為什么我寫的單片機(jī)控制舵機(jī)轉(zhuǎn)動(dòng)固定角度;求大佬指點(diǎn)下,謝謝。
#include<reg52.h>
sbit SEV_PWM = P0^0;
void ConfigUART(unsigned int baud);
void initTimer0();
unsigned char count = 0;
unsigned char SEV_count = 15;
unsigned char command;
EA=1;
initTimer0();
ConfigUART(9600);
switch(command)
case 'f':
SEV_count++;
if(SEV_count >= 25)
SEV_count = 25;
count=0;
break;
case 'g':
SEV_count--;
if(SEV_count <=5)
SEV_count = 5;
count=0;
break;
case 'k':
SEV_count = 15;
count=0;
break;
default:
break;
void initTimer0()
TMOD=0X01;
TH0 = 0xff;
TL0 = 0xa3;
ET0 = 1;
TR0 = 1;
SCON = 0x50;
TMOD &= 0x0F;
TMOD |= 0x20;
TH1 = 256 - (11059200/12/32)/baud;
TL1 = TH1;
ET1 = 0;
ES = 1;
TR1 = 1;
void Time0_Int() interrupt 1
TH0 = 0xff; //????0.1ms
TL0 = 0xa3;
if(count >= SEV_count) //???????
SEV_PWM = 1;
SEV_PWM = 0;
count++;
if (count >= 200)
count = 0;
void uart_ser() interrupt 4
if (RI)
RI = 0;
command= SBUF;
if(TI)
TI=0;
