給需要采用DM1000的朋友提供一個參考
全部資料51hei下載地址:
evk_sw_package_arm3.05_pc3.05c.zip
(5.73 MB, 下載次數(shù): 14)
2018-1-16 21:40 上傳
點擊文件名下載附件
單片機源程序如下:
- * @file main.c
- * @brief main loop for the DecaRanging application
- * @attention
- * Copyright 2013 (c) DecaWave Ltd, Dublin, Ireland.
- * All rights reserved.
- * @author DecaWave
- /* Includes */
- #include "compiler.h"
- #include "port.h"
- #include "instance.h"
- #include "deca_types.h"
- #include "deca_spi.h"
- #include "stdio.h"
- extern void usb_run(void);
- extern int usb_init(void);
- extern void usb_printconfig(int, uint8*, int);
- extern void send_usbmessage(uint8*, int);
- #define DWINTERRUPT_EN (1) //set to 1 when using DW interrupt, set to 0 to poll DW1000 IRQ line
- #define SOFTWARE_VER_STRING "Version 3.05 " //
- #define SWS1_SRM_MODE 0x80 //slow ranging mode with PC - response is configurable and > 150 ms
- #define SWS1_ANC_MODE 0x08 //anchor mode
- #define SWS1_SHF_MODE 0x10 //short frame mode (6.81M) (switch S1-5)
- #define SWS1_64M_MODE 0x20 // 64M PRF mode (switch S1-6)
- #define SWS1_CH5_MODE 0x40 //channel 5 mode (switch S1-7)
- int instance_anchaddr = 0; //0 = 0xDECA020000000001; 1 = 0xDECA020000000002; 2 = 0xDECA020000000003
- //NOTE: switches TA_SW1_7 and TA_SW1_8 are used to set tag/anchor address
- int dr_mode = 0;
- //if instance_mode = TAG_TDOA then the device cannot be selected as anchor
- int instance_mode = ANCHOR;
- //int instance_mode = TAG;
- //int instance_mode = TAG_TDOA;
- //int instance_mode = LISTENER;
- uint8 s1switch = 0;
- int chan, tagaddr, ancaddr;
- #define LCD_BUFF_LEN (100)
- uint8 dataseq[LCD_BUFF_LEN];
- uint8 dataseq1[LCD_BUFF_LEN];
- int ranging = 0;
- typedef struct
- uint8 channel ;
- uint8 prf ;
- uint8 datarate ;
- uint8 preambleCode ;
- uint8 preambleLength ;
- uint8 pacSize ;
- uint8 nsSFD ;
- uint16 sfdTO ;
- } chConfig_t ;
- //Configuration for DecaRanging Modes (8 default use cases selectable by the switch S1 on EVK)
- chConfig_t chConfig[8] ={
- //mode 1 - S1: 7 off, 6 off, 5 off
- 2, // channel
- DWT_PRF_16M, // prf
- DWT_BR_110K, // datarate
- 3, // preambleCode
- DWT_PLEN_1024, // preambleLength
- DWT_PAC32, // pacSize
- 1, // non-standard SFD
- (1025 + 64 - 32) //SFD timeout
- //mode 2
- 2, // channel
- DWT_BR_6M8, // datarate
- DWT_PLEN_128, // preambleLength
- DWT_PAC8, // pacSize
- 0, // non-standard SFD
- (129 + 8 - 8) //SFD timeout
- //mode 3
- 2, // channel
- DWT_PRF_64M, // prf
- 9, // preambleCode
- //mode 4
- 2, // channel
- //mode 5
- 5, // channel
- //mode 6
- 5, // channel
- //mode 7
- 5, // channel
- //mode 8
- 5, // channel
- uint32 inittestapplication(uint8 s1switch);
- // Restart and re-configure
- void restartinstance(void)
- instance_close() ; //shut down instance, PHY, SPI close, etc.
- spi_peripheral_init(); //re initialise SPI...
- inittestapplication(s1switch) ; //re-initialise instance/device
- } // end restartinstance()
- //NOTE: Channel 5 is not supported for the non-discovery mode
- int decarangingmode(uint8 s1switch)
- int mode = 0;
- if(s1switch & SWS1_SHF_MODE)
- mode = 1;
- if(s1switch & SWS1_64M_MODE)
- mode = mode + 2;
- if(s1switch & SWS1_CH5_MODE)
- mode = mode + 4;
- return mode;
- uint32 devID ;
- instanceConfig_t instConfig;
- int result;
- SPI_ConfigFastRate(SPI_BaudRatePrescaler_32); //max SPI before PLLs configured is ~4M
- //this is called here to wake up the device (i.e. if it was in sleep mode before the restart)
- devID = instancereaddeviceid() ;
- if(DWT_DEVICE_ID != devID) //if the read of device ID fails, the DW1000 could be asleep
- port_SPIx_clear_chip_select(); //CS low
- Sleep(1); //200 us to wake up then waits 5ms for DW1000 XTAL to stabilise
- port_SPIx_set_chip_select(); //CS high
- Sleep(7);
- // SPI not working or Unsupported Device ID
- return(-1) ;
- //clear the sleep bit - so that after the hard reset below the DW does not go into sleep
- dwt_softreset();
- //reset the DW1000 by driving the RSTn line low
- reset_DW1000();
- result = instance_init() ;
- if (0 > result) return(-1) ; // Some failure has occurred
- SPI_ConfigFastRate(SPI_BaudRatePrescaler_4); //increase SPI to max
- if (DWT_DEVICE_ID != devID) // Means it is NOT MP device
- return(-1) ;
- if(s1switch & SWS1_ANC_MODE)
- instance_mode = ANCHOR;
- led_on(LED_PC6);
- else
- instance_mode = TAG;
- led_on(LED_PC7);
- instancesetrole(instance_mode) ; // Set this instance role
- instance_init_s(instance_mode);
- dr_mode = decarangingmode(s1switch);
- instConfig.channelNumber = chConfig[dr_mode].channel ;
- instConfig.preambleCode = chConfig[dr_mode].preambleCode ;
- instConfig.pulseRepFreq = chConfig[dr_mode].prf ;
- instConfig.pacSize = chConfig[dr_mode].pacSize ;
- instConfig.nsSFD = chConfig[dr_mode].nsSFD ;
- instConfig.sfdTO = chConfig[dr_mode].sfdTO ;
- instConfig.dataRate = chConfig[dr_mode].datarate ;
- instConfig.preambleLen = chConfig[dr_mode].preambleLength ;
- instance_config(&instConfig) ; // Set operating channel etc
- instancesettagsleepdelay(POLL_SLEEP_DELAY, BLINK_SLEEP_DELAY); //set the Tag sleep time
- instance_init_timings();
- return devID;
- ** Abstract: main program
- void process_dwRSTn_irq(void)
- instance_notify_DW1000_inIDLE(1);
- #if (DWINTERRUPT_EN == 1)
- void process_deca_irq(void)
- do{
- instance_process_irq(0);
- }while(port_CheckEXT_IRQ() == 1); //while IRQ line active (ARM can only do edge sensitive interrupts)
- #else
- while(dwt_checkIRQ() == 1)
- } //while IRQ line active
- #endif
- void initLCD(void)
- uint8 initseq[9] = { 0x39, 0x14, 0x55, 0x6D, 0x78, 0x38 /*0x3C*/, 0x0C, 0x01, 0x06 };
- uint8 command = 0x0;
- int j = 100000;
- writetoLCD( 9, 0, initseq); //init seq
- while(j--);
- command = 0x2 ; //return cursor home
- writetoLCD( 1, 0, &command);
- command = 0x1 ; //clear screen
- * @brief switch_mask - bitmask of testing switches (currently 7 switches)
- * switchbuff[] - switch name to test
- * *switch_fn[]() - corresponded to switch test function
- #define switch_mask (0x7F)
- const uint8 switchbuf[]={0, TA_SW1_3 , TA_SW1_4 , TA_SW1_5 , TA_SW1_6 , TA_SW1_7 , TA_SW1_8 };
- typedef int (* switch_handler_t)(uint16) ;
- const switch_handler_t switch_fn[] ={ is_button_low, \
- is_switch_on, is_switch_on, is_switch_on,\
- is_switch_on, is_switch_on, is_switch_on };
- * @fn test_application_run
- * @brief test application for production pre-test procedure
- void test_application_run(void)
- char dataseq[2][40];
- uint8 j, switchStateOn, switchStateOff;
- switchStateOn=0;
- switchStateOff=0;
- led_on(LED_ALL); // show all LED OK
- Sleep(1000);
- dataseq[0][0] = 0x1 ; //clear screen
- writetoLCD( 1, 0, (const uint8 *) &dataseq);
- dataseq[0][0] = 0x2 ; //return cursor home
- /* testing SPI to DW1000*/
- writetoLCD( 40, 1, (const uint8 *) "TESTING ");
- writetoLCD( 40, 1, (const uint8 *) "SPI, U2, S2, S3 ");
- Sleep(1000);
- if(inittestapplication(s1switch) == (uint32)-1)
- writetoLCD( 40, 1, (const uint8 *) "-- TEST FAILS --");
- while(1); //stop
- writetoLCD( 40, 1, (const uint8 *) " TEST OK ");
- Sleep(1000);
- /* testing of switch S2 */
- while( (switchStateOn & switchStateOff) != switch_mask )
- memset(&dataseq, ' ', sizeof(dataseq));
- strcpy(&dataseq[0][0], (const char *)"SWITCH");
- strcpy(&dataseq[1][0], (const char *)"toggle");
- //switch 7-1
- for (j=0;j<sizeof(switchbuf);j++)
- if( switch_fn[j](switchbuf[j]) ) //execute current switch switch_fn
- dataseq[0][8+j]='O';
- switchStateOn |= 0x01<<j;
- switchStateOff &= ~(0x01<<j);//all switches finaly should be in off state
- }else{
- dataseq[1][8+j]='O';
- switchStateOff |=0x01<<j;
- writetoLCD(40, 1, (const uint8 *) &dataseq[0][0]);
- writetoLCD(40, 1, (const uint8 *) &dataseq[1][0]);
- Sleep(100);
- led_off(LED_ALL);
- writetoLCD( 40, 1, (const uint8 *) " Preliminary ");
- writetoLCD( 40, 1, (const uint8 *) " TEST OKAY ");
- while(1);
- void setLCDline1(uint8 s1switch)
- uint8 command = 0x2 ; //return cursor home
- sprintf((char*)&dataseq[0], "DecaRanging %02x", s1switch);
- writetoLCD( 40, 1, dataseq); //send some data
- sprintf((char*)&dataseq1[0], " ");
- writetoLCD( 16, 1, dataseq1); //send some data
- * @fn main()
- * @brief main entry point
- int main(void)
- int i = 0;
- int toggle = 1;
- double range_result = 0;
- double avg_result = 0;
- led_off(LED_ALL); //turn off all the LEDs
- peripherals_init();
- Sleep(1000); //wait for LCD to power on
- initLCD();
- memset(dataseq, 0, LCD_BUFF_LEN);
- memcpy(dataseq, (const uint8 *) "DECAWAVE ", 16);
- memcpy(dataseq, (const uint8 *) SOFTWARE_VER_STRING, 16); // Also set at line #26 (Should make this from single value !!!)
- writetoLCD( 16, 1, dataseq); //send some data
- Sleep(1000);
- #ifdef USB_SUPPORT
- // enable the USB functionality
- usb_init();
- Sleep(1000);
- #endif
- s1switch = is_button_low(0) << 1 // is_switch_on(TA_SW1_2) << 2
- | is_switch_on(TA_SW1_3) << 2
- | is_switch_on(TA_SW1_4) << 3
- | is_switch_on(TA_SW1_5) << 4
- | is_switch_on(TA_SW1_6) << 5
- | is_switch_on(TA_SW1_7) << 6
- | is_switch_on(TA_SW1_8) << 7;
- port_DisableEXT_IRQ(); //disable ScenSor IRQ until we configure the device
- //test EVB1000 - used in EVK1000 production
- if((is_button_low(0) == S1_SWITCH_ON) && (is_switch_on(TA_SW1_8) == S1_SWITCH_ON)) //using BOOT1 switch for test
- test_application_run(); //does not return....
- else
- if(is_switch_on(TA_SW1_3) == S1_SWITCH_OFF)
- int j = 1000000;
- uint8 command;
- while(j--);
- //command = 0x1 ; //clear screen
- //writetoLCD( 1, 0, &command);
- memcpy(dataseq, (const uint8 *) "DECAWAVE ", 12);
- #ifdef USB_SUPPORT //this is set in the port.h file
- memcpy(dataseq, (const uint8 *) "USB to SPI ", 12);
- #else
- #endif
- j = 1000000;
- while(j--);
- //usb_init();
- NVIC_DisableDECAIRQ();
- // Do nothing in foreground -- allow USB application to run, I guess on the basis of USB interrupts?
- while (1) // loop forever
- usb_run();
- #endif
- return 1;
- else //run DecaRanging application
- memset(dataseq, ' ', LCD_BUFF_LEN);
- memcpy(dataseq, (const uint8 *) "DECAWAVE RANGE", 15);
- writetoLCD( 15, 1, dataseq); //send some data
- led_off(LED_ALL);
- usb_printconfig(16, (uint8 *)SOFTWARE_VER_STRING, s1switch);
- #endif
- led_on(LED_ALL); //to display error....
- dataseq[0] = 0x2 ; //return cursor home
- writetoLCD( 1, 0, &dataseq[0]);
- memcpy(dataseq, (const uint8 *) "ERROR ", 12);
- memcpy(dataseq, (const uint8 *) " INIT FAIL ", 12);
- return 0; //error
復制代碼
