查看: 7921|回復(fù): 4
16×16點(diǎn)陣LED顯示器漢字顯示—基于74HC595和74HC154驅(qū)動(dòng)
點(diǎn)陣LED顯示器結(jié)構(gòu)及漢字字模。設(shè)計(jì)16×16點(diǎn)陣LED顯示器的驅(qū)動(dòng)電路,編寫程序?qū)崿F(xiàn)在16×16點(diǎn)陣LED顯示器上的漢字顯示。16×16點(diǎn)陣LED顯示器可由4塊8×8點(diǎn)陣LED顯示器構(gòu)成。可采用單片機(jī)并行端口、移位寄存器、譯碼器或鎖存器等4種驅(qū)動(dòng)方式中的組合實(shí)現(xiàn)對16×16點(diǎn)陣LED顯示器的驅(qū)動(dòng)
    電路方面主要包括以下3部分。
(a)設(shè)計(jì)單片機(jī)的最小系統(tǒng)(包括復(fù)位電路和外接的晶振電路),并確定相關(guān)元器件參數(shù)。
(b)采用動(dòng)態(tài)驅(qū)動(dòng)的方式,設(shè)計(jì)單片機(jī)并行端口、移位寄存器、譯碼器或鎖存器等與16×16點(diǎn)陣LED顯示器的驅(qū)動(dòng)電路,主要包括控制點(diǎn)陣LED行和列的連線。
(c)采用移位寄存器、譯碼器或鎖存器驅(qū)動(dòng)點(diǎn)陣LED顯示器時(shí),設(shè)計(jì)單片機(jī)與移位寄存器、譯碼器或鎖存器間的控制連線。
  1. #include<regx51.h>
  2. #include<intrins.h>
  4. #define clk P2_5
  5. #define sclk P2_6
  6. #define en P2_4
  7. #define dat P2_7
  8. void hang(uchar a)
  9. {
  10. uchar k;
  11. //p2=0;
  12. //en=1;
  13. for(k=0;k<8;k++)
  14. {
  15. dat=a&0x80;
  16. clk=1;
  17. clk=0;
  18. a<<=1;
  19. }
  20. }
  21. delay1ms(unsigned char m)
  22. {
  23. unsigned char  n;
  24. while(m--)
  25.    {
  26.      for(n=0;n<122;n++);
  27.    }
  28. }
  29. void main(void)
  30. {
  31. uchar i,j,q;
  32. uchar code a[32]=
  33. {0x04,0x00,0x04,0x00,0x0F,0xE0,0x10,0x20,0x20,0x40,0x7F,0xF8,0xA1,0x08,0x21,0x08,
  34. 0x3F,0xF8,0x21,0x08,0x21,0x08,0x3F,0xF8,0x21,0x08,0x01,0x02,0x01,0x02,0x00,0xFE,};
  35. uchar code b[32]=
  36. {0x00,0x08,0x20,0x3C,0x17,0xC0,0x14,0x00,0x84,0x1C,0x45,0xE0,0x45,0x20,0x15,0x22,
  37. 0x15,0x24,0x25,0x28,0xE5,0x10,0x25,0x10,0x25,0x08,0x29,0x44,0x29,0x82,0x11,0x00,};
  38. uchar code c[32]=
  39. {0x10,0x00,0x10,0x00,0x3F,0xFC,0x20,0x00,0x4F,0xF0,0x80,0x00,0x3F,0xF0,0x00,0x10,
  40. 0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x0A,0x00,0x0A,0x00,0x06,0x00,0x02,};
  41. uchar code d[32]=
  42. {0x00,0x40,0x00,0x40,0x00,0x40,0xFE,0x40,0x11,0xFC,0x10,0x44,0x10,0x44,0x10,0x44,
  43. 0x10,0x44,0x10,0x84,0x10,0x84,0x1E,0x84,0xF1,0x04,0x41,0x04,0x02,0x28,0x04,0x10,};
  44. while(1)
  45. {
  46. P2=0;
  47. en=1;
  48. for(j=0;j<62;j++)
  49. {
  50.          for(i=0;i<32;i=i+2)
  51.          {
  52.                  hang(a[i]);
  53.                  hang(a[i+1]);
  54.                  q=(31-i)/2;
  55.                  P2=P2&0xf0;
  56.                  P2=P2|q;
  57.                  sclk=1;
  58.                  sclk=0;
  59.                  delay1ms(1);
  60.          }
  61. }
  62. for(j=0;j<62;j++)
  63. {
  64. for(i=0;i<32;i=i+2)
  65. {
  66. hang(b[i]);
  67. hang(b[i+1]);
  68. q=(31-i)/2;
  69. P2=P2&0xf0;
  70. P2=P2|q;
  71. sclk=1;
  72. sclk=0;
  73. delay1ms(1);
  74. }
  75. }
  76. for(j=0;j<62;j++)
  77. {
  78. for(i=0;i<32;i=i+2)
  79. {
  80. hang(c[i]);
  81. hang(c[i+1]);
  82. q=(31-i)/2;
  83. P2=P2&0xf0;
  84. P2=P2|q;
  85. sclk=1;
  86. sclk=0;
  87. delay1ms(1);
  88. }
  89. }
  90. for(j=0;j<62;j++)
  91. ……………………
  92. …………限于本文篇幅 余下代碼請從51黑下載附件…………
16×16點(diǎn)陣LED顯示器漢字顯示——基于74HC595和74HC154驅(qū)動(dòng).rar (52.25 KB, 下載次數(shù): 210)
收藏收藏5 分享淘帖 頂1 踩
ID:774176 發(fā)表于 2020-6-9 17:10 | 只看該作者
感謝貼主
ID:644517 發(fā)表于 2019-11-18 19:16 | 只看該作者
很好的東西 很有用
ID:456928 發(fā)表于 2018-12-28 13:21 | 只看該作者
很好的東西 很有用
ID:302391 發(fā)表于 2018-4-7 16:42 | 只看該作者
好資料,51黑有你更精彩!!!
