查看: 3973|回復(fù): 0
單片機(jī)棋牌游戲仿真設(shè)計(jì) 附源碼和仿真圖
ID:267736 發(fā)表于 2018-1-10 04:08 | 顯示全部樓層 |閱讀模式
棋牌的設(shè)計(jì),附源碼和仿真圖
  1. #include <MSP430f249.h>
  3. #define uint  unsigned int
  4. uchar const led_tab[]={  0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  5.                         0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};   //共陰數(shù)碼管段選碼表,無(wú)小數(shù)點(diǎn)
  6. uchar key;                //按鍵值
  7. uint flag1=0,flag2=0,flag3=0;
  8. void delayus(uint t)
  9. {
  10.   uint i;
  11.   while(t--)
  12.     for(i=1300;i>0;i--);
  13. }
  14. void system_Initial(void)
  15. {
  16.   P3SEL &= 0x00;                                //選擇P3為輸入/輸出口
  17.   P3DIR |= 0XFF;                                //選擇P3為輸出功能
  18.   P3OUT=0xFF;
  19.
  20.   P1DIR = 0xFF;            // 設(shè)置方向?yàn)檩敵?nbsp;
  21.   P4DIR = 0xFF;            // 設(shè)置方向?yàn)檩敵?nbsp;
  22.   P2DIR = BIT0 + BIT1+BIT2+BIT3;
  23.   P1OUT = 0x00;            //LED輸出全部關(guān)閉
  24.   P4OUT = 0x00;            //LED輸出全部關(guān)閉
  25.   P2OUT = BIT0 + BIT1+BIT2+BIT3;
  26.   P2IE |= BIT4+BIT5+BIT6;    //P2.2中斷使能
  27.   P2IES |= BIT4+BIT5+BIT6;   //P2.2下降沿中斷
  28.   P2IFG &=~(BIT4+BIT5+BIT6);  //P2.2清除中斷標(biāo)志
  29.   _EINT();
  30. }
  31. // 端口2中斷服務(wù)程序
  32. #pragma vector=PORT2_VECTOR
  33. __interrupt void Port_2(void)
  34. {
  35.
  36.     P2IFG &= ~(BIT4+BIT5+BIT6);   //清除中斷標(biāo)志
  37. }
  38. //**********************************************************************
  39. int main(void)
  40. {
  41.   uchar i;
  42.   uchar count = 29;          //計(jì)數(shù)值
  43.   uchar disp_buf[4];        //顯示緩沖區(qū)
  44.   WDTCTL = WDTPW + WDTHOLD; // 關(guān)閉看門(mén)狗
  45.   system_Initial();
  46.   while(1)
  47.    {
  48.       if(!(0x10 & P2IN))  {
  49.         flag1=1;
  50.         if(flag2==1)
  51.           count=29;
  52.         flag2=0;
  53.
  54.       }
  55.       if(!(0x20 & P2IN))  {
  56.         flag2=1;
  57.         if(flag1==1)
  58.           count=29;
  59.         flag1=0;
  60.       }
  61.       if(!(0x40 & P2IN))  {
  62.         flag3=1;
  63.       }
  64.
  65.       if(flag1 == 1)
  66.       {
  67.         flag3=0;
  68.         if(count>0)
  69.         {
  70.            disp_buf[1] = count / 10;    //對(duì)計(jì)數(shù)值取十位數(shù)
  71.            disp_buf[0] = count % 10;   //對(duì)計(jì)數(shù)值取個(gè)位數(shù)
  72.            for(i = 0;i < 25; i++) //總共循環(huán)25次,計(jì)時(shí)1s
  73.            {
  74.              P1OUT = 0;
  75.              P1OUT = led_tab[disp_buf[1]];
  76.              P2OUT = ~BIT0; //顯示十位數(shù)
  77.              delayus(2);     //軟件仿真時(shí),取20不閃爍
  78.              P1OUT = 0;
  79.              P1OUT = led_tab[disp_buf[0]];
  80.              P2OUT = ~BIT1; //顯示個(gè)位數(shù)
  81.              delayus(2);     //軟件仿真時(shí),取20不閃爍
  82.            }
  83.            count--;
  84.         }
  85.         if(count==0)
  86.         {
  87.             P1OUT = 0;
  88.             P1OUT = led_tab[0];  //30s倒計(jì)時(shí)結(jié)束,顯示0;
  89.             P2OUT = ~BIT1;
  90.             P3OUT=~BIT1;
  91.         }
  92.       }
  93.
  94.       if(flag2 == 1)
  95.       {
  96.         flag3=0;
  97.         if(count>0)
  98.         {
  99.            disp_buf[3] = count / 10;    //對(duì)計(jì)數(shù)值取十位數(shù)
  100.            disp_buf[2] = count % 10;   //對(duì)計(jì)數(shù)值取個(gè)位數(shù)
  101.            for(i = 0;i < 25; i++) //總共循環(huán)25次,計(jì)時(shí)1s
  102.            {
  103.              P4OUT = 0;
  104.              P4OUT = led_tab[disp_buf[3]];
  105.              P2OUT = ~BIT2; //顯示十位數(shù)
  106.              delayus(2);     //軟件仿真時(shí),取20不閃爍
  107.              P4OUT = 0;
  108.              P4OUT = led_tab[disp_buf[2]];
  109.              P2OUT = ~BIT3; //顯示個(gè)位數(shù)
  110.              delayus(2);     //軟件仿真時(shí),取20不閃爍
  111.            }
  112.            count--;
  113.         }
  114.         if(count==0)
  115.         {
  116.             P4OUT = 0;
  117.             P4OUT = led_tab[0];  //30s倒計(jì)時(shí)結(jié)束,顯示0;
  118.             P2OUT = ~BIT3;
  119.             P3OUT=~BIT0;
  120.         }
  121.       }
  122. ……………………
  123. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
棋牌.rar (152.8 KB, 下載次數(shù): 18)
