查看: 1445|回復(fù): 0
單片機(jī)簡(jiǎn)單程序試試發(fā)
ID:276209 發(fā)表于 2018-1-15 15:24 | 顯示全部樓層 |閱讀模式
#include <avr/io.h>
#include <util/delay.h>
//口定義
#define PORT_DHT PORTC
//口方向定義
#define DDR_DHT DDRC
//讀取口定義
#define PIN_DHT PINC
//數(shù)據(jù)位定義
#define BIT_DHT PC4
#define RS PA0 //數(shù)據(jù)/命令控制端 0命令,1 數(shù)據(jù)
#define RW PA1 //讀/寫(xiě)選擇控制端 0寫(xiě),1讀
#define E PA2 //使能端 下降沿讀,高電平寫(xiě)
#define                L_DHT                PORT_DHT&=~(1<<BIT_DHT)                        //數(shù)據(jù)線(xiàn)強(qiáng)制拉低
#define                H_DHT                PORT_DHT|=(1<<BIT_DHT)                                //數(shù)據(jù)線(xiàn)強(qiáng)制拉高
#define                O_DHT                DDR_DHT|=(1<<BIT_DHT)                                //Mega16控制總線(xiàn),PD4為輸出
#define                P_DHT                DDR_DHT&=~(1<<BIT_DHT)                            //釋放總線(xiàn),PD4為輸入
#define                I_DHT                PIN_DHT&(1<<BIT_DHT)                                //數(shù)據(jù)線(xiàn)的狀態(tài)
void LCDPort_Init(void); //液晶端口初始化
void LCD_Init(void); //LCD 初始化
void Write_Com(unsigned char LCD_Com); //LCD 寫(xiě)指令
void Write_Data_Byte(unsigned char LCD_Data); //LCD 寫(xiě)字節(jié)數(shù)據(jù)
void Write_Place_xy(unsigned char x,unsigned char y); //指定當(dāng)前寫(xiě)字符的位置
void Write_Data_String(unsigned char x,unsigned char y,unsigned char *data);//在指定的(x,y)位置上寫(xiě)入字符串?dāng)?shù)據(jù)
void Write_Data_Char(unsigned char x,unsigned char y,unsigned char data);//在指定的(x,y)位置上寫(xiě)入字符數(shù)據(jù)
void Check_Busy(void); //讀寫(xiě)檢測(cè)函數(shù),每次對(duì)液晶操讀作前都要進(jìn)行寫(xiě)檢測(cè)
void Delayus(unsigned int lus); //us延時(shí)函數(shù)
void Delayms(unsigned int lms); //ms延時(shí)函數(shù)
unsigned  Reset()
        O_DHT;
        H_DHT;
        _delay_us(2);
        L_DHT;
        _delay_us(19);
        P_DHT;
        _delay_us(20);
        if(I_DHT)
        return 0;
        return 1;
int main(void)
        _delay_ms(1000);
        unsigned char tdata[5];
        unsigned long u16Flag; // 超時(shí)計(jì)數(shù)
        unsigned char iiii;
        unsigned long u32I; // 接收數(shù)據(jù)臨時(shí)變量
        unsigned long ReceiveValue = 0; // 接收數(shù)據(jù)包變量
        unsigned long ReceiveValue1 = 0; // 接收校驗(yàn)和變量
        unsigned int ReceiveHighByte; // 分解數(shù)據(jù)包 濕度
        unsigned int ReceiveLowByte; // 分解數(shù)據(jù)包溫度
        LCDPort_Init();
        LCD_Init();
        Write_Data_String(0,0,"ddddddd");
        if(Reset())
        {        P_DHT;
                while((!(I_DHT)) && ((u16Flag++)<50000));
                ReceiveValue = 0;
                ReceiveValue1 = 0;
                u16Flag = 0;
                while((I_DHT) && ((u16Flag++)<50000));
                for(u32I=0x80000000; u32I>0; u32I>>=1)
                        u16Flag = 0;
                        while((!(I_DHT))&& ((u16Flag++)<3000));
                        u16Flag = 0;
                        _delay_us(28);
                        if(I_DHT)
                                ReceiveValue |= u32I;
                        while((I_DHT)&&((u16Flag++)<300));
                for(u32I=0x80;u32I>0;u32I>>=1)
                        u16Flag = 0;
                        while((!(I_DHT))&&((u16Flag++)<3000));
                        u16Flag = 0;
                        _delay_us(28);
                        if(I_DHT)
                                ReceiveValue1 |= u32I;
                while(!(I_DHT));
                O_DHT;
                H_DHT;
                ReceiveLowByte =(unsigned int )( ReceiveValue&0x0000FFFF);
                ReceiveHighByte = ReceiveValue>>16;
                /****************************display******************************/
                        tdata[0]=*((unsigned char*)(&ReceiveHighByte) + 1)/10;
                      tdata[1]=*((unsigned char*)(&ReceiveHighByte) + 1)%10;
                      tdata[2]=*((unsigned char*)(&ReceiveLowByte) + 1)/10;
                        tdata[3]=*((unsigned char*)(&ReceiveLowByte) + 1)%10;
                        Write_Com(0xc0);
            Write_Data_Byte( tdata[0]+0x30 );//顯示濕度十位
                        Write_Com(0xc1);
                        Write_Data_Byte( tdata[1]+0x30 );//顯示濕度個(gè)位
                        Write_Com(0xc2);
                //        Write_Data_Byte("%");
                        Write_Com(0xc4);
                        Write_Data_Byte( tdata[2]+0x30 );//顯示溫度十位
                        Write_Com(0xc5);
                        Write_Data_Byte( tdata[3]+0x30 );//顯示溫度個(gè)位
                        Write_Com(0xc6);
                          Write_Data_Byte(0xdf);//顯示"。"
                          Write_Com(0xc7);
                          Write_Data_Byte('C');
void LCDPort_Init()
  //LCD 數(shù)據(jù)端口設(shè)置
  PORTD = 0X00; //
  DDRD = 0XFF; //配置端口PD全部為輸出口,LCD 數(shù)據(jù)端口
  //LCD 控制端口設(shè)置
  PORTA &= ~((1 << RS) | (1 << RW) | (1 << E)); //
  DDRA |= (1 << RS) | (1 << RW) | (1 << E);
//LCD 初始化
void LCD_Init()
Write_Com(0X01); //清屏
Delayms(5);
Write_Com(0X38); //顯示模式設(shè)置 16x2顯示,5x7點(diǎn)陣,8 位數(shù)據(jù)接口
Delayms(5);
//Write_Com(0X0f); //顯示開(kāi)關(guān)控制,開(kāi)顯示,光標(biāo)顯示,光標(biāo)閃爍
Write_Com(0X0c); //顯示開(kāi)關(guān)控制,開(kāi)顯示,光標(biāo)不顯示,光標(biāo)不閃爍
Delayms(5);
Write_Com(0X06); //光標(biāo)設(shè)置,讀或?qū)懸粋(gè)字符后,地址指針加一,光標(biāo)加一,整屏不移動(dòng)
Delayms(5);
//LCD 寫(xiě)指令
Check_Busy();
PORTA &= ~(1 << RS); //RS=0,寫(xiě)命令
PORTA &= ~(1 << RW); //RW=0,寫(xiě)指令
PORTA |= (1 << E); //E=1,寫(xiě)操作
Delayms(1);
PORTD = LCD_Com; //指令送數(shù)據(jù)端口
PORTA &= ~(1 << E); //E=0,停止寫(xiě)操作
Delayms(1);
  Check_Busy();
  PORTA |= (1 << RS); //RS=1,寫(xiě)數(shù)據(jù)
  Delayms(1);
  PORTD = LCD_Data; // 數(shù)據(jù)送數(shù)據(jù)端口
  Delayms(1);
  unsigned char address;
  if(y == 0) //行位置
    address = 0x80 + x; //列位置,
    address = 0x80 + 0x40 + x; //
  Write_Com(address); //寫(xiě)地址
  Write_Place_xy(x,y); //寫(xiě)地址
  while(*data)
   Write_Data_Byte(*data); //寫(xiě)字符串
   data++; //指針地址加1
//在指定的(x,y)位置上寫(xiě)入字符數(shù)據(jù) x列位置,y行位置
  Write_Data_Byte(data); //
//讀寫(xiě)檢測(cè)函數(shù),每次對(duì)液晶操作前都要進(jìn)行讀寫(xiě)檢測(cè)
void Check_Busy()
  DDRD = 0X00; //PB口置為輸入口,準(zhǔn)備讀取數(shù)據(jù)
  PORTA &= ~(1 << RS); //RS=0,讀命令
  PORTA |= (1 << RW); //RW=1,讀指令
  PORTA |= (1 << E); //E=1,使能
  while(0X80 & PIND); //監(jiān)測(cè)忙信號(hào),直到忙信號(hào)為0,才能進(jìn)行讀寫(xiě)操作
  DDRD = 0XFF; //PB口置為輸出口,準(zhǔn)備向端口發(fā)送數(shù)據(jù)
//us級(jí)別的延時(shí)函數(shù)
while(lus--)
   _delay_loop_2(4); //_delay_loop_2(1)是延時(shí)4 個(gè)時(shí)鐘周期,參數(shù)為4 則延時(shí)16
    //個(gè)時(shí)鐘周期,本實(shí)驗(yàn)用16M晶體,則16 個(gè)時(shí)鐘周期為16/16=1us
//ms級(jí)別的延時(shí)函數(shù)
  while(lms--)
   Delayus(1000); //延時(shí)1ms
