銳捷交換機(jī)命令與思科的極其相似
1. 靜態(tài)配置命令格式如下: 對(duì)于R1 Router>e Router#conf Configuring from terminal, memory, or network [terminal]? Enter configuration commands, one per line. End with CNTL/Z. Router(config)#ip route 192.168.3.0 255.255.255.0 192.168.2.2 ip route +目的網(wǎng)段+目的網(wǎng)段的子網(wǎng)掩碼+下一跳IP 查看配置情況 特權(quán)模式下 Router#show ip route 其他的路由同理配置 2. RIP 動(dòng)態(tài)路由配置命令 network +相鄰網(wǎng)段 Router#config Configuring from terminal, memory, or network [terminal]? Enter configuration commands, one per line. End with CNTL/Z. Router(config)#router ri Router(config-router)#network 192.168.1.0 Router(config-router)#network 192.168.2.0 Router#write Building configuration... [OK] 第2頁 /(共3頁) 查看命令 Router#show ip route Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area * - candidate default, U - per-user static route, o - ODR P - periodic downloaded static route Gateway of last resort is not set C 192.168.1.0/24 is directly connected, FastEthernet0/0 C 192.168.2.0/24 is directly connected, FastEthernet0/1 S 192.168.3.0/24 [1/0] via 192.168.2.2 R 192.168.4.0/24 [120/2] via 192.168.2.2, 00:00:19, FastEthernet0/1 3.查看pc 互ping的情況
注意:在做的時(shí)候,動(dòng)態(tài)配置的時(shí)候,只有全部路由都配置好以后,在查看的時(shí)候才能顯示出來。 第3頁 /(共3頁) 查看命令 Router#show ip route Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area * - candidate default, U - per-user static route, o - ODR P - periodic downloaded static route Gateway of last resort is not set C 192.168.1.0/24 is directly connected, FastEthernet0/0 C 192.168.2.0/24 is directly connected, FastEthernet0/1 S 192.168.3.0/24 [1/0] via 192.168.2.2 R 192.168.4.0/24 [120/2] via 192.168.2.2, 00:00:19, FastEthernet0/1 3.查看pc 互ping的情況
