查看: 2144|回復(fù): 0
舵機(jī)自動(dòng)旋轉(zhuǎn)源代碼
ID:279205 發(fā)表于 2018-1-24 11:25 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
sbit R_Key = P3 ^ 4;
sbit L_Key = P3 ^ 5;
sbit PWM_OUT = P3 ^ 6;
bit OUT;
unsigned char SG1;
void DELAY_MS (unsigned int a)
   unsigned int i;
   while( a-- != 0)
for(i = 0; i < 600; i++);
void T_C_init (void)
  TMOD = 0x11;
EA = 1;
TH0 = 0xFF;
TL0 = 0xF5;
ET0 = 1;
TR0 = 1;
void T_C0 (void) interrupt 1  using 1
unsigned int a;
if(OUT==0)
a= 0x0A*SG1+0x01F3;
a= 0xFFFF - a;
TH0 = a/0xFF;
TL0 = a%0xFF;
OUT = 1;
PWM_OUT=1;
Else
a= 0x4E1F - (0x0A*SG1+0x01F3);
a= 0xFFFF - a;
TH0 = a/0xFF;
TL0 = a%0xFF;
OUT = 0;
PWM_OUT=0;
void main (void)
P3M0 = 0x60;
P3M1 = 0x00;
DELAY_MS (500);
T_C_init ();
SG1=15;
{ SG1=12;
DELAY_MS (60);
SG1=18;
DELAY_MS (60);
