查看: 2206|回復(fù): 1
超聲波測距利用1602顯示程序
ID:285420 發(fā)表于 2018-2-25 16:20 | 顯示全部樓層 |閱讀模式
#include <AT89x51.H>        //器件配置文件
#include <intrins.h>
#define  RX  P3_1
#define  TX  P3_0
#define LCM_RW  P2_1 //定義LCD引腳
#define LCM_RS  P2_2
#define LCM_E   P2_0
#define LCM_Data  P0
#define Busy    0x80 //用于檢測LCM狀態(tài)字中的Busy標(biāo)識
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void Decode(unsigned char ScanCode);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
void ReadStatusLCM(void);
unsigned char code mcustudio[] ={"  LIU HENG RUI  "};
unsigned char code email[] =    {"  QQ:1277668379 "};
unsigned char code Cls[] =      {"                "};
unsigned char code ASCII[30] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M','C','D','I','S','T','A','N','C','E','T','H','E',':'};
                               //   0   1   2   3   4   5   6   7   8   9   10  11  12  13  14  15  16  17  18  19  20  21  22  23  24  25
static unsigned char DisNum = 0; //顯示用指針
       unsigned int  time=0;
       unsigned long S=0;
       bit      flag =0;
       unsigned char disbuff[4]    ={ 0,0,0,0,};
//寫數(shù)據(jù)
    ReadStatusLCM(); //檢測忙
    LCM_RS = 1;
    LCM_RW = 0;
    LCM_Data = WDLCM;
    LCM_E = 1; //若晶振速度太高可以在這后加小的延時
    LCM_E = 0; //延時
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
    if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測忙
    LCM_RS = 0;
    LCM_RW = 0;
    LCM_Data = WCLCM;
    LCM_E = 1;
    LCM_E = 0;
//讀數(shù)據(jù)
    LCM_RS = 1;
    LCM_RW = 1;
    LCM_E = 0;
    LCM_E = 0;
    LCM_E = 1;
    return(LCM_Data);
//讀狀態(tài)
    unsigned char sta;
    LCM_Data = 0xFF;
    LCM_RS = 0;
    LCM_RW = 1;
    do
        LCM_E = 1;
        sta = LCM_Data;
        LCM_E = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
void LCMInit(void) //LCM初始化
    LCM_Data = 0;
    WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號
    Delay5Ms();
    Delay5Ms();
    Delay5Ms();
    WriteCommandLCM(0x38,1); //顯示模式設(shè)置,開始要求每次檢測忙信號
    WriteCommandLCM(0x08,1); //關(guān)閉顯示
    WriteCommandLCM(0x01,1); //顯示清屏
    WriteCommandLCM(0x06,1); // 顯示光標(biāo)移動設(shè)置
    WriteCommandLCM(0x0F,1); // 顯示開及光標(biāo)設(shè)置
//按指定位置顯示一個字符
    Y &= 0x1;
    X &= 0xF; //限制X不能大于15,Y不能大于1
    if (Y) X |= 0x40; //當(dāng)要顯示第二行時地址碼+0x40;
    X |= 0x80; //算出指令碼
    WriteCommandLCM(X, 1); //發(fā)命令字
    WriteDataLCM(DData); //發(fā)數(shù)據(jù)
//按指定位置顯示一串字符
    unsigned char ListLength;
  ListLength = 0;
    Y &= 0x1;
    while (DData[ListLength]>0x19) //若到達(dá)字串尾則退出
            if (X <= 0xF) //X坐標(biāo)應(yīng)小于0xF
                    DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
                    ListLength++;
                    X++;
//5ms延時
void Delay5Ms(void)
    unsigned int TempCyc = 5552;
    while(TempCyc--);
//400ms延時
    unsigned char TempCycA = 5;
    unsigned int TempCycB;
    while(TempCycA--)
            TempCycB=7269;
            while(TempCycB--);
    void Conut(void)
     time=TH0*256+TL0;
     TH0=0;
     TL0=0;
     S=(time*1.7)/10;     //算出來是CM*10
     if((S>=7000)||flag==1) //超出測量范圍顯示“-”
      flag=0;
      DisplayOneChar(0, 1, ASCII[14]);  //顯示D
      DisplayOneChar(1, 1, ASCII[15]);  //顯示I
      DisplayOneChar(2, 1, ASCII[16]);  //顯示S
    DisplayOneChar(3, 1, ASCII[17]);  //顯示T
        DisplayOneChar(4, 1, ASCII[18]);  //顯示A
      DisplayOneChar(5, 1, ASCII[19]);  //顯示N
        DisplayOneChar(6, 1, ASCII[20]);  //顯示C
        DisplayOneChar(7, 1, ASCII[21]);  //顯示E
        DisplayOneChar(8, 1, ASCII[25]);  //顯示:
//  DisplayOneChar(9, 1, ASCII[23]);  //顯示
      DisplayOneChar(9, 1, ASCII[11]);  //百位
      DisplayOneChar(10, 1, ASCII[11]); //十位
      DisplayOneChar(11, 1, ASCII[11]);  //個位
        DisplayOneChar(12, 1, ASCII[10]);  //顯示.
        DisplayOneChar(13, 1, ASCII[11]);  //小數(shù)點(diǎn)后一位
      DisplayOneChar(14, 1, ASCII[13]);  //顯示C
      DisplayOneChar(15, 1, ASCII[12]); //顯示M
      disbuff[0]=S%10000/1000;
      disbuff[1]=S%10000%1000/100;
      disbuff[2]=S%10000%1000%100/10;
        disbuff[3]=S%10000%1000%100%10;
      DisplayOneChar(9, 1, ASCII[disbuff[0]]);
      DisplayOneChar(10, 1, ASCII[disbuff[1]]);
      DisplayOneChar(11, 1, ASCII[disbuff[2]]);
        DisplayOneChar(13, 1, ASCII[disbuff[3]]);
     void zd0() interrupt 1          //T0中斷用來計(jì)數(shù)器溢出,超過測距范圍
    flag=1;                          //中斷溢出標(biāo)志
     void  StartModule()                 //啟動模塊
      TX=1;                              //啟動一次模塊
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      _nop_();
      TX=0;
void delayms(unsigned int ms)
    unsigned char i=100,j;
    for(;ms;ms--)
        while(--i)
            j=10;
            while(--j);
ID:675016 發(fā)表于 2019-12-26 22:40 | 顯示全部樓層
寫的非常好真的好
