查看: 4026|回復(fù): 6
8*8點(diǎn)陣led燈亮的燈出現(xiàn)重復(fù)
ID:239318 發(fā)表于 2018-2-8 21:20 | 顯示全部樓層 |閱讀模式
20黑幣
#include<reg52.h>
unsigned char lie[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
unsigned char hang[3][8]={0x00,0x18,0x24,0x24,0x24,0x24,0x18,0x00, //數(shù)字0
                          0x00,0x3c,0x20,0x38,0x04,0x24,0x38,0x00, //數(shù)字5
                          0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}; //數(shù)字8
int  a,i,j;
  TMOD=0x01;
  TH0=(65536-50000)/256;
ID:239318 發(fā)表于 2018-2-9 17:04 | 顯示全部樓層
是消影問(wèn)題,改一下程序就好了
ID:239318 發(fā)表于 2018-2-9 10:56 | 顯示全部樓層
admin 發(fā)表于 2018-2-9 01:11
可能是有特殊字符被屏蔽了,代碼最好用代碼框 框起來(lái)
可以說(shuō)詳細(xì)一點(diǎn)嗎?我真的想不出辦法來(lái)了
  1. #include<reg52.h>
  2. unsigned char lie[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  3. unsigned char hang[3][8]={0x00,0x18,0x24,0x24,0x24,0x24,0x18,0x00, //數(shù)字0                                               0x00,0x3c,0x20,0x38,0x04,0x24,0x38,0x00, //數(shù)字5                           0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}; //數(shù)字8
  4. int  a,i,j;
  5. void main()
  6. {
  7.      TMOD=0x01;
  8.      TH0=(65536-50000)/256;
  9.      TL0=(65536-50000)%256;
  10.      TR0=1;
  11.      while(1)
  12. {
  13.     P2=hang[j][i];
  14.     P1=lie[i];
  15.      i++;
  16.    if(i==8)
  17.   {
  18.       i=0;
  19.    }
  20.   if(TF0==1)
  21.   {
  22.        TF0=0;
  23.         a++;
  24.       if(a==10)
  25.    {
  26.          a=0;
  27.          j++;
  28.         if(j==3)
  29.        {
  30.            j=0;
  31.         }
  32.      }
  33.    }
  34. }
  35. }
ID:1 發(fā)表于 2018-2-9 01:11 | 顯示全部樓層
科技論2 發(fā)表于 2018-2-8 21:29
本來(lái)有挺多東西接結(jié)果上傳后就不見(jiàn)了
ID:239318 發(fā)表于 2018-2-8 21:43 | 顯示全部樓層
又來(lái)寫(xiě)一遍,好煩啊。大家可以看一下圖片和程序,按照正常的思路數(shù)字“0”在8*8點(diǎn)陣第一行應(yīng)該是0x00,第二行應(yīng)該是0x18,我按照這種思路用delay函數(shù)寫(xiě)過(guò)一遍結(jié)果是正常的,用定時(shí)器就出現(xiàn)上面這中情況,先謝謝大家了。
ID:239318 發(fā)表于 2018-2-8 21:32 | 顯示全部樓層
#include<reg52.h> unsigned char lie[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe}; unsigned char hang[3][8]={0x00,0x18,0x24,0x24,0x24,0x24,0x18,0x00, //數(shù)字0                           0x00,0x3c,0x20,0x38,0x04,0x24,0x38,0x00, //數(shù)字5                           0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}; //數(shù)字8 int  a,i,j; void main() {   TMOD=0x01;   TH0=(65536-50000)/256;           TL0=(65536-50000)%256;   TR0=1;   while(1)   {            P2=hang[j][i];      P1=lie[i];           i++;          if(i==8)          {            i=0;          }          if(TF0==1)          {                    TF0=0;                    a++;                                    if(a==10)                  {                            a=0;                            j++;                                                     if(j==3)                          {                            j=0;                          }                  }      }   } }
ID:239318 發(fā)表于 2018-2-8 21:29 | 顯示全部樓層
