功能:通過溫度傳感和煙霧傳感器側(cè)得溫度和煙霧或者可燃?xì)怏w濃度經(jīng)過無線通信傳輸給另一個(gè)單片機(jī),另一個(gè)單片機(jī)對(duì)數(shù)據(jù)進(jìn)行計(jì)算判斷顯示溫度、煙霧濃度和安全等級(jí)(安全等級(jí)從1-3)
關(guān)鍵模塊:24L01 MQ-2 LCD1602 18B20 STC12C5A60S2
2018-1-18 17:47 上傳
2018-1-18 17:47 上傳
2018-1-18 17:48 上傳
單片機(jī)源程序如下(接受部分):
- #include <reg51.h>
- #include "def.h"
- #include "sbits.h"
- #include "TC1602AFC.h"
- #include "beep.h"
- #define uchar unsigned char
- #define uint unsigned int
- uchar r1,r2,r3,r4;
- uchar RxBuf[3];
- void main()
- uchar a,b,c,d,e,f,g;
- beep=1;
- lcd_init();
- init_NRF24L01();
- write_charstr( 0 , 1 , "TEMP " );
- write_charstr( 6 , 1 , "DENS " );
- write_charstr( 11 , 1 , "GRADE" );
- while(1)
- SetRX_Mode();
- if(nRF24L01_RxPacket(RxBuf))
- r1=RxBuf[0]; // 溫度
- r2=RxBuf[1]; // 煙霧/氣體濃度百位千位
- r3=RxBuf[2]; // 煙霧/氣體濃度個(gè)位十?
- a=r1/100;
- b=r1%100/10;
- c=r1%10;
- d=r2/10;
- e=r2%10;
- f=r3/10;
- g=r3%10;
- write_char( 1 , 2 ,a );
- write_char( 2 , 2 ,b );
- write_char( 3 , 2 ,c );
- write_char( 6 , 2 ,d );
- write_char( 7 , 2 ,e );
- write_char( 8 , 2 ,f );
- write_char( 9 , 2 ,g );
- fengming();
復(fù)制代碼 發(fā)送部分的源程序:
- #include"defines.h"
- #include "18b20.h"
- #include "def.h"
- #include "60s2ad.h"
- #include "mq2.h"
- uchar TxBuf[3];
- extern uint ppm; //濃度單位 用于表示濃度
- extern uint vol; //采集的電壓值
- extern uchar warning; //警告標(biāo)志位
- uchar a,b,c;
- void main()
- double temp;
- ppm=0;
- INputchange(0x01); //用的是P1.0端口
- beep=1;
- ppm=0;
- vol=0;
- init_NRF24L01() ;
- nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data
- Delay3(6000);
- while(1)
- temp=ReadTemperature();
- temp=temp*0.0625;
- a=(int)temp*10/10;
- value_TTL();
- value_analog();
- b=ppm/100;
- c=ppm%100;
- TxBuf[0]=a; //溫度
- TxBuf[1]=b; // 煙霧/氣體濃度百位千位
- TxBuf[2]=c; // 煙霧/氣體濃度個(gè)位十位
- Delay3(20000);
- SPI_RW_Reg(WRITE_REG+STATUS,0XFF);//clear RX_DR or TX_DS or MAX_RT interrupt
MQ-2.pdf
2018-1-18 13:33 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
150.27 KB, 下載次數(shù): 133, 下載積分: 黑幣 -5
STC12C5A60S2單片機(jī)的AD轉(zhuǎn)換(8位).pdf
2018-1-18 13:33 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
276.16 KB, 下載次數(shù): 96, 下載積分: 黑幣 -5
接受.rar
2018-1-18 13:32 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
7.85 MB, 下載次數(shù): 136, 下載積分: 黑幣 -5
發(fā)送.rar
2018-1-18 13:32 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
7.85 MB, 下載次數(shù): 116, 下載積分: 黑幣 -5
接收程序.rar
2018-1-18 13:27 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
47.94 KB, 下載次數(shù): 103, 下載積分: 黑幣 -5
發(fā)送程序.rar
2018-1-18 13:27 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
60.44 KB, 下載次數(shù): 114, 下載積分: 黑幣 -5
