我用取字模的方法在屏幕上輸出了四行八列漢字,想請(qǐng)教下各位怎么從右往左滾動(dòng)顯示漢字,謝謝- #include <reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define LCDLCDDisp_Off 0x3e
- #define LCDLCDDisp_On 0x3f
- #define Page_Add 0xb8//ye
- #define LCDCol_Add 0x40//lie
- #define Start_Line 0xC0//hang
- /*****液晶顯示器的端口定義*****/
- #define data_ora P0 /*液晶數(shù)據(jù)總線*/
- sbit LCDMcs=P2^4 ; /*片選1*/
- sbit LCDScs=P2^3 ; /*片選2*/
- sbit LCDDi=P2^2 ; /*數(shù)據(jù)/指令 選擇*/
- sbit LCDRW=P2^1 ; /*讀/寫 選擇*/
- sbit LCDEnable=P2^0 ; /*讀/寫 使能*/
- uchar code hz1[]=
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 源文件 / 文字 : 武
- 寬×高(像素): 16×16
- 字模格式/大小 : 單色點(diǎn)陣液晶字模,縱向取模,字節(jié)倒序/32字節(jié)
- 數(shù)據(jù)轉(zhuǎn)換日期 : 2010-7-31 15:50:18
- 0x20,0x20,0x24,0x24,0x24,0xA4,0x24,0x24,0x20,0xFF,0x20,0x22,0x2C,0x20,0x20,0x00,
- 0x40,0xC0,0x7E,0x40,0x40,0x3F,0x22,0x22,0x20,0x03,0x0C,0x10,0x20,0x40,0xF8,0x00,
- 源文件 / 文字 : 漢
- 寬×高(像素): 16×16
- 數(shù)據(jù)轉(zhuǎn)換日期 : 2010-7-31 15:51:45
- 0x10,0x60,0x02,0x0C,0xC0,0x02,0x1E,0xE2,0x02,0x02,0x02,0xE2,0x1E,0x00,0x00,0x00,
- 0x04,0x04,0x7C,0x03,0x80,0x80,0x40,0x20,0x13,0x0C,0x13,0x20,0x40,0x80,0x80,0x00,
- 源文件 / 文字 : 理
- 寬×高(像素): 16×16
- 數(shù)據(jù)轉(zhuǎn)換日期 : 2010-7-31 15:52:29
- 0x04,0x84,0x84,0xFC,0x84,0x84,0x00,0xFE,0x92,0x92,0xFE,0x92,0x92,0xFE,0x00,0x00,
- 0x20,0x60,0x20,0x1F,0x10,0x10,0x40,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x40,0x00,
- 源文件 / 文字 : 工
- 寬×高(像素): 16×16
- 數(shù)據(jù)轉(zhuǎn)換日期 : 2010-7-31 15:53:19
- 0x00,0x04,0x04,0x04,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x04,0x04,0x04,0x00,0x00,
- 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- 源文件 / 文字 : 大
- 寬×高(像素): 16×16
- 數(shù)據(jù)轉(zhuǎn)換日期 : 2010-7-31 15:53:53
- 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
- 0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00,
- 源文件 / 文字 : 學(xué)
- 寬×高(像素): 16×16
- 數(shù)據(jù)轉(zhuǎn)換日期 : 2010-7-31 15:54:23
- 0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,
- 0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00,
- uchar code hz2[]=
- /*-- 文字: 信 --*/
- /*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
- 0x00,0x80,0x60,0xF8,0x07,0x00,0x04,0x24,0x24,0x25,0x26,0x24,0x24,0x24,0x04,0x00,
- 0x01,0x00,0x00,0xFF,0x00,0x00,0x00,0xF9,0x49,0x49,0x49,0x49,0x49,0xF9,0x00,0x00,
- /*-- 文字: 息 --*/
- 0x00,0x00,0x00,0xFC,0x54,0x54,0x56,0x55,0x54,0x54,0x54,0xFC,0x00,0x00,0x00,0x00,
- 0x40,0x30,0x00,0x03,0x39,0x41,0x41,0x45,0x59,0x41,0x41,0x73,0x00,0x08,0x30,0x00,
- /*-- 文字: 工 --*/
- /*-- 文字: 程 --*/
- 0x24,0x24,0xA4,0xFE,0x23,0x22,0x00,0x3E,0x22,0x22,0x22,0x22,0x22,0x3E,0x00,0x00,
- 0x08,0x06,0x01,0xFF,0x01,0x06,0x40,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,
- /*-- 文字: 學(xué) --*/
- /*-- 文字: 院 --*/
- 0x00,0xFE,0x22,0x5A,0x86,0x10,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x14,0x0C,0x00,
- 0x00,0xFF,0x04,0x08,0x07,0x80,0x41,0x31,0x0F,0x01,0x01,0x3F,0x41,0x41,0x71,0x00,
- uchar code hz3[]=
- /*-- 文字: 通 --*/
- 0x40,0x42,0xCC,0x00,0x00,0xE2,0x22,0x2A,0x2A,0xF2,0x2A,0x26,0x22,0xE0,0x00,0x00,
- 0x80,0x40,0x3F,0x40,0x80,0xFF,0x89,0x89,0x89,0xBF,0x89,0xA9,0xC9,0xBF,0x80,0x00,
- /*-- 文字: 信 --*/
- /*-- 文字: 工 --*/
- /*-- 文字: 程 --*/
- uchar code hz4[]=
- /*-- 文字: 許 --*/
- 0x40,0x40,0x42,0xCC,0x00,0x00,0x20,0x18,0x0F,0x08,0xF8,0x08,0x08,0x08,0x00,0x00,
- 0x00,0x00,0x00,0x7F,0x20,0x10,0x01,0x01,0x01,0x01,0xFF,0x01,0x01,0x01,0x01,0x00,
- /*-- 文字: 萍 --*/
- 0x44,0x84,0x14,0x64,0x0F,0x24,0xA4,0x24,0x24,0xE4,0x2F,0x24,0xA4,0x24,0x04,0x00,
- 0x08,0x09,0x78,0x04,0x03,0x04,0x04,0x05,0x04,0xFF,0x04,0x05,0x04,0x04,0x04,0x00,
- 函數(shù)功能:LCD延時(shí)程序
- 入口參數(shù):t
- 出口參數(shù):
- void LCDdelay(uchar x)
- int d;
- uchar y;
- for(y=0;y<x;y++)
- for(d=0;d<10;d++);
- 狀態(tài)檢查,LCD是否忙
- void CheckState()
- uchar dat,DATA;//狀態(tài)信息(判斷是否忙)
- LCDDi=0; // 數(shù)據(jù)\指令選擇,D/I(RS)="L" ,表示 DB7∽DB0 為顯示指令數(shù)據(jù)
- LCDRW=1; //R/W="H" ,E="H"數(shù)據(jù)被讀到DB7∽DB0
- do
- DATA=0x00;
- LCDEnable=1; //EN下降源
- LCDdelay(1);//延時(shí)
- dat=DATA;
- LCDEnable=0;
- dat=0x80 & dat; //僅當(dāng)?shù)?位為0時(shí)才可操作(判別busy信號(hào))
- while(!(dat==0x00));
- 函數(shù)功能:寫命令到LCD程序,RS(DI)=L,RW=L,EN=H,即來(lái)一個(gè)脈沖寫一次
- 入口參數(shù):cmdcode
- 出口參數(shù):
- void write_com(uchar cmdcode)
- CheckState();//檢測(cè)LCD是否忙
- LCDDi=0;
- LCDRW=0;
- P1=cmdcode;
- LCDdelay(1);
- LCDEnable=1;
- LCDdelay(1);
- LCDEnable=0;
- 函數(shù)功能:寫數(shù)據(jù)到LCD程序,RS(DI)=H,RW=L,EN=H,即來(lái)一個(gè)脈沖寫一次
- 入口參數(shù):LCDDispdata
- 出口參數(shù):
- void write_data(uchar LCDDispdata)
- LCDDi=1;
- LCDRW=0;
- P1=LCDDispdata;
- LCDdelay(1);
- LCDEnable=1;
- LCDdelay(1);
- LCDEnable=0;
- 函數(shù)功能:LCD初始化程序
- 入口參數(shù):
- 出口參數(shù):
- void init_lcd()
- LCDdelay(1);
- LCDMcs=1;//剛開(kāi)始關(guān)閉兩屏
- LCDScs=1;
- LCDdelay(1);
- write_com(LCDLCDDisp_Off); //寫初始化命令
- write_com(Page_Add+0);
- write_com(Start_Line+0);
- write_com(LCDCol_Add+0);
- write_com(LCDLCDDisp_On);
- 函數(shù)功能:清除LCD內(nèi)存程序
- 入口參數(shù):pag,col,hzk
- 出口參數(shù):
- void Clr_Scr()
- uchar j,k;
- LCDMcs=0; //左、右屏均開(kāi)顯示
- LCDScs=0;
- for(k=0;k<8;k++)//控制頁(yè)數(shù)0-7,共8頁(yè)
- write_com(Page_Add+k); //每頁(yè)每頁(yè)進(jìn)行寫
- for(j=0;j<64;j++) //每頁(yè)最多可寫32個(gè)中文文字或64個(gè)ASCII字符
- write_com(LCDCol_Add+j);
- write_data(0x00);//控制列數(shù)0-63,共64列,寫點(diǎn)內(nèi)容,列地址自動(dòng)加1
- 函數(shù)功能:一行一行顯示
- 入口參數(shù):page,column,hzk
- 出口參數(shù):
- Disp(uchar page,uchar column, uchar code *word)
- uchar i;
- //左屏
- LCDMcs=0;
- LCDScs=1;
- //上半字
- write_com(0xb8|page);
- write_com(0x40|column);
- for(i=0;i<16;i++)
- write_data(word[i]);
- for(i=32;i<48;i++)
- for(i=64;i<80;i++)
- for(i=96;i<112;i++)
- //下半字
- write_com(0xb8|page+1);
- for(i=16;i<32;i++)
- for(i=48;i<64;i++)
- for(i=80;i<96;i++)
- for(i=112;i<128;i++)
- //右屏
- LCDMcs=1;
- LCDScs=0;
- //上半字
- write_com(0x40);
- for(i=128;i<144;i++)
- for(i=160;i<176;i++)
- for(i=192;i<208;i++)
- for(i=224;i<240;i++)
- //下半字
- write_com(0x40);
- for(i=144;i<160;i++)
- for(i=176;i<192;i++)
- for(i=208;i<224;i++)
- for(i=240;i<250;i++)
- void main()
- uint k=0;
- init_lcd();
- Clr_Scr();
- k=0;
- for(k=0xc0;k<0xff;k++)
- Disp(0,0,hz1);
- Disp(2,0,hz2);
- Disp(4,0,hz3);
- Disp(6,0,hz4);
- LCDMcs=0;
- LCDScs=0;
- write_com(k);
- LCDdelay(2);
- while(1)
