無線遙控器設(shè)計(jì)的課程作業(yè)
簡化的設(shè)計(jì),在網(wǎng)頁端控制開發(fā)板LED的亮滅。
使用udp傳輸協(xié)議,可以較好的穿透內(nèi)網(wǎng),
實(shí)現(xiàn)端端之間的直接通信。
2018-3-7 22:18 上傳
2018-3-7 22:19 上傳
STM32MARVELL88芯片主控
- #define DEBUG
- #include "drivers.h"
- #include "app.h"
- #include "api.h"
- #include "cfg80211.h"
- #include "defs.h"
- #include "type.h"
- #include "types.h"
- #include "moal_sdio.h"
- #include "lwip/pbuf.h"
- #include "lwip/sys.h"
- #include "wpa.h"
- #include "moal_main.h"
- #include "moal_uap.h"
- #include "moal_uap_priv.h"
- #include "mlan_ioctl.h"
- #include "oled.h"
- *分為station和ap兩個(gè)設(shè)備,其接口函數(shù)是不一樣的
- *所以在不同的模式下我們選擇相對(duì)應(yīng)的設(shè)備進(jìn)行操作
- *wifi_dev指向當(dāng)前設(shè)備
- struct net_device *sta_wifi_dev = NULL;
- struct net_device *ap_wifi_dev = NULL;
- struct net_device *direct_wifi_dev = NULL;
- struct net_device *wifi_dev = NULL;
- struct net_device *get_wifi_dev()
- return wifi_dev;
- int is_hw_ok()
- return wifi_dev?1:0;
- * @brief 設(shè)置wifi模式,只是切換模式,不對(duì)ap參數(shù)進(jìn)行配置
- * @param type : MODE_AP, MODE_STATION, MODE_ADHOC
- * @retval ok: 0, err: -1
- int wifi_set_mode(int type)
- int ret = -1;
- int set_type;
- moal_private *priv;
- struct net_device *saved_dev = wifi_dev;
- priv = (moal_private *)wifi_dev->ml_priv;
- //暫不支持ap+sta同時(shí)存在,切換模式前先關(guān)閉wifi
- if(priv->bss_role == MLAN_BSS_ROLE_UAP)
- wifi_stop_ap();
- else
- wifi_disconnect();
- if(0)
- #ifdef UAP_SUPPORT
- else if(type == MODE_AP){
- set_type = NL80211_IFTYPE_AP;
- wifi_dev = ap_wifi_dev;
- OLED_ShowString(16,2," MODE:AP ");
- OLED_ShowString(0,0,"IP:");
- OLED_ShowString(24,0,"192.168.1.8");
- p_dbg("IP:192.168.1.8");
- #endif
- #ifdef STA_SUPPORT
- else if(type == MODE_STATION){
- wifi_dev = sta_wifi_dev;
- set_type = NL80211_IFTYPE_STATION;
- OLED_ShowString(16,2,"MODE:STATION");
- else if(type == MODE_ADHOC){
- set_type = NL80211_IFTYPE_ADHOC;
- OLED_ShowString(16,2," MODE:ADHOC ");
- #endif
- #ifdef WIFI_DIRECT_SUPPORT
- else if(type == MODE_P2P_GO){
- wifi_dev = direct_wifi_dev;
- set_type = NL80211_IFTYPE_P2P_GO;
- else if(type == MODE_P2P_GC){
- set_type = NL80211_IFTYPE_P2P_CLIENT;
- #endif
- else{
- p_err("type %d not support", type);
- return -1;
- if(wifi_dev == NULL){
- wifi_dev = saved_dev;
- p_err("%s not support", __FUNCTION__);
- return -1;
- if(wifi_dev->cfg80211_ops->change_virtual_intf){
- //ap和sta指向相同的change_virtual_intf
- ret = wifi_dev->cfg80211_ops->change_virtual_intf(priv->wdev->wiphy, wifi_dev, (enum nl80211_iftype)set_type, 0, 0);
- if(ret != 0)
- }else
- return ret;
- * @brief 設(shè)置硬件的多播、廣播、混雜模式
- * @param flags : IFF_PROMISC 接收所有的包
- IFF_ALLMULTI 接收所有的多播包(暫時(shí)采用接收所有多播報(bào)的簡單方式,
- 不處理多播地址表)
- int wifi_set_multicast(uint32_t flags)
- if(!wifi_dev)
- return -1;
- wifi_dev->flags |= flags;
- if(wifi_dev->netdev_ops && wifi_dev->netdev_ops->ndo_set_multicast_list)
- wifi_dev->netdev_ops->ndo_set_multicast_list(wifi_dev);
- return 0;
- * @brief 設(shè)置為混雜模式
- * @param
- int wifi_set_promisc()
- return wifi_set_multicast(IFF_PROMISC);
- * @brief 設(shè)置wifi頻道,for ap
- * @param channel : 1 - 14
- int wifi_set_channel(int channel)
- int ret = -1;
- struct ieee80211_channel ch;
- //sta和ap的cfg80211_ops接口是不一樣的,必須檢查其成員是否有效,下同
- if(wifi_dev->cfg80211_ops->set_channel){
- memset(&ch, 0, sizeof(struct ieee80211_channel));
- ch.hw_value = channel;
- ch.band = IEEE80211_BAND_2GHZ;
- ch.center_freq = ieee80211_channel_to_frequency(ch.hw_value, ch.band);
- ret = wifi_dev->cfg80211_ops->set_channel(priv->wdev->wiphy, wifi_dev, &ch, NL80211_CHAN_NO_HT);
- }else
- return ret;
- * @brief 設(shè)置wifi模式為AP參數(shù)
- * @param name : 網(wǎng)絡(luò)名稱
- * @param key:密碼
- * @param key_type:加密模式,可選參數(shù)KEY_NONE, KEY_WEP,KEY_WPA,KEY_WPA2
- * @param channel:頻道
- * @param max_client:最大允許客戶端數(shù)量,1 - MAX_STA_COUNT(SDK預(yù)設(shè)為10)
- int wifi_ap_cfg(char *name, char *key, int key_type, int channel, int max_client)
- int ret = -1;
- char str_tmp[64];
- /* example
- char *cmd = "ASCII_CMD=AP_CFG,"\
- "SSID=QWERT,"\
- "SEC=wep128,"\
- "KEY=12345,"\
- "CHANNEL=8,"\
- "MAX_SCB=4,"\
- "END";
- //配置ap參數(shù)我們沒有使用cfg80211_ops提供的, 而是使用更簡單的netdev_ops接口
- //netdev_ops接口比較豐富,這里做一個(gè)參考
- if(wifi_dev->netdev_ops && wifi_dev->netdev_ops->ndo_do_ioctl)
- struct iwreq *wrq = (struct iwreq *)mem_calloc(256, 1);
- if(!wrq)
- return ret;
- wrq->u.data.pointer = wrq + 1;
- strcpy(wrq->u.data.pointer, "ASCII_CMD=AP_CFG,");
- snprintf(str_tmp, 64, "SSID=%s,", name);
- strcat(wrq->u.data.pointer, str_tmp);
- if (key_type == KEY_NONE)
- strcpy(str_tmp, "SEC=open,");
- else if (key_type == KEY_WEP)
- strcpy(str_tmp, "SEC=wep128,");
- else if (key_type == KEY_WPA)
- strcpy(str_tmp, "SEC=wpa-psk,");
- else if (key_type == KEY_WPA2)
- strcpy(str_tmp, "SEC=wpa2-psk,");
- else
- snprintf(str_tmp, 64, "KEY=%s,", key);
- snprintf(str_tmp, 64, "CHANNEL=%d,", channel);
- snprintf(str_tmp, 64, "MAX_SCB=%d,", max_client);
- strcat(wrq->u.data.pointer, "END");
- wrq->u.data.length = strlen(wrq->u.data.pointer);
- ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, WOAL_UAP_FROYO_AP_SET_CFG);
- if(ret == 0)
- ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, 0, WOAL_UAP_FROYO_AP_BSS_START);
- mem_free(wrq);
- }else
- return ret;
- int wifi_stop_ap()
- int ret = -1;
- ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, 0, WOAL_UAP_FROYO_AP_BSS_STOP);
- return ret;
- * @brief
- int wifi_join_adhoc(char *ssid, char *key, int ch)
- int ret = -1;
- struct cfg80211_ibss_params params;
- struct ieee80211_channel channel;
- int key_len = strlen(key);
- memset(¶ms, 0, sizeof(struct cfg80211_ibss_params));
- memset(&channel, 0 ,sizeof(struct ieee80211_channel));
- params.channel = &channel;
- params.beacon_interval = 100;
- params.ssid = (u8*)ssid;
- params.ssid_len = strlen(ssid);
- params.channel_fixed = TRUE;
- params.channel->band = IEEE80211_BAND_2GHZ;
- params.channel->hw_value = ch;
- params.channel->center_freq = ieee80211_channel_to_frequency(params.channel->hw_value,
- params.channel->band);
- if(key_len)
- params.key = key;
- params.key_len = key_len;
- params.privacy = TRUE; //使能wep加密
- if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->join_ibss)
- ret = wifi_dev->cfg80211_ops->join_ibss(priv->wdev->wiphy, wifi_dev, ¶ms);
- }else
- return ret;
- int wifi_leave_adhoc()
- int ret = -1;
- if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->leave_ibss)
- ret = wifi_dev->cfg80211_ops->leave_ibss(priv->wdev->wiphy, wifi_dev);
- }else
- return ret;
- int wifi_get_sta_list(mlan_ds_sta_list *p_list)
- int ret = -1;
- struct iwreq *wrq = (struct iwreq *)mem_calloc(sizeof(struct iwreq), 1);
- if(wrq)
- wrq->u.data.pointer = p_list;
- ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, UAP_GET_STA_LIST);
- mem_free(wrq);
- }else
- return ret;
- #endif
- struct cfg80211_scan_request *new_scan_req(moal_private *priv, char *ssid, u8_t ssid_len)
- struct wiphy *wiphy = priv->wdev->wiphy;
- struct cfg80211_scan_request *creq = NULL;
- int i, n_channels = 0;
- enum ieee80211_band band;
- for (band = (enum ieee80211_band)0; band < IEEE80211_NUM_BANDS; band++) {
- if (wiphy->bands[band])
- n_channels += wiphy->bands[band]->n_channels;
- p_dbg("_new_connect_scan_req,channels:%d,creq_size:%d\n",n_channels,sizeof(*creq) + sizeof(struct cfg80211_ssid) +
- n_channels * sizeof(void *));
- creq = (struct cfg80211_scan_request *)mem_calloc(sizeof(*creq) + sizeof(struct cfg80211_ssid) +
- n_channels * sizeof(void *),1);
- if (!creq)
- return NULL;
- /* SSIDs come after channels */
- creq->wiphy = wiphy;
- creq->ssids = (void *)&creq->channels[n_channels];
- creq->n_channels = n_channels;
- if(ssid_len)
- creq->n_ssids = 1;
- /* Scan all available channels */
- i = 0;
- int j;
- if (!wiphy->bands[band])
- continue;
- for (j = 0; j < wiphy->bands[band]->n_channels; j++) {
- /* ignore disabled channels */
- if (wiphy->bands[band]->channels[j].flags &
- IEEE80211_CHAN_DISABLED)
- continue;
- creq->channels[i] = &wiphy->bands[band]->channels[j];
- i++;
- if (i) {
- /* Set real number of channels specified in creq->channels[] */
- creq->n_channels = i;
- /* Scan for the SSID we're going to connect to */
- memcpy(creq->ssids[0].ssid, ssid, ssid_len);
- creq->ssids[0].ssid_len = ssid_len;
- } else {
- /* No channels found... */
- mem_free(creq);
- creq = NULL;
- return creq;
- * @brief 掃描附近的AP,usr_scan_result_callback是我們自定義的一個(gè)回調(diào)接口
- * 每掃描到一個(gè)ap就會(huì)在wlan_ret_802_11_scan->handle_user_scan_result調(diào)用一次,其參數(shù)scan_result_data包含一些基本
- * 的ap信息,一般已經(jīng)夠用,如果要更詳細(xì)的ap的信息請直接在handle_user_scan_result里面取
- * @param
- extern void (*usr_scan_result_callback)(struct scan_result_data *res_data);
- int wifi_scan(void (*scan_result_callback)(struct scan_result_data *res_data),
- char *essid)
- struct cfg80211_scan_request *scan_request;
- if(!wifi_dev)
- return -1;
- p_err("AP模式下不支持scan,請先切換到STA模式");
- return 0;
- usr_scan_result_callback = scan_result_callback;
- scan_request = new_scan_req(priv, essid, strlen(essid));
- wifi_dev->cfg80211_ops->scan(priv->wdev->wiphy, wifi_dev, scan_request);
- //scan是異步實(shí)現(xiàn)的,這里調(diào)用完會(huì)馬上退出
- //掃描完成后驅(qū)動(dòng)會(huì)自動(dòng)調(diào)用cfg80211_scan_done函數(shù)
- return 0;
- * @brief wifi 是否已經(jīng)連接
- int is_wifi_connected()
- int ret = 0;
- if(priv->media_connected)
- ret = 1;
- return ret;
- * @brief wifi連接,驅(qū)動(dòng)自動(dòng)處理加密模式和頻道,用戶只需提供路由器名稱和密碼
- * @param
- * essid: 即AP名稱
- * key: 明文密碼
- int wifi_connect( char *essid, char *key)
- int result_ret = 0;
- int essid_len = strlen(essid);
- struct cfg80211_connect_params *smee = 0;
- p_dbg("enter %s\n", __FUNCTION__);
- OLED_ShowString(0,4,"SSID:");
- OLED_ShowString(0,6,"KEY:");
- OLED_ShowString(48,4,(u8 *)essid);
- OLED_ShowString(48,6,(u8 *)key);
- if(essid_len > 32 || key_len > 32)
- result_ret = -1;
- goto ret;
- smee = (struct cfg80211_connect_params *)mem_malloc(sizeof(struct cfg80211_connect_params));
- if(smee == 0)
- result_ret = -1;
- goto ret;
- memset(smee,0,sizeof(struct cfg80211_connect_params));
- smee->bssid = 0;
- memcpy(smee->ssid,essid,essid_len);
- smee->ssid[essid_len] = 0;
- smee->ssid_len = essid_len;
- memcpy(smee->key,key,key_len);
- smee->key[key_len] = 0;
- smee->key_len = key_len;
- smee->auth_type = NL80211_AUTHTYPE_AUTOMATIC;
- smee->crypto.wpa_versions = NL80211_WPA_VERSION_2;
- smee->crypto.cipher_group = MLAN_ENCRYPTION_MODE_CCMP;
- smee->crypto.n_ciphers_pairwise = 1;
- smee->crypto.ciphers_pairwise[0] = MLAN_ENCRYPTION_MODE_CCMP;
- *smee結(jié)構(gòu)只填充了部分成員,其他成員將在連接的時(shí)候自動(dòng)填充(根據(jù)目標(biāo)ap的信息)
- result_ret = wifi_dev->cfg80211_ops->wifi_connect(priv->wdev->wiphy, wifi_dev,smee);
- ret:
- if(smee)
- mem_free(smee);
- if(result_ret)
- p_err("user_link_app err:%d\n",result_ret);
- p_dbg("exit %s\n", __FUNCTION__);
- return result_ret;
- * @brief 斷開連接
- int wifi_disconnect()
- int ret = -1;
- if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->disconnect)
- ret = wifi_dev->cfg80211_ops->disconnect(priv->wdev->wiphy, wifi_dev, 0);
- }else
- return ret;
- * @brief 讀取mac地址,mac地址從8782芯片讀取
- * @param mac_addr : mac地址 6BYTE
- int wifi_get_mac(unsigned char *mac_addr)
- memcpy(mac_addr, wifi_dev->dev_addr, ETH_ALEN);
- return 0;
- * @brief 獲取WIFI連接的統(tǒng)計(jì)信息(信號(hào)強(qiáng)度...)
- * @param pStats : 指向station_info的指針
- * @param mac : 指向需要獲取的station的地址
- int wifi_get_stats(uint8_t *mac,struct station_info *sinfo)
- int ret = -1;
- if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->get_station)
- ret = wifi_dev->cfg80211_ops->get_station(priv->wdev->wiphy, wifi_dev, mac,sinfo);
- }else
- return ret;
- * @brief 配置省電模式,在保持連接的情況下可達(dá)到很可觀省電效果
- * 省電模式下的耗電量由數(shù)據(jù)收發(fā)量決定
- * 此外用戶可以配置更加細(xì)節(jié)的電源管理參數(shù),比如DTIM間隔
- * 一般情況下使用此函數(shù)已經(jīng)夠用
- * @param power_save_level : 取值 0,1,2;
- * 0代表關(guān)閉省電模式(CAM)
- * 1采用DTIM省電方式
- * 2采用INACTIVITY省電方式
- int wifi_power_cfg(uint8_t power_save_level)
- int ret = -1;
- if(wrq)
- if(sleep)
- deep_sleep_para param;
- memset(¶m, 0, sizeof(deep_sleep_para));
- wrq->u.data.pointer = ¶m;
- param.subcmd = UAP_DEEP_SLEEP;
- param.action = MLAN_ACT_SET;
- param.deep_sleep = TRUE;
- param.idle_time = 1000;
- ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, UAP_IOCTL_CMD);
- }else
- mlan_ds_ps_mgmt ps_mgmt;
- memset(&ps_mgmt, 0, sizeof(mlan_ds_ps_mgmt));
- wrq->u.data.pointer = &ps_mgmt;
- ps_mgmt.flags = PS_FLAG_PS_MODE;
- if(power_save_level == 0)
- ps_mgmt.ps_mode = PS_MODE_DISABLE;
- else if(power_save_level == 1)
- ps_mgmt.ps_mode = PS_MODE_PERIODIC_DTIM;
- else if(power_save_level == 2)
- ps_mgmt.ps_mode = PS_MODE_INACTIVITY;
- else
- ret = wifi_dev->netdev_ops->ndo_do_ioctl(wifi_dev, (void*)wrq, UAP_POWER_MODE);
- mem_free(wrq);
- if(priv->bss_role == MLAN_BSS_ROLE_STA)
- if(wifi_dev->cfg80211_ops && wifi_dev->cfg80211_ops->set_power_mgmt)
- bool enable;
- enable = FALSE;
- else
- enable = TRUE;
- ret = wifi_dev->cfg80211_ops->set_power_mgmt(priv->wdev->wiphy, wifi_dev,enable, 0);
- return ret;
- * @brief 這里不再提供WIFI事件的回調(diào)
- * ap模式下請參考wlan_ops_uap_process_event函數(shù)
- * sta模式下請參考wlan_ops_sta_process_event函數(shù)
- int event_callback(int type)
- return 0;
- extern uint8_t g_mac_addr[6];
- * @brief 通過CPU_ID計(jì)算出一個(gè)隨機(jī)數(shù)用于填充MAC地址的低3字節(jié)
- int create_mac(unsigned char *mac)
- char psk[33], id[12];
無線遙控器設(shè)計(jì).zip
(9.01 MB, 下載次數(shù): 47)
2018-3-7 11:20 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
