查看: 2729|回復: 6
求助51單片機紅外遙控模塊
ID:265318 發(fā)表于 2018-1-21 10:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
買的單片機自帶的有紅外遙控視頻,但是聽的我一頭霧水。有沒有已經(jīng)做過紅外遙控的大佬教導我一下。
ID:46999 發(fā)表于 2018-1-21 11:52 | 只看該作者
本帖最后由 維超 于 2018-1-21 12:02 編輯
給個自適應的紅外解碼實例你參考吧(非本人原創(chuàng),資料來自網(wǎng)絡,感謝分享的大俠)
#include "INC\STC89C52RC.H"
#include "INC\MY_SET.H"
#include "INC\IR_NEC.H"                   //調(diào)用NEC解碼頭文件
sfr   SE   = 0x80;             //數(shù)碼管段選 P0:0x80   P1:0x90
sbit  WX1  = P2^0;                           //數(shù)碼管位顯
sbit  WX2  = P2^1;
sbit  WX3  = P2^2;
sbit  WX4  = P2^3;
sbit  WX5  = P2^4;
sbit  WX6  = P2^5;
sbit  WX7  = P2^6;
sbit  WX8  = P2^7;
uint8c tab[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0X88,0X83,0XC6,0XA1,0X86,0X8E,0xFF};
uint8  Xn,X1,X2,X3,X4,X5,X6;
void KZ0();      //短按處理
void KZ1();      //長按處理
/***************** 主函數(shù) ********************/
void main(void)
        IR_Init();                           //紅外線解碼初始化
          //遙控檢測
          if((IR_BT==2)||(IR_BT==3))
                if(IR_BT==2)KZ0();      //短按處理
                 else        KZ1();      //長按處理
                IR_BT =0;                        //清有效標志
                X1 = NEC[0]/16;                   //更新顯示
                X2 = NEC[0]%16;
                X3 = NEC[1]/16;
                X4 = NEC[1]%16;
                X5 = NEC[2]/16;
                X6 = NEC[2]%16;
函數(shù):遙控短按處理
void KZ0()
   switch(NEC[2])
      case 0x12: P10 = !P10; break;
          case 0x05: break;
          case 0x1E: break;
          case 0x55: break;
          case 0x01: break;
          case 0x1B: break;
          case 0x03: break;
          case 0x6B: break;
          case 0x07: break;
          case 0x08: break;
          case 0x09: break;
          case 0x68: break;
          case 0x22: break;
          case 0xE6: break;
          case 0x33: break;
          case 0xE2: break;
          default:break;
函數(shù):遙控長按處理
void KZ1()
   switch(NEC[2])
      case 0x12: P14 = !P14; break;
          case 0x05: break;
          case 0x1E: break;
          case 0x55: break;
          case 0x01: break;
          case 0x1B: break;
          case 0x03: break;
          case 0x6B: break;
          case 0x07: break;
          case 0x08: break;
          case 0x09: break;
          case 0x68: break;
          case 0x22: break;
          case 0xE6: break;
          case 0x33: break;
          case 0xE2: break;
          default:break;
/*********************數(shù)碼管掃描*************************/
void XS(void)
  if(++Xn > 7)Xn=0;
  switch(Xn)
         case 0: WX8=1;        NOP;                                        //屏蔽上個位顯
                 SE=tab[X1];                                        //送段碼
                         WX1=0;                                                        //開位顯
                         break;
     case 1: WX1=1; NOP; SE=tab[X2]; WX2=0; break;
     case 2: WX2=1; NOP; SE=tab[X3]; WX3=0; break;
         case 3: WX3=1; NOP; SE=tab[X4]; WX4=0; break;
         case 4: WX4=1; NOP; SE=tab[16]; WX5=0; break;
         case 5: WX5=1; NOP; SE=tab[16]; WX6=0; break;
         case 6: WX6=1; NOP; SE=tab[X5]; WX7=0; break;
         case 7: WX7=1; NOP; SE=tab[X6]; WX8=0; break;
         default:break;
/********************** 定時器0中斷函數(shù)************************/
void time0(void) interrupt 1
   IR_NEC();
   XS();
}   紅外線NEC解碼.rar (53.47 KB, 下載次數(shù): 13)
ID:96682 發(fā)表于 2018-1-21 12:42 | 只看該作者
看著視頻還得跟著有樣學樣才行,好不好呢要看教和學兩者之間水平了。
社會上的維修店面一般都有招學徒工的,雖然不能系統(tǒng)的學習但干這活的理解能力也不會太差
ID:247467 發(fā)表于 2018-1-21 14:31 | 只看該作者
這個得自看著資料慢慢學習,多看幾遍,要自己動手體會,這樣是效果最好的
ID:265318 發(fā)表于 2018-1-22 11:25 | 只看該作者
wc86110 發(fā)表于 2018-1-21 12:42
社會上的維修店面一般都有招學徒工的 ...
emmm這個還在上學,當學徒可能有點困難
ID:265318 發(fā)表于 2018-1-22 11:26 | 只看該作者
天下1213 發(fā)表于 2018-1-21 14:31
就是倒在了動手的道路上
維超 發(fā)表于 2018-1-21 11:52
#include "INC\STC89C52 ...
