3x8e做的智能監(jiān)控陀螺儀程序,陀螺儀用的MP6000A
#include "intell_monitor_api.h"
#include "asf.h"
#include "def.h"
#include "string.h"
#include "compiler.h"
#include "stdio.h"
#include "math.h"
#define PI 3.14159265
#define SDA_IO_OUTPUT 0x00
#define SDA_IO_INPUT 0x01
#define IIC_CLOCK_DELAY 100/*20->10, for test*/
#define IIC_HIGH 0x01
#define IIC_LOW 0x00
//定義MPU3050內(nèi)部地址********************
#define WHO 0x75
#define SMPL 0x19
#define DLPF 0x1a
#define GYRO_CONFIG 0x1b //陀螺儀自檢及測(cè)量范圍,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG 0x1c //加速計(jì)自檢、測(cè)量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define INT_CONFIG 0x37
#define INT_ENABLE 0x38
#define INT_STATUS 0x3a
#define TMP_H 0x41
#define TMP_L 0x42
#define GX_H 0x43
#define GX_L 0x44
#define GY_H 0x45
#define GY_L 0x46
#define GZ_H 0x47
#define GZ_L 0x48
#define AUX_H 0x3b
#define AUX_L 0x3c
#define AUY_H 0x3d
#define AUY_L 0x3e
#define AUZ_H 0x3f
#define AUZ_L 0x40
#define PWR_M1 0x6b
#define PWR_M2 0x6c
#define SlaveAddress 0xd0
UNIVOLTAGE_t vtg;
static void CLK_Delay(void)
unsigned long i;
for (i=0; i<IIC_CLOCK_DELAY; i++);
static STATUS setSCL_GYRO(uchar_t value)
if(value == IIC_LOW)
gpio_set_pin_low(TWI1_CLK_GPIO);
gpio_set_pin_high(TWI1_CLK_GPIO);
return ok;
static STATUS SDA_IO_Direction_GYRO(uchar_t value)
if(value == SDA_IO_OUTPUT) /*定義SDA為輸出方向*/
gpio_configure_pin(TWI1_DATA_GPIO,MDIO_OUTPUT_FLAGS);
if(value == SDA_IO_INPUT) /*定義SDA為輸入方向*/
gpio_configure_pin(TWI1_DATA_GPIO,MDIO_INPUT_FLAGS);
CLK_Delay();//delay_us(5);
return ok;
static STATUS setSDA_GYRO(uchar_t value)
/*SDA_IO_Direction_SFP(SDA_IO_OUTPUT);*/
gpio_set_pin_low(TWI1_DATA_GPIO);
gpio_set_pin_high(TWI1_DATA_GPIO);
return ok;
static uchar_t getSDA_GYRO()
if((pio_get_pin_value(TWI1_DATA_GPIO)) == 1)
return IIC_HIGH;
return IIC_LOW;
/*讀/寫(xiě)操作的START條件*/
static void START_GYRO()
SDA_IO_Direction_GYRO(SDA_IO_OUTPUT);
setSDA_GYRO(IIC_HIGH);
setSCL_GYRO(IIC_HIGH);
setSDA_GYRO(IIC_LOW);
setSCL_GYRO(IIC_LOW);
/*讀/寫(xiě)操作的STOP條件*/
static void STOP_GYRO()
/*setSCL_SFP(IIC_LOW);CLK_Delay();*/
/*發(fā)送1字節(jié)*/
static void BYTE_SND_GYRO(uchar_t WR_data)
uchar_t i;
printf("WR_DATA=%x\r\n",WR_data);
for(i=0;i<8;i++)
if(WR_data&0x80)
WR_data<<=1;
/*接收1字節(jié)*/
static uchar_t BYTE_RCV_GYRO()
uchar_t temp=0;
uchar_t i;
SDA_IO_Direction_GYRO(SDA_IO_INPUT);
for(i=0;i<8;i++)
temp <<= 1;
if(getSDA_GYRO() == IIC_HIGH)
temp |= 0x01;
return temp;
/*發(fā)送確認(rèn)比特(ACK)*/
static void SND_ACK_GYRO()
/*發(fā)送非確認(rèn)比特(noACK)*/
static void SND_noACK_GYRO()
/*接收確認(rèn)比特,返回ACK/noACK*/
static uchar_t RCV_ACK_GYRO()
if(getSDA_GYRO() == IIC_LOW)
return IIC_LOW;
return IIC_HIGH;
static STATUS IIC_ERROR_Release_GYRO()
STOP_GYRO();
printf("error\r\n");
return error;
static STATUS IIC_OK_Release_GYRO()
STOP_GYRO();
return ok;
STATUS sndsIICRead_GYRO(uchar_t slaveAddr, uchar_t readAddr, uchar_t *pBuff)
uchar_t regAddr;
unsigned short num;
if (pBuff == NULL)
return error;
regAddr = readAddr;
START_GYRO();
BYTE_SND_GYRO(slaveAddr);
if(RCV_ACK_GYRO()==IIC_HIGH)
IIC_ERROR_Release_GYRO();
return error;
BYTE_SND_GYRO(regAddr);
return error;
START_GYRO();
BYTE_SND_GYRO(slaveAddr |0x01);
return error;
*pBuff = BYTE_RCV_GYRO();
SND_ACK_GYRO();
SND_noACK_GYRO();
IIC_OK_Release_GYRO();
return ok;
STATUS sndsIICWriteGYRO(uchar_t slaveAddr, uchar_t writeAddr, uchar_t *pBuff)
uchar_t regAddr;
unsigned short i;
if (pBuff == NULL)
return error;
regAddr = writeAddr;
START_GYRO();
return error;
return error;
BYTE_SND_GYRO(*pBuff);
SND_ACK_GYRO();
return ok;
void InitMPU6050(void)
delay_ms(500);
uchar_t gyro_value2;
gyro_value2=0x00;
write_GYRO_register(SlaveAddress,PWR_M1,&gyro_value2,1);
delay_ms(10);
gyro_value2=0x07;
write_GYRO_register(SlaveAddress,SMPL,&gyro_value2,1);
delay_ms(10);
gyro_value2=0x06;
write_GYRO_register(SlaveAddress,DLPF,&gyro_value2,1);
delay_ms(10);
gyro_value2=0x18;
write_GYRO_register(SlaveAddress,GYRO_CONFIG,&gyro_value2,1);
delay_ms(10);
gyro_value2=0x01;
write_GYRO_register(SlaveAddress,ACCEL_CONFIG,&gyro_value2,1);
delay_ms(10);
/*uchar_t add,gyro_value1;
for(add=25;add<118;add++)
read_GYRO_register(SlaveAddress,add,&gyro_value1,1);
printf("REG_VALUE=%x %x\r\n",add,gyro_value1);
delay_ms(10);
// write_GYRO_register(SlaveAddress,PWR_M1,0x80,1);
#if 0
delay_ms(1000);
write_GYRO_register(SlaveAddress,PWR_M1,0x00,1);
delay_ms(10);
delay_ms(10);
write_GYRO_register(SlaveAddress,SMPL,0x07,1);
delay_ms(10);
write_GYRO_register(SlaveAddress,DLPF,0x06,1);
delay_ms(10);
write_GYRO_register(SlaveAddress,GYRO_CONFIG,0x18,1);
delay_ms(10);
write_GYRO_register(SlaveAddress,ACCEL_CONFIG,0x01,1);
delay_ms(10);
write_GYRO_register(SlaveAddress,INT_CONFIG,0x00,1);
delay_ms(10);
#endif
//合成數(shù)據(jù)
/*ushort_t GetData(uchar_t REG_Address)
uchar_t H,L;
H=read_GYRO_register(REG_Address);
L=read_GYRO_register(REG_Address+1);
return (H<<8)+L; //合成數(shù)據(jù)
/*float SqrtByNewton(float x)
float val = x;//最終
float last;//保存上一個(gè)計(jì)算的值
do
last = val;
val =(val + x/val) / 2;
}while(Abs(val-last) > eps);
return val;
float Sqrt(float x)
float xhalf = 0.5f * x;
int i = *(int*)&x;
i = 0x5f375a86 - (i>>1);
x = *(float*)&i;
x = x*(1.5f-xhalf*x*x);
printf("GYRO_XOUT=%.2f \r\n",1/x);
return 1/x;
double atan(double x)
//atan(x)=x-x^3/3+x^5/5-x^7/7+.....(-1<x<1)
//return:[-pi/2,pi/2]
double mult,sum,xx;
sum=0;
if(x==1){
return PI/4;
if(x==-1){
return -PI/4;
if((x>1||x<-1))
mult=1/x;
mult=x;
xx=mult*mult;
for(int i=1;i<200;i+=2){
sum+=mult*((i+1)%4==0?-1:1)/i;
mult*=xx;
if(x>1||x<-1){
return PI/2-sum;
else{
return sum;
/*union UNIVOLTAGE
float fVoltage;
char voltage4Byte[4];
UNIVOLTAGE vtg;
// char RS232ComBuf[4096];
// strcpy(vtg.voltage4Byte, RS232ComBuf);
//printf("%f", vtg.fVoltage);
void display_who(void)
uchar_t gyro_value;
read_GYRO_register(SlaveAddress,WHO,&gyro_value,1);
printf("WHO=%02x\r\n",gyro_value);
//lcd_printf(dis, dis_data); //轉(zhuǎn)換數(shù)據(jù)顯示
//DisplayListChar(2,0,dis,4); //啟始列,行,顯示數(shù)組,顯示長(zhǎng)度
//顯示x軸
void display_x(void)
uchar_t gyro_value1=0,gyro_value2=0;
ushort_t gyro_value3=0,gyro_value4=0;
sshort_t data=0;
float x;
double y;
read_GYRO_register(SlaveAddress,GX_L,&gyro_value1,1);
delay_ms(1);
read_GYRO_register(SlaveAddress,GX_H,&gyro_value2,1);
gyro_value3=gyro_value1;
gyro_value4=gyro_value2;
data=(sshort_t)((gyro_value4<<8)+gyro_value3); //合成數(shù)據(jù)
// data=data/16.4;
printf("GYRO_XOUT=%d \r\n",data);
x=Sqrt(Abs(data));
y=atan(1);
vtg.fVoltage=y;
sprintf("changeGYRO_XOUT=%f\r\n", vtg.fVoltage);
//printf("changeGYRO_XOUT=%d %d \r\n",y,(y*180)/PI);
//printf("sshort_t=%d \r\n",sizeof(sshort_t));
//data/=16.4; //計(jì)算對(duì)應(yīng) 度/秒
// printf("changeGYRO_XOUT=%d\r\n",data);
/*printf("\r\n");
lcd_printf(dis, data); //轉(zhuǎn)換數(shù)據(jù)顯示
printf("changedataGYRO_XOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//顯示y軸
void display_y(void)
sshort_t data=0;
read_GYRO_register(SlaveAddress,GY_L,&gyro_value1,1);
delay_ms(1);
read_GYRO_register(SlaveAddress,GY_H,&gyro_value2,1);
//data=data/16.4;
printf("GYRO_YOUT=%d \r\n",data);
// dis_data/=16.4; //計(jì)算對(duì)應(yīng) 度/秒
/* printf("\r\n");
printf("changedataGYRO_YOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//顯示z軸
void display_z(void)
sshort_t data=0;
read_GYRO_register(SlaveAddress,GZ_L,&gyro_value1,1);
delay_ms(1);
read_GYRO_register(SlaveAddress,GZ_H,&gyro_value2,1);
//data=data/16.4;
printf("GYRO_ZOUT=%d \r\n",data);
/* printf("\r\n");
//dis_data/=16.4; //計(jì)算對(duì)應(yīng) 度/秒
printf("changedataGYRO_ZOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//顯示x_g軸
void display_x_g(void)
sshort_t data=0;
read_GYRO_register(SlaveAddress,AUX_L,&gyro_value1,1);
delay_ms(1);
read_GYRO_register(SlaveAddress,AUX_H,&gyro_value2,1);
data=(gyro_value4<<8)|gyro_value3; //合成數(shù)據(jù)
//data=data/16384;
printf("GYRO_AUXOUT=%d\r\n",data);
/* printf("\r\n");
printf("changedataGYRO_AUXOUT=%s%s%s%s%s%s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//顯示y軸
void display_y_g(void)
sshort_t data=0;
read_GYRO_register(SlaveAddress,AUY_L,&gyro_value1,1);
delay_ms(1);
read_GYRO_register(SlaveAddress,AUY_H,&gyro_value2,1);
//data=data/16384;
printf("GYRO_AUYOUT=%d\r\n",data);
/* printf("\r\n");
//顯示z軸
void display_z_g(void)
sshort_t data=0;
read_GYRO_register(SlaveAddress,AUZ_L,&gyro_value1,1);
delay_ms(1);
read_GYRO_register(SlaveAddress,AUZ_H,&gyro_value2,1);
//data=data/16384;
printf("GYRO_AUZOUT=%d\r\n",data);
/* printf("\r\n");
//顯示TEM
void display_tem(void)
uchar_t fanwei1=0,fanwei2=0;
sshort_t data=0;
sshort_t Temperature=0;
read_GYRO_register(SlaveAddress,TMP_L,&gyro_value1,1);
delay_ms(1);
read_GYRO_register(SlaveAddress,TMP_H,&gyro_value2,1);
Temperature = 35+ ((sshort_t) (data + 13200)) / 280; // 計(jì)算出溫度
printf("GYRO_TEMPOUT=%d\r\n",Temperature);
//write_GYRO_register(SlaveAddress,0x19,0x07,1);
// delay_ms(10);
//printf("accset=%x\r\n",fanwei);
read_GYRO_register(SlaveAddress,0x1b,&fanwei1,1);
printf("GYRO_CONFIG_1B=%x\r\n",fanwei1);
delay_ms(1);
read_GYRO_register(SlaveAddress,0x1c,&fanwei2,1);
printf("ACCEL_CONFIG_1C=%x\r\n",fanwei2);
printf("\r\n");
/* printf("\r\n");
printf("changedataGYRO_TEMPOUT=%s %s %s %s %s %s\r\n",dis[0],dis[1],dis[2],dis[3],dis[4],dis[5]);
//整數(shù)轉(zhuǎn)字符串
void lcd_printf(uchar_t *s,int temp_data)
if(temp_data<0)
temp_data=-temp_data;
*s='-';
else *s=' ';
*++s =temp_data/10000+0x30;
temp_data=temp_data%10000; //取余運(yùn)算
*++s =temp_data/1000+0x30;
temp_data=temp_data%1000; //取余運(yùn)算
*++s =temp_data/100+0x30;
temp_data=temp_data%100; //取余運(yùn)算
*++s =temp_data/10+0x30;
temp_data=temp_data%10; //取余運(yùn)算
*++s =temp_data+0x30;
void IIC_init(void)
twi_options_t optsfp;
pmc_enable_periph_clk(BOARD_ID_TWI1);
optsfp.master_clk = sysclk_get_cpu_hz();
optsfp.speed = TWI_CLK;
if (twi_master_init(BOARD_BASE_TWI1, &optsfp) != TWI_SUCCESS)
puts("-E-\tTWI0 master initialization failed.\r");
uint8_t read_GYRO_register(uint8_t slave_addr, uint8_t reg_addr, uint8_t *reg_value, uint32_t reg_len)
twi_packet_t packet_sfp_rx;
delay_ms(1);
packet_sfp_rx.chip = slave_addr >> 1;
packet_sfp_rx.addr[0] = reg_addr;
packet_sfp_rx.addr_length = TWI_MEM_ADDR_LENGTH;
packet_sfp_rx.buffer = reg_value;
packet_sfp_rx.length = reg_len;
return twi_master_read(BOARD_BASE_TWI1, &packet_sfp_rx);
uint8_t write_GYRO_register(uint8_t slave_addr, uint8_t reg_addr, uint8_t *reg_value, uint32_t reg_len)
twi_packet_t packet_sfp_tx;
packet_sfp_tx.chip = slave_addr >> 1;
packet_sfp_tx.addr[0] = reg_addr;
packet_sfp_tx.addr_length = TWI_MEM_ADDR_LENGTH;
packet_sfp_tx.buffer = reg_value;
packet_sfp_tx.length = reg_len;
return twi_master_write(BOARD_BASE_TWI1, &packet_sfp_tx);
