- #define MAIN_Fosc 22118400L //定義主時(shí)鐘
- #include "STC15Fxxxx.H"
- #define DIS_DOT 0x20
- #define DIS_BLACK 0x10
- #define DIS_ 0x11
- #define SLAW 0xA2
- #define SLAR 0xA3
- sbit SDA = P1^1; //定義SDA PIN5
- sbit SCL = P1^0; //定義SCL PIN6
- /****************************** 用戶定義宏 ***********************************/
- #define Timer0_Reload (65536UL -(MAIN_Fosc / 1000)) //Timer 0 中斷頻率, 1000次/秒
- /************* 本地常量聲明 **************/
- u8 code t_display[]={ //標(biāo)準(zhǔn)字庫
- // 0 1 2 3 4 5 6 7 8 9 A B C D E F
- 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,
- //black - H J K L N o P U t G Q r M y
- 0x00,0x40,0x76,0x1E,0x70,0x38,0x37,0x5C,0x73,0x3E,0x78,0x3d,0x67,0x50,0x37,0x6e,
- 0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0x46}; //0. 1. 2. 3. 4. 5. 6. 7. 8. 9. -1
- u8 code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //位碼
- /************* IO口定義 **************/
- sbit P_HC595_SER = P4^0; //pin 14 SER data input
- sbit P_HC595_RCLK = P5^4; //pin 12 RCLk store (latch) clock
- sbit P_HC595_SRCLK = P4^3; //pin 11 SRCLK Shift data clock
- /************* 本地變量聲明 **************/
- u8 LED8[8]; //顯示緩沖
- u8 display_index; //顯示位索引
- bit B_1ms; //1ms標(biāo)志
- u8 IO_KeyState, IO_KeyState1, IO_KeyHoldCnt; //行列鍵盤變量
- u8 KeyHoldCnt; //鍵按下計(jì)時(shí)
- u8 KeyCode; //給用戶使用的鍵碼, 1~16有效
- u8 cnt50ms;
- u8 hour,minute,second; //RTC變量
- u8 year,month,date; //Cadendar變量
- u16 msecond;
- u8 m;
- u8 flag=0;
- u8 flaging=1;
- u16 k=0;
- unsigned char tt[2]={0x12,0x17};
- unsigned char tt0[1]={0x13};
- unsigned char newtime[3]={0x00,0x00,0x10};
- /************* 本地函數(shù)聲明 **************/
- void CalculateAdcKey(u16 adc);
- void IO_KeyScan(void); //50ms call
- void WriteNbyte(u8 addr, u8 *p, u8 number);
- void ReadNbyte( u8 addr, u8 *p, u8 number);
- void DisplayRTC(void);
- void DisplayCadendar(void);
- void ReadRTC(void);
- void WriteRTC(void);
- void ReadCadendar(void);
- void WriteCadendar(void);
- /**************** 外部函數(shù)聲明和外部變量聲明 *****************/
- void main(void)
- u8 i;
- P0M1 = 0; P0M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P1M1 = 0; P1M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P2M1 = 0; P2M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P3M1 = 0; P3M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P4M1 = 0; P4M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P5M1 = 0; P5M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P6M1 = 0; P6M0 = 0; //設(shè)置為準(zhǔn)雙向口
- P7M1 = 0; P7M0 = 0; //設(shè)置為準(zhǔn)雙向口
- display_index = 0;
- AUXR = 0x80; //Timer0 set as 1T, 16 bits timer auto-reload,
- TH0 = (u8)(Timer0_Reload / 256);
- TL0 = (u8)(Timer0_Reload % 256);
- ET0 = 1; //Timer0 interrupt enable
- TR0 = 1; //Tiner0 run
- IE1 = 0; //外中斷1標(biāo)志位
- IT1 = 1; //INT1下降沿觸發(fā)
- EX1 = 1; //外中斷1允許位
- PX1 = 1; //外部中斷1為高優(yōu)先級(jí)
- EA = 1; //打開總中斷
- for(i=0; i<8; i++) LED8[i] = 0x10; //上電消隱
- WriteNbyte(2,newtime,3);
- ReadRTC();
- WriteNbyte(5,tt0,1);
- WriteNbyte(7,tt,2);
- ReadCadendar();
- F0 = 0;
- if(second >= 60) F0 = 1;
- if(minute >= 60) F0 = 1;
- if(hour >= 24) F0 = 1;
- if(date >= 31) F0 = 1;
- if(month >= 12) F0 = 1;
- if(year >= 99) F0 = 1;
- if(F0) //有錯(cuò)誤, 默認(rèn)12:30:00 17-12-13
- second = 0;
- minute = 30;
- hour = 12;
- WriteRTC();
- date = 13 ;
- month= 12 ;
- year = 17 ;
- WriteCadendar();
- DisplayRTC();
- KeyHoldCnt = 0; //鍵按下計(jì)時(shí)
- KeyCode = 0; //給用戶使用的鍵碼, 1~16有效
- IO_KeyState = 0;
- IO_KeyState1 = 0;
- IO_KeyHoldCnt = 0;
- cnt50ms = 0;
- while(1)
- while(flag==0)
- if(B_1ms) //1ms到
- B_1ms = 0;
- if(++msecond >= 500) //1秒到
- msecond = 0;
- ReadRTC();
- DisplayRTC();
- if(++cnt50ms >= 50) //50ms掃描一次行列鍵盤
- cnt50ms = 0;
- IO_KeyScan();
- if(KeyCode != 0) //有鍵按下
- if(KeyCode == 17) //hour +1
- if(++hour >= 24) hour = 0;
- WriteRTC();
- DisplayRTC();
- if(KeyCode == 18) //hour -1
- if(--hour >= 24) hour = 23;
- WriteRTC();
- DisplayRTC();
- if(KeyCode == 19) //minute +1
- second = 0;
- if(++minute >= 60) minute = 0;
- WriteRTC();
- DisplayRTC();
- if(KeyCode == 20) //minute -1
- second = 0;
- if(--minute >= 60) minute = 59;
- WriteRTC();
- DisplayRTC();
- if(KeyCode == 21)
- flag=1;
- KeyCode = 0;
- while(flag ==1)
- if(k>202)
- DisplayCadendar();
- k=0;
- cnt50ms = 0;
- IO_KeyScan();
- if(KeyCode !=0)
- if(KeyCode == 22)
- flag=0;
- if(KeyCode == 25) //year +1
- KeyCode =0;
- if(++year >= 99) year = 0;
- WriteCadendar();
- //while(1);
- if(KeyCode == 26) //year -1
- KeyCode =0;
- if(--year >= 100) year =99;
- WriteCadendar();
- if(KeyCode == 27) //month +1
- KeyCode =0;
- if(++month >= 13) month = 1;
- WriteCadendar();
- if(KeyCode == 28) //month -1
- KeyCode =0;
- if(--month==0) month = 12;
- WriteCadendar();
- if(KeyCode == 29) //date +1
- KeyCode =0;
- if(++date >= 32) date = 1;
- WriteCadendar();
- if(KeyCode == 30) //date -1
- KeyCode =0;
- if(--date == 0) date = 31;
- WriteCadendar();
- k++;
- /********************** 顯示時(shí)鐘函數(shù) ************************/
- if(hour >= 10) LED8[0] = hour / 10;
- else LED8[0] = DIS_BLACK;
- LED8[1] = hour % 10;
- LED8[2] = DIS_;
- LED8[3] = minute / 10;
- LED8[4] = minute % 10;
- LED8[5] = DIS_;
- LED8[6] = second / 10;
- LED8[7] = second % 10;
- /********************** 顯示日歷函數(shù) ************************/
- LED8[0] = 2;
- LED8[1] = 0;
- if(year >= 10) LED8[2] = year / 10;
- else
- LED8[2] = DIS_BLACK;
- LED8[3] = year % 10;
- LED8[4] = month / 10;
- LED8[5] = month % 10;
- LED8[6] = date / 10;
- LED8[7] = date % 10;
- /**********************讀RTC函數(shù)************************/
- u8 tmp[3];
- ReadNbyte(2, tmp, 3);
- second = ((tmp[0] >> 4) & 0x07) * 10 + (tmp[0] & 0x0f);
- minute = ((tmp[1] >> 4) & 0x07) * 10 + (tmp[1] & 0x0f);
- hour = ((tmp[2] >> 4) & 0x03) * 10 + (tmp[2] & 0x0f);
- // if(minute==20) 19-59停止
- // while(1);
- /**********************寫RTC函數(shù)************************/
- u8 tmp[3];
- tmp[0] = ((second / 10) << 4) + (second % 10);
- tmp[1] = ((minute / 10) << 4) + (minute % 10);
- tmp[2] = ((hour / 10) << 4) + (hour % 10);
- WriteNbyte(2, tmp, 3);
- /********************** 讀Cadendar函數(shù) ************************/
- u8 cad[3];
- ReadNbyte(5, cad, 1);
- ReadNbyte(7, cad+1, 2);
- date = ((cad[0] >> 4) & 0x03) * 10 + (cad[0] & 0x0f);
- month = ((cad[1] >> 4) & 0x01) * 10 + (cad[1] & 0x0f);
- year = (cad[2] >> 4) * 10 + (cad[2] & 0x0f);
- /********************** 寫Cadendar函數(shù) ************************/
- u8 cad[3];
- cad[0] = ((date / 10) << 4) + (date % 10);
- cad[1] = ((month / 10) << 4) + (month % 10);
- cad[2] = ((year / 10) << 4) + (year % 10);
- WriteNbyte(5, cad, 1);
- WriteNbyte(7, cad+1, 2);
- 行列鍵掃描程序
- 使用XY查找4x4鍵的方法,只能單鍵,速度快
- Y P04 P05 P06 P07
- X | | | |
- P00 ---- K00 ---- K01 ---- K02 ---- K03 ----
- P01 ---- K04 ---- K05 ---- K06 ---- K07 ----
- P02 ---- K08 ---- K09 ---- K10 ---- K11 ----
- P03 ---- K12 ---- K13 ---- K14 ---- K15 ----
- u8 code T_KeyTable[16] = {0,1,2,0,3,0,0,0,4,0,0,0,0,0,0,0};
- void IO_KeyDelay(void)
- u8 i;
- i = 60;
- while(--i) ;
- void IO_KeyScan(void) //50ms call
- u8 j;
- j = IO_KeyState1; //保存上一次狀態(tài)
- P0 = 0xf0; //X低,讀Y
- IO_KeyDelay();
- IO_KeyState1 = P0 & 0xf0;
- P0 = 0x0f; //Y低,讀X
- IO_KeyDelay();
- IO_KeyState1 |= (P0 & 0x0f);
- IO_KeyState1 ^= 0xff; //取反
- if(j == IO_KeyState1) //連續(xù)兩次讀相等
- j = IO_KeyState;
- IO_KeyState = IO_KeyState1;
- if(IO_KeyState != 0) //有鍵按下
- F0 = 0;
- if(j == 0) F0 = 1; //第一次按下
- else if(j == IO_KeyState)
- if(++IO_KeyHoldCnt >= 20) //1秒后重鍵
- IO_KeyHoldCnt = 18;
- F0 = 1;
- if(F0)
- j = T_KeyTable[IO_KeyState >> 4];
- if((j != 0) && (T_KeyTable[IO_KeyState& 0x0f] != 0))
- KeyCode = (j - 1) * 4 + T_KeyTable[IO_KeyState & 0x0f] + 16; //計(jì)算鍵碼,17~32
- else IO_KeyHoldCnt = 0;
- P0 = 0xff;
- /**************** 向HC595發(fā)送一個(gè)字節(jié)函數(shù) ******************/
- void Send_595(u8 dat)
- u8 i;
- dat <<= 1;
- P_HC595_SER = CY;
- P_HC595_SRCLK = 1;
- P_HC595_SRCLK = 0;
- /********************** 顯示掃描函數(shù) ************************/
- void DisplayScan(void)
- Send_595(~T_COM[display_index]); //輸出位碼
- Send_595(t_display[LED8[display_index]]); //輸出段碼
- P_HC595_RCLK = 1;
- P_HC595_RCLK = 0; //所存輸出數(shù)據(jù)
- if(++display_index >= 8) display_index = 0; //8位結(jié)束回0
- /********************** Timer0 1ms中斷函數(shù) ************************/
- void timer0 (void) interrupt TIMER0_VECTOR
- DisplayScan(); //1ms掃描顯示一位
- B_1ms = 1; //1ms標(biāo)志
- void I2C_Delay(void) //for normal MCS51, delay (2 * dly + 4) T, for STC12Cxxxx delay (4 * dly + 10) T
- u8 dly;
- dly = MAIN_Fosc / 2000000UL; //按2us計(jì)算
- while(--dly) ;
- void I2C_Start(void) //start the I2C, SDA High-to-low when SCL is high
- SDA = 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SDA = 0;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- void I2C_Stop(void) //STOP the I2C, SDA Low-to-high when SCL is high
- SDA = 0;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SDA = 1;
- I2C_Delay();
- void S_ACK(void) //Send ACK (LOW)
- SDA = 0;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- void S_NoACK(void) //Send No ACK (High)
- SDA = 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- void I2C_Check_ACK(void) //Check ACK, If F0=0, then right, if F0=1, then error
- SDA = 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- F0 = SDA;
- SCL = 0;
- I2C_Delay();
- void I2C_WriteAbyte(u8 dat) //write a byte to I2C
- u8 i;
- i = 8;
- do
- if(dat & 0x80) SDA = 1;
- else SDA = 0;
- dat <<= 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- while(--i);
- u8 I2C_ReadAbyte(void) //read A byte from I2C
- u8 i,dat;
- i = 8;
- SDA = 1;
- do
- SCL = 1;
電子日歷改良版.zip
(119.07 KB, 下載次數(shù): 14)
2018-1-3 21:01 上傳
點(diǎn)擊文件名下載附件
