80黑幣
我想要能在hours==3,minutes==0(這個(gè)時(shí)間可以在程序中改)的時(shí)候蜂鳴器能響,而且不影響時(shí)間的運(yùn)行。
“void baojing()” 這部分程序運(yùn)行要會(huì)使我時(shí)分秒不能準(zhǔn)確運(yùn)行,直接出現(xiàn)空白。
#include<reg51.h>
#define SEG P2
#define SCANP P1
unsigned int x;
sbit P30=P0^0;
sbit P32=P0^2;
sbit P34=P0^4;
sbit P37=P0^7;
sbit beep=P3^7;
uchar count_T0=0;
uchar code tab[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar disp[8]={0x3f,0x3f,0x40,0x3f,0x3f,0x40,0x3f,0x3f};
uchar scan[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar seconds=0;
uchar minutes=0;
uchar hours=0;
void delayms(uint x)
uint i,j;
for(j=0;j<x;j++)
for(i=0;i<100;i++);
void baojing()
unsigned char x,i;
if(hours==3)
if(minutes==1)
for(i=0;i<500;i++)
for(x=0;x<100;x++);
P37=~P37;
for(i=0;i<250;i++)
for(x=0;x<100;x++);
P37=~P37;
void display()//顯示函數(shù)
uchar i;
baojing();
for(i=0;i<8;i++)
SCANP=scan[i];//送出秒數(shù)段碼
SEG=disp[i];
delayms(8);
TMOD=0x11;
TL0=15536%256;
TH0=15536/526;
IE=0x82;
TR0=1;
EX0=1;
EX1=1;
IT0=1;
IT1=1;
P37=1;
display();
void timer0() interrupt 1
count_T0++;
TL0=45536%256;
TH0=45536/256;
while(count_T0==20)
count_T0=0;
seconds++;
while(seconds==10)
seconds=0;
minutes++;
while(minutes>=5)
minutes=0;
hours++;
while(hours==24)
hours=0;
disp[1]=tab[seconds/10];
disp[0]=tab[seconds%10];
disp[4]=tab[minutes/10];
disp[3]=tab[minutes%10];
disp[7]=tab[hours/10];
disp[6]=tab[hours%10];
void intx0() interrupt 0
if(minutes>=5)
minutes=0;
hours++;
minutes++;
void intx1() interrupt 2
if(hours<24)
hours++;
hours=0;
