查看: 2902|回復(fù): 0
adc0832模數(shù)轉(zhuǎn)換與顯示
ID:270277 發(fā)表于 2018-1-2 16:28 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
//           說明:調(diào)整VR1時,adc0832將模擬電壓轉(zhuǎn)換為數(shù)字電壓顯示在1602液晶
//           屏第0行,液晶屏第一行同時以進程條方式顯示當(dāng)前電壓大小。
#include<reg51.h>
#include<intrins.h>
#include<string.h>
//adc0832引腳定義
sbit CS = P2^0;     //片選線
sbit CLK = P2^1;
sbit DIO = P2^2;
sbit RS = P1^0;
sbit RW = P1^1;
sbit E = P1^2;
#define LCD_PORT P0
uchar Disp_Buffer1[] = "VOLTAGE:   0.00V";
uchar Disp_Buffer2[16];
#define delay4us() {_nop_();_nop_();_nop_();_nop_();}
void delay_ms(uint x)
uchar t;
while(x--)
  for(t = 0; t < 120 ;t++);
//  du mang
bit Read_LCD_Busy_Flag()
uchar result;
LCD_PORT = 0XFF;
RS = 0;
RW = 1;
E = 1;
delay4us();
result = P0;E = 0;
return(result&0x80)?1:0;
//xie lcd  command
void Write_LCD_Command(uchar cmd)
while(Read_LCD_Busy_Flag() );
RS = 0;
RW = 0;
E = 0;
  _nop_();
LCD_PORT = cmd;
delay4us();
E = 1;
delay4us();
E = 0;
//xie lcd  data
void Write_LCD_Data(uchar dat)
while (Read_LCD_Busy_Flag() );
  RS = 1;
RW = 0;
E = 0;
  _nop_();
LCD_PORT = dat;
delay4us();
E = 1;
delay4us();
E = 0;
//在lcd制定行列顯示字符串
void LCD_Show_String(uchar r,uchar c,char *s)
uchar i = 0;
uchar code DDRAM[] = {0x80,0xc0};
Write_LCD_Command(DDRAM[r]|c);
while(s[i]&&i<16)
  Write_LCD_Data(s[i++]);
//LCD初始化
void LCD_Init()
Write_LCD_Command(0x38);delay_ms(1);
Write_LCD_Command(0x0c);delay_ms(1);
Write_LCD_Command(0x06);delay_ms(1);
Write_LCD_Command(0x01);delay_ms(1);
//獲取ad轉(zhuǎn)換結(jié)果
uchar Get_AD_Result()
  uchar i,dat1 = 0,dat2 = 0;
CS = 0;CLK = 0;
DIO = 1;_nop_();_nop_();
CLK = 1;_nop_();_nop_();
CLK = 0;DIO = 1;_nop_();_nop_();
CLK = 0;DIO = 0;_nop_();_nop_();
for (i=0;i<8;i++)
CLK = 0;_nop_();_nop_();
dat1=(dat1<<1)|DIO;
  for (i=0;i<8;i++)
dat2=dat2|((uchar)DIO<<i);
dat1=(dat1<<1)|DIO;
CS= 1;
return(dat1 = dat2)?dat1:0x00;
//串口輸出字符串
void Putstr(char *s)
uchar i=0;
while(s[i])
SBUF = s[i++];
  while(TI == 0);
  TI = 0;
//------主程序
uchar i,AD;
uint d;
LCD_Init();
SCON = 0X50;
TMOD = 0X20;
PCON = 0X00;
TH1=TL1=0XFD;
IE = 0X91;
IT0 = 1;
TR1 = 1;
AD = Get_AD_Result();
d = AD*500.0*2/511.0;
  Disp_Buffer1[11]=d/100+'0';
  Disp_Buffer1[13]=d/10%10+'0';
   Disp_Buffer1[11]=d%10+'0';
LCD_Show_String(0,0,Disp_Buffer1);
Putstr(strcat((char*)Disp_Buffer1,"\r\n"));
delay_ms(50);
i=(uint)AD*16/255;
memset(Disp_Buffer2,'\xff',i);
memset(Disp_Buffer2+i,'\xdb',16-i);
  LCD_Show_String(1,0,Disp_Buffer2);  //memset是以字節(jié)為單位,初始化內(nèi)存塊。
admin + 50 共享資料的黑幣獎勵!
