要求是兩個(gè)紅外傳感器距離一米,用手觸發(fā)A傳感器啟動(dòng)定時(shí)器計(jì)時(shí),然后再觸發(fā)B傳感器停止計(jì)數(shù),得到時(shí)間,再求速度(路程/時(shí)間)。最后顯示在LCDLCD1602A。
程序如下:
#include<reg52.h>
#include<intrins.h>
#define uint8 unsigned char
#define uint16 unsigned int
#define CMD 0x00
#define DAT 0x01
#define DataPort P0//LCD數(shù)據(jù)口
sbit RW=P2^6;
sbit RS=P2^7;
sbit E=P2^5;
sbit A=P1^0;//傳感器A
sbit N=P2^0;//傳感器B
uint8 CNT=0; //10ms
float speed;
bit flag_1s=0;
uint8 Resust=0;
/**ms級(jí)延時(shí)子程序**/
void delay(uint16 t)
uint16 a;
for(;t>0;t--)
for(a=123;a>0;a--);
/**LCD時(shí)序**/
void write_LCD(uint8 dat,bit rs)
E=0;
RW=0;
RS=rs;//選擇指令or數(shù)據(jù)
_nop_();
_nop_();
_nop_();
E=1;
_nop_();//delay(1);
_nop_();
_nop_();
DataPort=dat;//將數(shù)據(jù)送到LCD數(shù)據(jù)口
_nop_();
_nop_();
_nop_();
E=0;
delay(1);
/**LCD選擇顯示位置子函數(shù)**/
void SetXY(uint8 x,uint8 y)
x=x&0x0f;//防止X、Y 超過量程
y=y&0x01;
if(y)
write_LCD(0x80+x,CMD);
write_LCD(0xc0+x,CMD);
/**速度數(shù)值轉(zhuǎn)換子函數(shù)**/
void disload(uint16 a)
SetXY(3,0);
write_LCD(a*100/100+'0',DAT);//個(gè)位
write_LCD('.',DAT);
write_LCD(a*100%100/10+'0',DAT);//小數(shù)位1
write_LCD(a*100%100%10+'0',DAT);//小數(shù)位2
write_LCD('k',DAT);
write_LCD('m',DAT);
write_LCD('/',DAT);
write_LCD('h',DAT);
/**LCD字符指針函數(shù)**/
void LCD_wrstr(uint8*str)
while(*str!='\0')
write_LCD(*str,DAT);
str++;
/**初始化子程序**/
void All_init()
delay(500);
write_LCD(0x38,CMD);
write_LCD(0x0c,CMD);
write_LCD(0x01,CMD);
delay(10);
SetXY(0,1);//設(shè)置標(biāo)題顯示位置
LCD_wrstr("Tachometer:");
TMOD=0x01;//設(shè)置T0位工作方式1——作為16位定時(shí)器
ET0=1;//打開定時(shí)器0的中斷
TR0=1;//打開定時(shí)器0
TH0=(65536-9216)/256;//裝入初值
TL0=(65536-9216)%256;
IT0=1;//外部中斷0為下降沿中斷
EX0=1;//打開外部中斷
EA=1;//打開總中斷
All_init();//先進(jìn)行初始化
if(flag_1s==1)
flag_1s=0;//1s標(biāo)志位清零
disload(speed);
Timer0Init();
EA=1;
if(A==1)//當(dāng)傳感器a檢測(cè)到時(shí)
CNT=0;//從0開始計(jì)時(shí)
CNT++
if(N==1)//當(dāng)傳感器B檢測(cè)到時(shí)
Resust=CNT; //存儲(chǔ)計(jì)數(shù)結(jié)果
/**定時(shí)器0中斷服務(wù)子程序**/
void timer0() interrupt 1
if(CNT==300)
speed=360/Resust*100;
EX0=0;//關(guān)閉外部中斷0
CNT=0;//定時(shí)1s之后C_50ms清零
flag_1s=1;//1s標(biāo)志位置1
TH0=(65536-9216)/256;//重新初值
