main函數,初始化時鐘串口等,執(zhí)行MPU6050Test();后 while(i){ReadGYRO()}就能讀取DMP輸出的三個角
單片機源程序如下:
- #include "mpu6050.h"
- #define delay_ms(x) DelayMs(x)
- void MPU6050Test(void)
- int FLAG;
- do
- FLAG=MPU_Init(); //初始化MPU6050, PC0,PC1
- delay_ms (200);
- printf ("Waiting...\n");
- if(FLAG)
- printf("ErrorMPU6050:%d...\t\n",FLAG);
- }while(FLAG);
- do
- FLAG=mpu_dmp_init();
- delay_ms (200);
- if(FLAG)
- printf("ErrorDMP:%d...\t\n",FLAG);
- }while(FLAG);
- printf("MPU6050 DMP Int... \t\n");
- float anger[3];
- void ReadGYRO()
- float loop_time_200hz=Get_Cycle_T(0);
- //TDT_IMUBotupdate(0.05,Gyroy);
- // MPU_Get_Accelerometer(&Gyroy->aaceleration[X],&Gyroy->aaceleration[Y],&Gyroy->aaceleration[Z]); //得到加速度傳感器數據
- // MPU_Get_Gyroscope(&Gyroy->gyro[X],&Gyroy->gyro[Y],&Gyroy->gyro[Z]); //得到陀螺儀數據
- MPU_Get_Accelerometer(&Gyroy->OriginalAace[0],&Gyroy->OriginalAace[1],&Gyroy->OriginalAace[2]);
- MPU_Get_Gyroscope(&Gyroy->OriginalGyroys[0],&Gyroy->OriginalGyroys[1],&Gyroy->OriginalGyroys[2]);
- for(int i=0;i<3;i++)
- mpu9250filter.acc.origin [i] =Gyroy->OriginalAace[i];
- mpu9250filter.gyro.origin [i] =Gyroy->OriginalGyroys[i];
- Mpu9250Top_Data_Prepare();
- TDT_update(0.5f *loop_time_200hz);
- printf("dmp=%d\n",mpu_dmp_get_data(&anger[0],&anger[1],&anger[2]));
- // float T_IMU=Get_Cycle_T(0);
- // //TDT_IMUBotupdate(0.05,Gyroy);
- // if(mpu_dmp_get_data(&anger[0],&anger[1],&anger[2])==0)
- // // MPU_Get_Accelerometer(&Gyroy->aaceleration[X],&Gyroy->aaceleration[Y],&Gyroy->aaceleration[Z]); //得到加速度傳感器數據
- // // MPU_Get_Gyroscope(&Gyroy->gyro[X],&Gyroy->gyro[Y],&Gyroy->gyro[Z]); //得到陀螺儀數據
- // MPU_Get_Accelerometer(&Gyroy->OriginalAace[0],&Gyroy->OriginalAace[1],&Gyroy->OriginalAace[2]);
- // MPU_Get_Gyroscope(&Gyroy->OriginalGyroys[0],&Gyroy->OriginalGyroys[1],&Gyroy->OriginalGyroys[2]);
- //初始化MPU6050
- //返回值:0,成功
- // 其他,錯誤代碼
- u8 MPU_Init(void)
- u8 res;
- IIC_Init();//初始化IIC總線
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X80); //復位MPU6050
- delay_ms(100);
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X00); //喚醒MPU6050
- MPU_Set_Gyro_Fsr(3); //陀螺儀傳感器,±2000dps
- MPU_Set_Accel_Fsr(0); //加速度傳感器,±2g
- MPU_Set_Rate(50); //設置采樣率50Hz
- MPU_Write_Byte(MPU_INT_EN_REG,0X00); //關閉所有中斷
- MPU_Write_Byte(MPU_USER_CTRL_REG,0X00); //I2C主模式關閉
- MPU_Write_Byte(MPU_FIFO_EN_REG,0X00); //關閉FIFO
- MPU_Write_Byte(MPU_INTBP_CFG_REG,0X80); //INT引腳低電平有效
- res=MPU_Read_Byte(MPU_DEVICE_ID_REG);
- if(res==MPU_ADDR)//器件ID正確
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X01); //設置CLKSEL,PLL X軸為參考
- MPU_Write_Byte(MPU_PWR_MGMT2_REG,0X00); //加速度與陀螺儀都工作
- MPU_Set_Rate(50); //設置采樣率為50Hz
- }else return 1;
- return 0;
- //設置MPU6050陀螺儀傳感器滿量程范圍
- //fsr:0,±250dps;1,±500dps;2,±1000dps;3,±2000dps
- //返回值:0,設置成功
- // 其他,設置失敗
- u8 MPU_Set_Gyro_Fsr(u8 fsr)
- return MPU_Write_Byte(MPU_GYRO_CFG_REG,fsr<<3);//設置陀螺儀滿量程范圍
- //設置MPU6050加速度傳感器滿量程范圍
- //fsr:0,±2g;1,±4g;2,±8g;3,±16g
- //返回值:0,設置成功
- // 其他,設置失敗
- u8 MPU_Set_Accel_Fsr(u8 fsr)
- return MPU_Write_Byte(MPU_ACCEL_CFG_REG,fsr<<3);//設置加速度傳感器滿量程范圍
- //設置MPU6050的數字低通濾波器
- //lpf:數字低通濾波頻率(Hz)
- //返回值:0,設置成功
- // 其他,設置失敗
- u8 MPU_Set_LPF(u16 lpf)
- u8 data=0;
- if(lpf>=188)data=1;
- else if(lpf>=98)data=2;
- else if(lpf>=42)data=3;
- else if(lpf>=20)data=4;
- else if(lpf>=10)data=5;
- else data=6;
- return MPU_Write_Byte(MPU_CFG_REG,data);//設置數字低通濾波器
- //設置MPU6050的采樣率(假定Fs=1KHz)
- //rate:4~1000(Hz)
- //返回值:0,設置成功
- // 其他,設置失敗
- u8 MPU_Set_Rate(u16 rate)
- u8 data;
- if(rate>1000)rate=1000;
- if(rate<4)rate=4;
- data=1000/rate-1;
- data=MPU_Write_Byte(MPU_SAMPLE_RATE_REG,data); //設置數字低通濾波器
- return MPU_Set_LPF(rate/2); //自動設置LPF為采樣率的一半
- //得到溫度值
- //返回值:溫度值(擴大了100倍)
- short MPU_Get_Temperature(void)
- u8 buf[2];
- short raw;
- float temp;
- MPU_Read_Len(MPU_ADDR,MPU_TEMP_OUTH_REG,2,buf);
- raw=((u16)buf[0]<<8)|buf[1];
- temp=36.53+((double)raw)/340;
- return temp*100;;
- //得到陀螺儀值(原始值)
- //gx,gy,gz:陀螺儀x,y,z軸的原始讀數(帶符號)
- //返回值:0,成功
- // 其他,錯誤代碼
- u8 MPU_Get_Gyroscope(short *gx,short *gy,short *gz)
- u8 buf[6],res;
- res=MPU_Read_Len(MPU_ADDR,MPU_GYRO_XOUTH_REG,6,buf);
- if(res==0)
- *gx=((u16)buf[0]<<8)|buf[1];
- *gy=((u16)buf[2]<<8)|buf[3];
- *gz=((u16)buf[4]<<8)|buf[5];
- return res;;
- //得到加速度值(原始值)
- //返回值:0,成功
- // 其他,錯誤代碼
- u8 MPU_Get_Accelerometer(short *ax,short *ay,short *az)
- u8 buf[6],res;
- res=MPU_Read_Len(MPU_ADDR,MPU_ACCEL_XOUTH_REG,6,buf);
- if(res==0)
- *ax=((u16)buf[0]<<8)|buf[1];
- *ay=((u16)buf[2]<<8)|buf[3];
- *az=((u16)buf[4]<<8)|buf[5];
- return res;;
- //IIC連續(xù)寫
- //addr:器件地址
- //reg:寄存器地址
- //len:寫入長度
- //buf:數據區(qū)
- //返回值:0,正常
- // 其他,錯誤代碼
- u8 MPU_Write_Len(u8 addr,u8 reg,u8 len,u8 *buf)
- u8 i;
- IIC_Start();
- IIC_Send_Byte((addr<<1)|0);//發(fā)送器件地址+寫命令
- if(IIC_Wait_Ack()) //等待應答
- IIC_Stop();
- return 1;
- IIC_Send_Byte(reg); //寫寄存器地址
- IIC_Wait_Ack(); //等待應答
- for(i=0;i<len;i++)
- IIC_Send_Byte(buf[i]); //發(fā)送數據
- if(IIC_Wait_Ack()) //等待ACK
- IIC_Stop();
- return 1;
- IIC_Stop();
- return 0;
- //IIC連續(xù)讀
- //addr:器件地址
- //reg:要讀取的寄存器地址
- //len:要讀取的長度
- //buf:讀取到的數據存儲區(qū)
- //返回值:0,正常
- // 其他,錯誤代碼
- u8 MPU_Read_Len(u8 addr,u8 reg,u8 len,u8 *buf)
- IIC_Start();
- IIC_Stop();
- return 1;
- IIC_Start();
- IIC_Send_Byte((addr<<1)|1);//發(fā)送器件地址+讀命令
- while(len)
- if(len==1)*buf=IIC_Read_Byte(0);//讀數據,發(fā)送nACK
- else *buf=IIC_Read_Byte(1); //讀數據,發(fā)送ACK
- len--;
- buf++;
- IIC_Stop(); //產生一個停止條件
- return 0;
- //IIC寫一個字節(jié)
- //reg:寄存器地址
- //data:數據
- //返回值:0,正常
- // 其他,錯誤代碼
- u8 MPU_Write_Byte(u8 reg,u8 data)
- IIC_Start();
- IIC_Send_Byte((MPU_ADDR<<1)|0);//發(fā)送器件地址+寫命令
- IIC_Stop();
- return 1;
- IIC_Send_Byte(data);//發(fā)送數據
- IIC_Stop();
- return 1;
- IIC_Stop();
- return 0;
- //IIC讀一個字節(jié)
- //reg:寄存器地址
- //返回值:讀到的數據
- u8 MPU_Read_Byte(u8 reg)
- u8 res;
- IIC_Start();
- IIC_Start();
- IIC_Send_Byte((MPU_ADDR<<1)|1);//發(fā)送器件地址+讀命令
- res=IIC_Read_Byte(0);//讀取數據,發(fā)送nACK
- return res;
復制代碼
MPU6050 DMP.zip
(43.69 KB, 下載次數: 251)
2018-1-26 16:20 上傳
點擊文件名下載附件
整理后的mpu6050 dmp 文件,包括6050驅動代碼
