查看: 2587|回復(fù): 4
請大神幫忙分析一下程序就是一個簡單的時鐘,一切都可以就是按鍵部分不起作用
回帖獎勵 5 黑幣 回復(fù)本帖可獲得 5 黑幣獎勵! 每人限 1 次(中獎概率 50%)
本帖最后由 july0 于 2018-3-3 21:41 編輯
#include<reg52.h>
#include"24c02.h"
sbit rs=P2^6;
sbit wr=P2^5;
sbit lcden=P2^7;
sbit s1=P1^0;
sbit s2=P1^1;
sbit s3=P1^2;
sbit rd=P1^3;
sbit beep=P1^4;
uchar count,s1num;
char miao,shi,fen;
uchar code table[]="2008-9-30 MON";
void delay(uint z)
        uint x,y;
        for(x=z;x--;x>0)
                for(y=110;y--;y>0);
void di()
        beep=0;
        delay(100);
        beep=1;
void write_com(uchar com)//命令送給液晶
  rs=0;
  lcden=0;
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_date(uchar date)
  rs=1;
  lcden=0;
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_sfm(uchar add,uchar date)
  uchar shi,ge;
  shi=date/10;
  ge=date%10;
  write_com(0x80+0x40+add);
  write_date(0x30+shi);
  write_date(0x30+ge);
void init()
  void init_24c02();
  uchar num;
  wr=0;
  rd=0;
  lcden=0;
  fen=0;
  shi=0;
  miao=0;
  count=0;
  s1num=0;
  write_com(0x38);
  write_com(0x0c);
  write_com(0x06);
  write_com(0x01);
  write_com(0x80);
  for(num=0;num<15;num++)
        write_date(table[num]);
        delay(5);
  write_com(0x80+0x40+6);
  write_date(':');
  delay(5);
  write_com(0x80+0x40+9);
  write_date(':');
  delay(5);
  miao=read_add(1);
  fen=read_add(2);
  shi=read_add(3);
  write_sfm(10,miao);
  write_sfm(4,shi);
  write_sfm(7,fen);
  TMOD=0x01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=1;
void keyscan()
  if(s1==0)
          delay(5);
        if(s1==0)
          s1num++;
          while(!s1);
          di();
          if(s1num==1)
            TR0=0;
                write_com(0x80+0x40+10);
                write_com(0x0f);
          if(s1num==2)
            write_com(0x80+0x40+7);
          if(s1num==3);
            write_com(0x80+0x40+4);
          if(s1num==4);
            s1num=0;
                write_com(0x0c);
                TR0=1;
  if(s1num!=0);
    if(s2==0);
        delay(5);
        if(s2==0);
                while(!s2);
                di();
                if(s1num==1)
                        miao++;
                        if(miao==60)
                        miao=0;
                        write_sfm(10,miao);
                        write_add(1,miao);
                if(s1num==2)
                     fen++;
                        if(fen==60)
                        fen=0;
                        write_sfm(7,fen);
                        write_add(2,fen);
                if(s1num==3)
                        shi++;
                        if(shi==24)
                        shi=0;
                        write_sfm(4,shi);
                        write_add(3,shi);
        if(s3==0)
                delay(5);
                if(s3==0)
                while(!s3);
                di();
                if(s1num==1)
                         miao--;
                        if(miao==-1)
                        miao=59;
                        write_sfm(10,miao);
                        write_add(1,miao);
                if(s1num==2)
                        fen--;
                        if(fen==-1)
                        fen=59;
                        write_sfm(7,fen);
                        write_add(2,fen);
                if(s1num==3)
                        shi--;
                        if(shi==-1)
                        shi=23;
                        write_sfm(4,shi);
                        write_add(3,shi);
        init();
                keyscan();
void timer0() interrupt 1
        count++;
        if(count==20)
        miao++;
        count=0;
        if(miao==60)
                miao=0;
                fen++;
                if(fen==60)
                        fen=0;
                        shi++;
                        if(shi==24)
                                shi=0;
                        write_sfm(4,shi);
                        write_add(3,shi);
                write_sfm(7,fen);
                write_add(2,fen);
        write_sfm(10,miao);
        write_add(1,miao);
其中24c02.h的內(nèi)容是
bit write=0;
sbit sda=P2^0;
sbit scl=P2^1;
void delay0()
void start()
        sda=1;
        delay0();
        scl=1;
        delay0();
        sda=0;
        delay0();
void stop()
  sda=0;
  delay0();
  scl=1;
  delay0();
  sda=1;
  delay0();
void respon()
        uchar i;
        scl=1;
        delay0();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay0();
void init_24c02()
        sda=1;
        delay0();
        scl=1;
        delay0();
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay0();
                sda=CY;
                delay0();
                scl=1;
                delay0();
        scl=0;
        delay0();
        sda=1;
        delay0();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay0();
        sda=1;
        delay0();
        for(i=0;i<8;i++)
                scl=1;
                delay0();
                k=(k<<1)|sda;
                scl=0;
                delay0();
        return k;
void write_add(uchar address,uchar date)
        start();
        write_byte(0xa0);
        respon();
        write_byte(address);
        respon();
        write_byte(date);
        respon();
        stop();
char read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respon();
        respon();
        start();
        write_byte(0xa1);
        respon();
        date=read_byte();
        stop();
        return date;
求解為什么連接上按鍵后按鍵部分卻不起作用(按鍵沒有問題)
ID:222948 發(fā)表于 2018-3-4 10:34 | 只看該作者
在程序中找到if(s1num!=0);這一行把后面的分號去掉試一下,應(yīng)該可以了,(另外就是不用的函數(shù)可以屏蔽了,還有在中斷和主函數(shù)不要同時調(diào)用同一個函數(shù))這是建議
ID:284007 發(fā)表于 2018-3-4 12:28 | 只看該作者
999333 發(fā)表于 2018-3-4 10:34
在程序中找到if(s1num!=0);這一行把后面的分號去掉試一下,應(yīng)該可以了,(另外就是不用的函數(shù)可以屏蔽了, ...
謝謝終于調(diào)試成功了,我還有一個問題希望前輩解答一下,那就是是不是中斷和主函數(shù)同時調(diào)用一個函數(shù)有時候會出現(xiàn)錯誤才不能同時調(diào)用
ID:284007 發(fā)表于 2018-3-4 12:33 | 只看該作者
還有就是液晶.有一部分我沒有設(shè)置卻會出現(xiàn)字符是為什么,我試了很多遍也不能去除掉
ID:222948 發(fā)表于 2018-3-4 19:23 | 只看該作者
july0 發(fā)表于 2018-3-4 12:33
亂碼是肯定的,你只負(fù)責(zé)初始地址而且沒有限制最后的末地址,最簡單就是在uchar code table[]="2008-9-30 MON";中mon的后面加兩個空格就行;比如uchar code table[]="2008-9-30 MON  ";這樣就行了
