基于STC15W4K32S4的智能小車測速程序,測速使用光電碼盤,顯示采用諾基亞5110液晶屏
單片機源程序如下:
- #include "nokia_5110.h"
- #include "timer.h"
- #include "Exti.h"
- #include "delay.h"
- #include "motor.h"
- #include "PWM.h"
- #include "GPIO.h"
- extern u8 speed1,speed2;
- extern u16 rev1,rev2;
- /************* 功能說明 **************
- 電機驅(qū)動測試例程
- // 函數(shù): void PWM_config(void)
- // 描述: PWM配置函數(shù)。
- // 參數(shù): none.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-8-15
- // 備注:
- void PWM_config(void)
- PWMx_InitDefine PWMx_InitStructure; //結(jié)構(gòu)定義
- PWMx_InitStructure.PWMx_IO_Select = PWM4_P22; //PWM輸出IO選擇. PWM2_P37,PWM2_P27,PWM3_P21,PWM3_P45,PWM4_P22,PWM4_P44,PWM5_P23,PWM5_P42,PWM6_P16,PWM6_P07,PWM7_P17,PWM7_P06
- PWMx_InitStructure.Start_IO_Level = 0; //設置PWM輸出端口的初始電平, 0或1
- PWMx_InitStructure.PWMx_Interrupt = DISABLE; //中斷允許, ENABLE或DISABLE
- PWMx_InitStructure.FirstEdge_Interrupt = DISABLE; //第一個翻轉(zhuǎn)中斷允許, ENABLE或DISABLE
- PWMx_InitStructure.SecondEdge_Interrupt = DISABLE; //第二個翻轉(zhuǎn)中斷允許, ENABLE或DISABLE
- PWMx_InitStructure.FirstEdge = 64; //第一個翻轉(zhuǎn)計數(shù), 1~32767
- PWMx_InitStructure.SecondEdge = 192; //第二個翻轉(zhuǎn)計數(shù), 1~32767
- PWMx_Configuration(PWM4_ID, &PWMx_InitStructure); //初始化PWM, PWM2_ID,PWM3_ID,PWM4_ID,PWM5_ID,PWM6_ID,PWM7_ID
- P2n_standard(1<<2); //IO初始化, 上電時為高阻
- PWMx_InitStructure.PWMx_IO_Select = PWM5_P23; //PWM輸出IO選擇. PWM2_P37,PWM2_P27,PWM3_P21,PWM3_P45,PWM4_P22,PWM4_P44,PWM5_P23,PWM5_P42,PWM6_P16,PWM6_P07,PWM7_P17,PWM7_P06
- PWMx_Configuration(PWM5_ID, &PWMx_InitStructure); //初始化PWM, PWM2_ID,PWM3_ID,PWM4_ID,PWM5_ID,PWM6_ID,PWM7_ID
- P2n_standard(1<<3); //IO初始化, 上電時為高阻
- TH2 = (u8)((65536UL - MAIN_Fosc / 500000UL) / 256); //波特率使用Timer2
- TL2 = (u8)((65536UL - MAIN_Fosc / 500000UL) % 256);
- AUXR = 0x14; //Timer2 set As Timer, Timer2 set as 1T mode;
- PWM_SourceClk_Duty(PwmClk_T2, 256); //時鐘源: PwmClk_1T,PwmClk_2T, ... PwmClk_16T, PwmClk_T2, PWM周期: 1~32767
- PWMCR |= ENPWM; // 使能PWM波形發(fā)生器,PWM計數(shù)器開始計數(shù)
- PWMCR &= ~ECBI; //禁止PWM計數(shù)器歸零中斷
- // PWMCR |= ECBI; //允許PWM計數(shù)器歸零中斷
- // PWMFDCR = ENFD | FLTFLIO | FDIO; //PWM失效中斷控制, ENFD | FLTFLIO | EFDI | FDCMP | FDIO
- void EXTI_config(void)
- EXTI_InitTypeDef EXTI_InitStructure; //結(jié)構(gòu)定義
- EXTI_InitStructure.EXTI_Mode = EXT_MODE_Fall; //中斷模式, EXT_MODE_RiseFall, EXT_MODE_Fall
- EXTI_InitStructure.EXTI_Polity = PolityLow; //中斷優(yōu)先級, PolityLow,PolityHigh
- EXTI_InitStructure.EXTI_Interrupt = ENABLE; //中斷允許, ENABLE或DISABLE
- Ext_Inilize(EXT_INT0,&EXTI_InitStructure); //初始化INT0 EXT_INT0,EXT_INT1,EXT_INT2,EXT_INT3,EXT_INT4
- Ext_Inilize(EXT_INT1,&EXTI_InitStructure); //初始化INT1 EXT_INT0,EXT_INT1,EXT_INT2,EXT_INT3,EXT_INT4
- void Timer_config(void)
- TIM_InitTypeDef TIM_InitStructure; //結(jié)構(gòu)定義
- TIM_InitStructure.TIM_Mode = TIM_16BitAutoReload; //指定工作模式, TIM_16BitAutoReload,TIM_16Bit,TIM_8BitAutoReload,TIM_16BitAutoReloadNoMask
- TIM_InitStructure.TIM_Polity = PolityHigh; //指定中斷優(yōu)先級, PolityHigh,PolityLow
- TIM_InitStructure.TIM_Interrupt = ENABLE; //中斷是否允許, ENABLE或DISABLE
- TIM_InitStructure.TIM_ClkSource = TIM_CLOCK_12T; //指定時鐘源, TIM_CLOCK_1T,TIM_CLOCK_12T,TIM_CLOCK_Ext
- TIM_InitStructure.TIM_ClkOut = ENABLE; //是否輸出高速脈沖, ENABLE或DISABLE
- TIM_InitStructure.TIM_Value = 0x4cd0; //初值,
- TIM_InitStructure.TIM_Run = ENABLE; //是否初始化后啟動定時器, ENABLE或DISABLE
- Timer_Inilize(Timer0,&TIM_InitStructure); //初始化Timer0 Timer0,Timer1,Timer2
- void main(void)
- u8 v1[3],v2[3];
- P4n_standard(0x1e);
- LCD_init(); //初始化液晶
- LCD_clear();
- LCD_write_english_string(6,2," Welcome To");
- delay(1);
- LCD_clear();
- LCD_write_chinese_string(0,2,12,6,0,2);
- delay(2);
- LCD_clear();
- LCD_write_chinese_string(12,2,12,3,8,2);
- LCD_write_english_string(54,3,". ");
- delay_ms(250);delay_ms(250);
- LCD_write_english_string(54,3,".. ");
- LCD_write_english_string(54,3,"...");
- LCD_clear();
- EXTI_config();
- Timer_config();
- EA=1;
- PWM_config(); //PWM初始化
- GPIO_config();
- LCD_write_chinese_string(15,0,12,4,14,2);
- LCD_write_chinese_string(2,2,12,2,11,1);
- LCD_write_english_string(27,3,"1: cm/s");
- LCD_write_chinese_string(2,4,12,2,11,1);
- LCD_write_english_string(27,5,"2: cm/s");
- while(1)
復制代碼
基于STC15W4K32S4的智能小車測速程序,測速使用光電碼盤,顯示采用諾基亞5110液晶屏.rar
(162.99 KB, 下載次數(shù): 48)
2018-1-24 14:40 上傳
點擊文件名下載附件
基于STC15W4K32S4的智能小車測速程序,測速使用光電碼盤,顯示采用諾基亞5110液晶屏 下載積分: 黑幣 -5
