i);
        for(n=len;n<6;n++)
                write_data(32);                          //空格
void write_com(uchar com)                 //向LCD寫命令
        RS = 0;
        RW = 0;
        P0 = com;
        delay_ms(5);
        E = 1;
        delay_ms(5);
        E = 0;
void write_data(uchar date)                 //向LCD寫數(shù)據(jù)
        RS = 1;
        RW = 0;
        P0 = date;
        delay_ms(5);
        E = 1;
        delay_ms(5);
        E = 0;
/*按下鍵盤產(chǎn)生中斷,中斷程序*/
void EX_INT0() interrupt 0
        uchar aa,bb,i,j;
        EA = 0;                  //關(guān)總中斷
        P1 = 0xf0;
        if((P1 & 0xf0) != 0xf0)
                delay_ms(5);
                        aa = 0xfe;
                        for(i = 0;i < 4;i++)
                                P1 = aa;
                                        bb = P1;
                                        for(j=0;j<16;j++)
                                                if(bb == table[j])
                                                        scan_num = j;
                                        aa = _crol_(aa,1);
        P1 = 0xf0;
        EA=1;                 //開總中斷
/*輸入數(shù)字0~9處理函數(shù)*/
void num9()
        uchar i;
        if(scan_len>5)
                return;
        if(yes == 1)                  // 提示“Input Code”輸入正確密碼后
                if(scan_num == 1)           //鍵1開鎖鍵
                        Music();
                        yes = 0;
                        scan_num=-1;
                        if(flag == 1)
                                flag = 0;
                                P2_3 = 0;
                        if(flag == 2)
                                flag = 0;
                                P2_3 = 0;
                                P2_4 = 0;
                        if(flag == 3)
                                flag = 0;
                                P2_3 = 0;
                                P2_4 = 0;
                                P2_5 = 0;
                if(scan_num == 2)                //鍵2設(shè)置新密碼
                        Music();
                        yes = 0;
                        print(table5,14,0x81,1); //LCD顯示“Input New Code”
                        scan_num=-1;
                        key = 1;
                }return;
        Music();
        scan_1[scan_len] = scan_num;
        //scan[scan_len] = scan_num + 48;
        scan_len++;
        print(scan,scan_len,0xc5,0);          //顯示密碼值
        scan_num=-1;
        if(key == 1)                  //輸入6位新密碼后,提示“Comfirm New Code”
                if(scan_len == 6)
                        scan_len = 0;
                        for(i = 0;i < 6;i++)
                                newpassword_1[i] = scan_1[i];
                        key = 2;
                        print(table6,16,0x80,1);            //LCD顯示“Comfirm New Code”
/*刪除鍵*/
void num10()
        if(scan_len>0)
                Music();
                scan_len=scan_len-1;//字符串的長度減少一位
                print(scan,scan_len,0xc5,0);  //顯示輸入值刪除一位后的新值
                scan_num=-1;
/*確認鍵*/
void num11()
//        if(scan_len == 0)
//                return;
        scan_num=-1;
        scan_len=0;
void Test1()         //輸入的密碼是否正確
        uchar i;
        if((password_1[0]==scan_1[0])&&(password_1[1]==scan_1[1])&&(password_1[2]==scan_1[2])&&(password_1[3]==scan_1[3])&&(password_1[4]==scan_1[4])&&(password_1[5]==scan_1[5]))
                yes=1;
                print(table2,15,0x81,1);
                print(table4,16,0xc0,0);
                yes=0;
                print(table3,16,0x80,1); //LCD顯示“Input Code Again”
                error++;
                if(error == 3)
                        error = 0;
                        print(table9,8,0x84,1); //LCD顯示“Warning!”
                        for(i = 0;i < 10;i++ )
                                errorMusic(90);
                                errorMusic(120);
                                led = ~led;
                        delay_ms(1000);
                        led = 1;
void Test2()                          //修改密碼時兩次輸入的密碼是否相同
        if((newpassword_1[0]==scan_1[0])&&(newpassword_1[1]==scan_1[1])&&(newpassword_1[2]==scan_1[2])&&(newpassword_1[3]==scan_1[3])&&(newpassword_1[4]==scan_1[4])&&(newpassword_1[5]==scan_1[5]))
                Write_Code(newpassword_1,0,6);        //向24c02寫入新密碼
                print(table7,8,0x84,1); //LCD顯示“Success!”
                Alarm();
                delay_ms(1000);
                Read_Code(password_1,0,6);
                print(table8,8,0x84,1); //LCD顯示“Failure!”
                Music1();
                delay_ms(1000);
void timer0(void) interrupt 1 using 1
        Counter1++;        //節(jié)拍次數(shù)計數(shù)
        TH0=0xd8; //定義單位節(jié)拍的延時大小
        TL0=0xef;
void Music()                         //按鍵聲
        Sound_Signal=Array1[0];
        Sound_Pace=Array1[1];
        TR0=1;
        //當節(jié)拍數(shù)未達到時候,繼續(xù)循環(huán),產(chǎn)生該音調(diào)的聲音
        while(Counter1!=Sound_Pace)
                Sound=~Sound;
                Sound_Delay(Sound_Signal);
        Counter1=0;//節(jié)拍計數(shù)器置0,進入下一個音調(diào)
        TR0=0;
void Alarm()                                  //設(shè)置密碼成功后的聲音
        Sound_Signal=Array1[2];
        Sound_Pace=Array1[3];
        TR0=1;
                Sound=~Sound;
        // i++;
        TR0=0;
void Music1()                  //設(shè)置密碼失敗后的聲音
        uchar i=0;
        while(i<14)
                Sound_Signal=Array1[i];
                Sound_Pace=Array1[++i];
                TR0=1;                  //開定時器T0
                        Sound=~Sound;
                Counter1=0;
                TR0=0;
                i++;
        uchar i,j;
        for(i=0;i<100;i++)
                Sound=~Sound;
                for(j=0;j<t;j++);
        uchar i;
        while(n--)
                for(i=0;i<2;i++);
void delay()
        uchar i,j;
        for(i=1;i>0;i--)
                for(j=20;j>0;j--);
        uint x,y;
        for(x = z;x > 0;x--)
                for(y = 110;y > 0;y--);
p2.3應產(chǎn)生跳變與1N4001連接使二極管亮起來
ID:212728 發(fā)表于 2017-12-24 16:38 | 只看該作者
不是1N4001而是74ls04連接
