看了好多朋友用那個(gè)f_unlink()函數(shù)沒法刪除還有內(nèi)容的文件夾,今天在網(wǎng)上找到一個(gè)不錯(cuò)的函數(shù),所以拿來(lái)跟大家分享一下~廢話不多說直接上函數(shù)的代碼:
/* 刪除文件夾內(nèi)所有的文件和文件夾*/
FRESULT FS_DeleteIntFile(TCHAR* path)
UINT i, j;
FRESULT res;
DIR dir;
FILINFO fno;
#if _USE_LFN
fno.lfname = 0; /* Set null pointer because LFN is not needed */
#endif
res = f_opendir(&dir, path);
if (res == FR_OK)
for (i = 0; path[ i]; i++) ;
path[i++]='/';
for (;;)
res = f_readdir(&dir, &fno);
if (res != FR_OK || !fno.fname[0]) break;
if (fno.fname[0] == '.') continue;
j = 0;
do
path[i+j] = fno.fname[j];
while (fno.fname[j++]);
if (fno.fattrib & AM_DIR)
res = FS_DeleteIntFile(path);
if (res != FR_OK) break;
res = f_unlink(path);
if ((res != FR_OK) && (res != FR_DENIED)) break;
path[--i] = '\0';
return res;
/* 刪除此文件夾及內(nèi)部的文件及文件夾*/
FRESULT FS_DeleteFolderOrFile(TCHAR* path)
FRESULT res;
if (res == FR_OK)
else if (FR_NO_PATH == res)
return res;
首先把這兩個(gè)函數(shù)的定義放在ff.c當(dāng)中,別忘了在ff.h中聲明一下。然后直接調(diào)用就行啦
至于怎么用,不用我說了吧~
