查看: 2999|回復(fù): 13
DS18B20和步進電機為啥不會轉(zhuǎn)呢?
回帖獎勵 200 黑幣 回復(fù)本帖可獲得 10 黑幣獎勵! 每人限 1 次
ID:241873 發(fā)表于 2017-12-27 10:02 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define uint        unsigned        int
#define        uchar        unsigned        char
#define Coil_A1 {A1=1;B1=0;C1=0;D1=0;}
#define Coil_B1 {A1=0;B1=1;C1=0;D1=0;}
#define Coil_C1 {A1=0;B1=0;C1=1;D1=0;}
#define Coil_D1 {A1=0;B1=0;C1=0;D1=1;}
#define Coil_AB1 {A1=1;B1=1;C1=0;D1=0;}
#define Coil_BC1 {A1=0;B1=1;C1=1;D1=0;}
#define Coil_CD1 {A1=0;B1=0;C1=1;D1=1;
#define Coil_DA1 {A1=1;B1=0;C1=0;D1=1;}
#define Coil_OFF {A1=0;B1=0;C1=0;D1=0;}
sbit DSPORT=P3^7;
sbit A1=P1^0;
sbit B1=P1^1;
sbit C1=P1^2;
sbit D1=P1^3;
uchar Speed;
void Delay1ms(uint y);
uint x;
for(y;y>0;y--)
   for(x=110;x>0;x--);
unsigned char Ds18b20Init()
        unsigned int i;
        DSPORT=0;
        i=70;
        while(i--);
        DSPORT=1;
        i=0;
        while(DSPORT)
                i++;
                if(i>5000)
                        return 0;
        return 1;
void Ds18b20WriteByte(unsigned char dat)
        unsigned int i,j;
        for(j=0;j<8;j++)
                DSPORT=0;
                i++;
                DSPORT=dat&0x01;
                i=6;
                while(i--);
                DSPORT=1;
                dat>>=1;
unsigned char Ds18b20ReadByte()
        unsigned char byte,bi;
        unsigned int i,j;
        for(j=8;j>0;j--)
                DSPORT=0;
                i++;
                DSPORT=1;
                i++;
                i++;
                bi=DSPORT;
                byte=(byte>>1)|(bi<<7);
                i=4;
                while(i--);
        return byte;
void  Ds18b20ChangTemp()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xcc);
        Ds18b20WriteByte(0x44);
void  Ds18b20ReadTempCom()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xbe);
int Ds18b20ReadTemp()
        int temp=0;
        unsigned char tmh,tml;
        Ds18b20ChangTemp();
        Ds18b20ReadTempCom();
        tml=Ds18b20ReadByte();
        tmh=Ds18b20ReadByte();
        temp=tmh;
        temp<<=8;
        temp|=tml;
        return temp;
void        main()
        unsigned int tp,j,i;
        tp=Ds18b20ReadTemp;
        Speed=2;
                if(tp>=20)
         Coil_A1
     Delay1ms(Speed);
     Coil_AB1
     Delay1ms(Speed);
         Coil_B1
      Delay1ms(Speed);
     Coil_BC1
       Delay1ms(Speed);
         Coil_C1
       Delay1ms(Speed);
     Coil_CD1
      Delay1ms(Speed);
         Coil_D1
      Delay1ms(Speed);
     Coil_DA1
     Delay1ms(Speed);
                        Coil_OFF;
                        for(i=0;i<10;i++)
                                for(j=0;j<60;j++)
                                        Delay1ms(1000);
ID:78322 發(fā)表于 2017-12-27 15:01 | 顯示全部樓層
從程序看,你是采樣的溫度值大于20,就會啟動馬達,而且,你的溫度只采樣一次,如果一開始的值小于20,步進電機就不會動。
ID:84283 發(fā)表于 2017-12-27 15:27 | 顯示全部樓層
ds18b20你沒讓它工作,導(dǎo)致tp接收不到。
ID:117053 發(fā)表于 2017-12-27 16:45 | 顯示全部樓層
從程序上分析的話,會不會是因為你的溫度沒有達到要求,所以導(dǎo)致DS18B20和步進電機不轉(zhuǎn)動。
ID:241873 發(fā)表于 2017-12-27 19:23 | 顯示全部樓層
立里 發(fā)表于 2017-12-27 15:01
從程序看,你是采樣的溫度值大于20,就會啟動馬達,而且,你的溫度只采樣一次,如果一開始的值小于20,步進 ...
可以這樣說 我想做的是溫度大于這個就可以開始工作 不知道咋樣修改 了 可以幫下忙嗎
qq1105424012 發(fā)表于 2017-12-27 15:27
這個就尷尬了 有啥辦法修改一下嗎
ID:84283 發(fā)表于 2017-12-27 19:47 | 顯示全部樓層
湮滅GG 發(fā)表于 2017-12-27 19:23
這個就尷尬了 有啥辦法修改一下嗎
把18B20 采集溫度的函數(shù)放在while中,讓它一直執(zhí)行從而改變得到tp的數(shù)值,20攝氏度以上就轉(zhuǎn)。
ID:84283 發(fā)表于 2017-12-27 19:49 | 顯示全部樓層
這個就尷尬了 有啥辦法修改一下嗎
也就是這個函數(shù) Ds18b20ReadTemp()
ID:241873 發(fā)表于 2017-12-28 10:10 | 顯示全部樓層
qq1105424012 發(fā)表于 2017-12-27 19:49
尷尬了 我把這個放進去之后還是沒反應(yīng)。
ID:267813 發(fā)表于 2017-12-28 11:33 | 顯示全部樓層
void        main()
        tp=Ds18b20ReadTemp;
        Speed=2;
tp=Ds18b20ReadTemp();
這個地方有點語法錯誤哈,否則你是根本沒有采集溫度,溫度為0,步進電機當然不動啦
ID:267813 發(fā)表于 2017-12-28 11:35 | 顯示全部樓層
改為:
        Speed=2;
再試試
ID:241873 發(fā)表于 2017-12-28 15:14 | 顯示全部樓層
zzzxxxccc 發(fā)表于 2017-12-28 11:33
void        main()
這個需要咋樣修改
ID:268407 發(fā)表于 2017-12-28 16:29 | 顯示全部樓層
溫度多高啊 ,溫度沒有達到要求。
ID:262845 發(fā)表于 2017-12-30 12:05 | 顯示全部樓層
采集溫度和驅(qū)動要控時序,交差驅(qū)動,不能同時控制。
