STM32 12通道采集程序
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "adc.h"
- //ALIENTEK 探索者STM32F407開(kāi)發(fā)板 實(shí)驗(yàn)18
- //ADC模數(shù)轉(zhuǎn)換實(shí)驗(yàn)-庫(kù)函數(shù)版本
- extern __IO uint16_t ADC1ConvertedValue[10][12];
- __IO uint32_t ADC1ConvertedVoltage[12];
- int main(void)
- u8 i;
- u8 j;
- u8 k;
- float temp[12];
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
- delay_init(); //初始化延時(shí)函數(shù)
- uart_init(115200); //初始化串口波特率為115200
- LED_Init(); //初始化LED
- LCD_Init(); //初始化LCD接口
- Adc_Init(); //初始化ADC
- POINT_COLOR=RED;
- LCD_ShowString(200,70,200,16,24,"UESTC");
- POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
- LCD_ShowString(160,130,200,16,16,"ADC1_CH00_VAL:");
- LCD_ShowString(160,150,200,16,16,"ADC1_CH00_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,170,200,16,16,"ADC1_CH01_VAL:");
- LCD_ShowString(160,190,200,16,16,"ADC1_CH01_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,210,200,16,16,"ADC1_CH02_VAL:");
- LCD_ShowString(160,230,200,16,16,"ADC1_CH02_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,250,200,16,16,"ADC1_CH03_VAL:");
- LCD_ShowString(160,270,200,16,16,"ADC1_CH03_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,290,200,16,16,"ADC1_CH04_VAL:");
- LCD_ShowString(160,310,200,16,16,"ADC1_CH04_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,330,200,16,16,"ADC1_CH05_VAL:");
- LCD_ShowString(160,350,200,16,16,"ADC1_CH05_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,370,200,16,16,"ADC1_CH06_VAL:");
- LCD_ShowString(160,390,200,16,16,"ADC1_CH06_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,410,200,16,16,"ADC1_CH07_VAL:");
- LCD_ShowString(160,430,200,16,16,"ADC1_CH07_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,450,200,16,16,"ADC1_CH09_VAL:");
- LCD_ShowString(160,470,200,16,16,"ADC1_CH09_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,490,200,16,16,"ADC1_CH10_VAL:");
- LCD_ShowString(160,510,200,16,16,"ADC1_CH10_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,530,200,16,16,"ADC1_CH11_VAL:");
- LCD_ShowString(160,550,200,16,16,"ADC1_CH11_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- LCD_ShowString(160,570,200,16,16,"ADC1_CH12_VAL:");
- LCD_ShowString(160,590,200,16,16,"ADC1_CH12_VOL:0.000V"); //先在固定位置顯示小數(shù)點(diǎn)
- while(1)
- ADC1ConvertedVoltage[0] = 0;
- for(i=0;i<12;i++)
- ADC1ConvertedVoltage[i] = 0;
- for(j=0;j<10;j++)
- ADC1ConvertedVoltage[i]+= ADC1ConvertedValue[j][i];
- ADC1ConvertedVoltage[i] = ADC1ConvertedVoltage[i]/10;
- for(k=0;k<12;k++)
- temp[k] = ADC1ConvertedVoltage[k]*3.3/4096;
- LCD_ShowxNum(272,130+40*k,ADC1ConvertedVoltage[k],4,16,0); //顯示ADCC采樣后的原始值
- i=temp[k]; //賦值整數(shù)部分給adcx變量,因?yàn)閍dcx為u16整形
- LCD_ShowxNum(272,150+40*k,i,1,16,0); //顯示電壓值的整數(shù)部分,3.1111的話(huà),這里就是顯示3
- temp[k]-=i; //把已經(jīng)顯示的整數(shù)部分去掉,留下小數(shù)部分,比如3.1111-3=0.1111
- temp[k]*=1000; //小數(shù)部分乘以1000,例如:0.1111就轉(zhuǎn)換為111.1,相當(dāng)于保留三位小數(shù)。
- LCD_ShowxNum(288,150+40*k,temp[k],3,16,0X80); //顯示小數(shù)部分(前面轉(zhuǎn)換為了整形顯示),這里顯示的就是111.
- /*LCD_ShowxNum(264,170,ADC1ConvertedVoltage[1],4,16,0); //顯示ADCC采樣后的原始值
- i=temp2; //賦值整數(shù)部分給adcx變量,因?yàn)閍dcx為u16整形
- LCD_ShowxNum(264,190,i,1,16,0); //顯示電壓值的整數(shù)部分,3.1111的話(huà),這里就是顯示3
- temp2-=i; //把已經(jīng)顯示的整數(shù)部分去掉,留下小數(shù)部分,比如3.1111-3=0.1111
- temp2*=1000; //小數(shù)部分乘以1000,例如:0.1111就轉(zhuǎn)換為111.1,相當(dāng)于保留三位小數(shù)。
- LCD_ShowxNum(280,190,temp2,3,16,0X80); //顯示小數(shù)部分(前面轉(zhuǎn)換為了整形顯示),這里顯示的就是111.
- LED0=!LED0;
- delay_ms(1000);
12通道ADC_DMA -.rar
(361.7 KB, 下載次數(shù): 33)
2018-1-17 02:13 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
