查看: 2768|回復: 2
分享一個矩陣控制的51單片機簡單計算器程序,不是很完善,只能進行小于100的運算
ID:276204 發(fā)表于 2018-1-15 15:41 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <stdio.h>
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x80,0x80,0x80,0x80};        //顯示內(nèi)容
uchar hang[]={0xfe,0xfd,0xfb,0xf7};          //第幾行按鍵
void delayms(uint lym);
uint scan(void);                                   //掃描函數(shù)
void suanfa();                                   //傳送數(shù)據(jù)
uchar temp,key,num,num1;
uint i,num3,num2,a,b,c;
        P0=0x00;
                scan();
                suanfa();
uint scan()                                 //按鍵掃描函數(shù)
        for(i=0;i<4;i++)                         //掃描各行
                P3=hang[i];
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delayms(10);
                        temp=P3;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P3;
                                switch(temp)
                                        case 0xbe:key=1;break;                //1
                                        case 0xbd:key=2;break;                //2
                                        case 0xbb:key=3;break;                //3
                                        case 0x77:key=10;break;                                 //+
                                        case 0xde:key=4;break;                //4
                                        case 0xdd:key=5;break;                //5
                                        case 0xdb:key=6;break;                //6
                                        case 0xb7:key=11;break;                                //-
                                        case 0xee:key=7;break;                //7
                                        case 0xed:key=8;break;                //8
                                        case 0xeb:key=9;break;                //9
                                        case 0xd7:key=12;break;             //*
                                        case 0x7e:key=14;break;                                //清0
                                        case 0x7d:key=0;break;                //0
                                        case 0x7b:key=15;break;                                //=
                                        case 0xe7:key=13;break;                                ///
                                        while(temp!=0xf0)
                                                temp=P3;
                                                temp=temp&0xf0;
                                                P0=table[key];                 //顯示
        return key;                                        //返回 key
        uint i,j;
        for(i=lym;i>0;i--)
                for(j=110;j>0;j--);
void suanfa()
                if(key==0||key==1||key==2||key==3||key==4||key==5||key==6||key==7||key==8||key==9)                                                 //判斷0~9是否被按下
                        if(b==1)                                      //某個數(shù)被按下
                                num2=key;                                                //給num2
                                P1=0x01;
                        else                                                       //某個數(shù)被按下
                                num=key;                                            //給num
                                P1=0x01;
                        c++;
                if(key==10||key==11|key==12||key==13)
                        num1=key;                                                  //運算被按下
                        switch(num1)
                                case 10:P1=0x08;a=1;break;                    //+
                                case 11:P1=0x04;a=2;break;                    //-
                                case 12:P1=0x02;a=3;break;                        //*
                                case 13:P1=0x01;a=4;break;                        ///
                        b=1;                                                        //下次按下第2個數(shù)
                if(key==15)
                        switch(a)
                                case 1:num3=num+num2;break;                         //+運算
                                case 2:num3=num-num2;break;                          //-運算
                                case 3:num3=num*num2;break;                                //*運算
                                case 4:num3=num/num2;break;                                 ///運算
                        }                //'{'不能放在下面那個delayms(10)后面,因為break的緣故不會在執(zhí)行下面
                                if(num3<10)
                                        P0=table[num3%10];                                 //個位顯示
                                        P1=0xf1;
                                        delayms(10);
                                else if(num3<100)
                                        P1=0xf1;
                                        P0=table[num3%10];                                 //個位顯示,yu
                                        delayms(10);
                                        P1=0xf2;
                                        P0=table[num3/10];                                 //十位顯示,mo
                                        delayms(10);
                if(key==14)
                        b=0;
                        num=0;
                        num1=0;
                        num2=0;
                        num3=0;                                   //結果
                        P0=0x3f;                           //顯示0
                        P1=0xf1;
參與人數(shù) 2黑幣 +53 收起 理由
會飛的魚687142 + 3
admin + 50 共享資料的黑幣獎勵!
ID:276997 發(fā)表于 2018-1-17 15:42 | 顯示全部樓層
沒有電路圖,這是基于51開發(fā)板的嗎?
ID:276204 發(fā)表于 2018-3-16 10:14 | 顯示全部樓層
會飛的魚687142 發(fā)表于 2018-1-17 15:42
嗯,沒怎么注意消息
