分享一個(gè)很好的無(wú)線收發(fā)源碼
1. 將改程序下載到2個(gè)開(kāi)發(fā)板
2. 然后按KEY0會(huì)顯示對(duì)應(yīng)信息
3. A-B 2個(gè)板子上電時(shí),A-B板子的數(shù)碼管都顯示為:—(橫線) ,
4. 當(dāng)按下A板子的KEY0按鍵時(shí),A板子會(huì)發(fā)送數(shù)據(jù),自身數(shù)碼管會(huì)變化,顯示為1,而B(niǎo)板子收到數(shù)據(jù)且判斷數(shù)據(jù)是正確時(shí),數(shù)碼管也會(huì)變化,顯示為1,然后B板子自動(dòng)回傳數(shù)據(jù),告訴A板子已經(jīng)收到數(shù)據(jù)了,B板子發(fā)送出返回?cái)?shù)據(jù)后自身數(shù)碼管又變化顯示為—(橫線),而當(dāng)A板子收到返回的數(shù)據(jù),且正確時(shí),數(shù)碼管又從1顯示為—(橫線),這就完成一次帶反饋的無(wú)線雙向收發(fā)通訊,在一些應(yīng)用中,需要可靠的無(wú)線通訊就需要增加這種返回機(jī)制,如果發(fā)送出得不到回傳反饋信息,那就可以重傳,直到傳輸?shù)健?br />
5. A-B開(kāi)發(fā)板都可以做為發(fā)送和接收,一個(gè)做為發(fā)送,對(duì)應(yīng)另一即為接收
- #include <reg52.h>
- #include <intrins.h>
- typedef unsigned char uchar;
- typedef unsigned char uint;
- //****************************************NRF24L01端口定義***************************************
- sbit MISO =P1^3;
- sbit MOSI =P1^4;
- sbit SCK =P1^2;
- sbit CE =P1^1;
- sbit CSN =P3^2;
- sbit IRQ =P3^3;
- //************************************按鍵***************************************************
- sbit KEY1=P3^6;
- sbit KEY2=P3^7;
- //************************************數(shù)碼管位選*********************************************
- sbit led3=P2^0;
- sbit led2=P2^1;
- sbit led1=P2^2;
- sbit led0=P2^3;
- //************************************蜂明器***************************************************
- sbit BELL=P3^4;
- //***********************************數(shù)碼管0-9編碼*******************************************
- uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段碼
- //*********************************************NRF24L01*************************************
- #define TX_ADR_WIDTH 5 // 5 uints TX address width
- #define RX_ADR_WIDTH 5 // 5 uints RX address width
- #define TX_PLOAD_WIDTH 20 // 20 uints TX payload
- #define RX_PLOAD_WIDTH 20 // 20 uints TX payload
- uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址
- uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址
- unsigned char tf =0;
- unsigned char TxBuf[20]={0}; //
- unsigned char RxBuf[20]={0};
- //***************************************NRF24L01寄存器指令*******************************************************
- #define READ_REG 0x00 // 讀寄存器指令
- #define WRITE_REG 0x20 // 寫(xiě)寄存器指令
- #define RD_RX_PLOAD 0x61 // 讀取接收數(shù)據(jù)指令
- #define WR_TX_PLOAD 0xA0 // 寫(xiě)待發(fā)數(shù)據(jù)指令
- #define FLUSH_TX 0xE1 // 沖洗發(fā)送 FIFO指令
- #define FLUSH_RX 0xE2 // 沖洗接收 FIFO指令
- #define REUSE_TX_PL 0xE3 // 定義重復(fù)裝載數(shù)據(jù)指令
- #define NOP 0xFF // 保留
- //*************************************SPI(nRF24L01)寄存器地址****************************************************
- #define CONFIG 0x00 // 配置收發(fā)狀態(tài),CRC校驗(yàn)?zāi)J揭约笆瞻l(fā)狀態(tài)響應(yīng)方式
- #define EN_AA 0x01 // 自動(dòng)應(yīng)答功能設(shè)置
- #define EN_RXADDR 0x02 // 可用信道設(shè)置
- #define SETUP_AW 0x03 // 收發(fā)地址寬度設(shè)置
- #define SETUP_RETR 0x04 // 自動(dòng)重發(fā)功能設(shè)置
- #define RF_CH 0x05 // 工作頻率設(shè)置
- #define RF_SETUP 0x06 // 發(fā)射速率、功耗功能設(shè)置
- #define STATUS 0x07 // 狀態(tài)寄存器
- #define OBSERVE_TX 0x08 // 發(fā)送監(jiān)測(cè)功能
- #define CD 0x09 // 地址檢測(cè)
- #define RX_ADDR_P0 0x0A // 頻道0接收數(shù)據(jù)地址
- #define RX_ADDR_P1 0x0B // 頻道1接收數(shù)據(jù)地址
- #define RX_ADDR_P2 0x0C // 頻道2接收數(shù)據(jù)地址
- #define RX_ADDR_P3 0x0D // 頻道3接收數(shù)據(jù)地址
- #define RX_ADDR_P4 0x0E // 頻道4接收數(shù)據(jù)地址
- #define RX_ADDR_P5 0x0F // 頻道5接收數(shù)據(jù)地址
- #define TX_ADDR 0x10 // 發(fā)送地址寄存器
- #define RX_PW_P0 0x11 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
- #define RX_PW_P1 0x12 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
- #define RX_PW_P2 0x13 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
- #define RX_PW_P3 0x14 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
- #define RX_PW_P4 0x15 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
- #define RX_PW_P5 0x16 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
51-BACK-NRF24l01雙向通信.rar
(27.23 KB, 下載次數(shù): 349)
2017-12-27 20:56 上傳
點(diǎn)擊文件名下載附件
