查看: 16113|回復(fù): 25
RFID RC522程序源碼(51單片機可用)
ID:281734 發(fā)表于 2018-2-2 15:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
RFID程序(51可用)
詳見附件
單片機源碼:
  1. /**********************RC522實驗開發(fā)板例程************************
  2. *  CPU:STC89C52RC
  3. *  晶振:11.0592MHZ
  4. ------------------------------------------------*/
  5. #include <reg52.h>
  6. #include  <STDIO.H>
  7. #include <string.h>
  8. #include "main.h"
  9. #include "mfrc522.h"
  10. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  11. //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
  12. //4字節(jié)金額(低字節(jié)在前)+4字節(jié)金額取反+4字節(jié)金額+1字節(jié)塊地址+1字節(jié)塊地址取反+1字節(jié)塊地址+1字節(jié)塊地址取反
  13. unsigned char code data2[4]  = {0,0,0,0x01};
  14. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  15. unsigned char g_ucTempbuf[20];
  16. void delay1(unsigned int z)
  17. {
  18.         unsigned int x,y;
  19.         for(x=z;x>0;x--)
  20.         for(y=110;y>0;y--);
  21. }
  22. void main( )
  23. {
  24.     unsigned char status,i,j;
  25.           unsigned int temp;
  26.      InitializeSystem( );
  27.      PcdReset();
  28.      PcdAntennaOff();
  29.      PcdAntennaOn();
  30.      while ( 1 )
  31.      {
  32.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  33.          if (status != MI_OK)
  34.          {
  35.               InitializeSystem( );
  36.      PcdReset();
  37.      PcdAntennaOff();
  38.      PcdAntennaOn();
  39.                           continue;
  40.          }
  41.
  42.                         printf("卡的類型:");
  43.             for(i=0;i<2;i++)
  44.                                         {
  45.                                                 temp=g_ucTempbuf[i];
  46.                                                 printf("%X",temp);
  47.
  48.                                         }
  49.
  50.          status = PcdAnticoll(g_ucTempbuf);//防沖撞
  51.          if (status != MI_OK)
  52.          {    continue;    }
  53.
  54.                                         ////////以下為超級終端打印出的內(nèi)容////////////////////////
  55.
  56.                                         printf("卡序列號:");        //超級終端顯示,
  57.                                         for(i=0;i<4;i++)
  58.                                         {
  59.                                                 temp=g_ucTempbuf[i];
  60.                                                 printf("%X",temp);
  61.
  62.                                         }
  63.                                         ///////////////////////////////////////////////////////////
  64.          status = PcdSelect(g_ucTempbuf);//選定卡片
  65.          if (status != MI_OK)
  66.          {    continue;    }
  67.
  68.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  69.          if (status != MI_OK)
  70.          {    continue;    }
  71.
  72.          status = PcdWrite(1, data1);//寫塊
  73.          if (status != MI_OK)
  74.          {    continue;    }
  75. while(1)
  76.                 {
  77.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
  78.          if (status != MI_OK)
  79.          {
  80.                   InitializeSystem( );
  81.      PcdReset();
  82.      PcdAntennaOff();
  83.      PcdAntennaOn();
  84.                           continue;
  85.          }
  86.                  status = PcdAnticoll(g_ucTempbuf);//防沖撞
  87.          if (status != MI_OK)
  88.          {    continue;    }
  89.                 status = PcdSelect(g_ucTempbuf);//選定卡片
  90.          if (status != MI_OK)
  91.          {    continue;    }
  92.
  93.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
  94.          if (status != MI_OK)
  95.          {    continue;    }
  96.          status = PcdValue(PICC_DECREMENT,1,data2);//扣款
  97.          if (status != MI_OK)
  98.          {    continue;    }
  99.
  100.          status = PcdBakValue(1, 2);//塊備份
  101.          if (status != MI_OK)
  102.          {    continue;    }
  103.
  104.          status = PcdRead(2, g_ucTempbuf);//讀塊
  105.          if (status != MI_OK)
  106.          {    continue;    }
  107.                 printf("對花:");        //超級終端顯示,
  108.          for(i=0;i<16;i++)
  109.                                         {
  110.                                                 temp=g_ucTempbuf[i];
  111.                                                 printf("%X",temp);
  112.
  113.                                         }
  114.                  printf("\n");
  115.                 LED_GREEN = 0;
  116.             for(i=0;i<250;i++)//先輸出一種頻率的聲音
  117.         {
  118.          for(j=0;j<80;j++);
  119.          Speaker=~Speaker;
  120.         }
  121.                 delay1(100);
  122.                 LED_GREEN = 1;
  123.                 delay1(100);
  124.                 LED_GREEN = 0;
  125.                 delay1(200);
  126.                 LED_GREEN = 1;
  127.                  PcdHalt();
  128.                 }
  129.     }
  130. }
  131. /////////////////////////////////////////////////////////////////////
  132. //系統(tǒng)初始化
  133. /////////////////////////////////////////////////////////////////////
  134. void InitializeSystem()
  135. {
  136. /*        P0M1 = 0x0; P0M2 = 0x0;
  137.         P1M1 = 0x0;        P1M2 = 0x0;
  138.         P3M1 = 0x0; P3M2 = 0xFF;
  139. */        P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
  140.          TMOD=0x21;                   //設(shè)T0為方式1,GATE=1;
  141.         SCON=0x50;
  142.         TH1=0xF4;          //波特率為2400bps
  143. ……………………
  144. …………限于本文篇幅 余下代碼請從51黑下載附件…………
MFRC522(51可用).zip (65.86 KB, 下載次數(shù): 512)
參與人數(shù) 1黑幣 +1 收起 理由
ttland + 1 共享資料的黑幣獎勵!
收藏收藏9 分享淘帖 頂1 踩
來自 2#
ID:449992 發(fā)表于 2018-12-19 16:24 | 只看該作者
rc522人員定位系統(tǒng)
rc522人員定位系統(tǒng).7z
1.28 MB, 下載次數(shù): 60, 下載積分: 黑幣 -5
stm320人員定位
admin + 50 回帖助人的獎勵!
ID:383498 發(fā)表于 2018-12-3 13:56 | 只看該作者
有用嗎
ID:375092 發(fā)表于 2018-12-5 13:36 | 只看該作者
能夠?qū)崿F(xiàn)些啥子功能呢樓主,我現(xiàn)在想要扣款,充值,等一些高級一點的程序功能
ID:480303 發(fā)表于 2019-2-25 11:30 | 只看該作者
不管咋樣 感謝樓主分享
不管怎么樣 感謝樓主的分享  這樣的例子很好
ID:489048 發(fā)表于 2019-3-20 16:12 | 只看該作者
謝謝樓主分享,研究學(xué)習(xí)一下。
ID:289193 發(fā)表于 2019-3-20 17:09 | 只看該作者
牛逼啊
學(xué)習(xí)一下先
ID:308951 發(fā)表于 2019-3-21 08:28 | 只看該作者
這個項目我也做過,我做的門禁系統(tǒng)結(jié)合語音的只要在他的主函數(shù)里面調(diào)用那些寫好的庫就跟STM32標準庫編程時一樣的,然后用顯示屏進行顯示
ID:503143 發(fā)表于 2019-4-4 12:54 | 只看該作者
jwl595 發(fā)表于 2019-3-21 08:28
這個項目我也做過,我做的門禁系統(tǒng)結(jié)合語音的只要在他的主函數(shù)里面調(diào)用那些寫好的庫就跟STM32標準庫編程時 ...
有資料嗎兄弟
ID:515887 發(fā)表于 2019-4-18 22:06 | 只看該作者
有這個下載好的文件嗎?急需急需,剛注冊,積分不夠。有沒有誰下載好了跟我分享一下?
ID:440456 發(fā)表于 2019-5-15 21:30 | 只看該作者
我也想下載學(xué)習(xí)
ID:440456 發(fā)表于 2019-5-15 21:46 | 只看該作者
是我想要的
ID:440456 發(fā)表于 2019-5-15 21:47 | 只看該作者
ID:540405 發(fā)表于 2019-5-17 08:01 | 只看該作者
正在學(xué)習(xí)中,但愿有用。
ID:588638 發(fā)表于 2019-7-25 08:55 | 只看該作者
謝謝lz的分享
ID:384520 發(fā)表于 2019-10-19 21:12 | 只看該作者
我只想復(fù)制卡 能實現(xiàn)嗎
ID:505153 發(fā)表于 2019-11-13 13:52 | 只看該作者
沒看見單片機引腳在哪配置的。
ID:242883 發(fā)表于 2019-11-13 16:30 | 只看該作者
感謝分享。
ID:20672 發(fā)表于 2019-11-14 12:56 | 只看該作者
啥東西都要學(xué)習(xí)學(xué)習(xí)
ID:328790 發(fā)表于 2020-1-10 16:06 | 只看該作者
學(xué)習(xí)下最近在弄這個
ID:505400 發(fā)表于 2020-2-16 20:54 | 只看該作者
可以實現(xiàn)什么功能
ID:266164 發(fā)表于 2020-5-8 15:54 | 只看該作者
謝謝分享
ID:1005936 發(fā)表于 2022-2-21 22:39 | 只看該作者
你好請問stc89c52,晶振是12mhz的板子,程序需要改動嗎?改動的話是只改動定時器的部分嗎?
