查看: 2898|回復(fù): 1
ADX345直接輸出角度值C51程序
ID:290293 發(fā)表于 2018-3-11 09:39 | 顯示全部樓層 |閱讀模式
#include  <REG51.H>
#include  <math.h>    //Keil library
#include  <stdio.h>   //Keil library
#include  <INTRINS.H>
#define   uchar unsigned char
#define   uint unsigned int
#define   DataPort P0    //LCD1602數(shù)據(jù)端口
sbit    SCL=P1^0;     //IIC時(shí)鐘引腳定義
sbit          SDA=P1^1;     //IIC數(shù)據(jù)引腳定義
sbit      LCM_RS=P2^0;   //LCD1602命令端口
sbit      LCM_RW=P2^1;   //LCD1602命令端口
sbit      LCM_EN=P2^2;   //LCD1602命令端口
#define    SlaveAddress   0xA6     //定義器件在IIC總線中的從地址,根據(jù)ALT  ADDRESS地址引腳不同修改
                             //ALT  ADDRESS引腳接地時(shí)地址為0xA6,接電源時(shí)地址為0x3A
typedef unsigned char  BYTE;
typedef unsigned short WORD;
BYTE BUF[8];                        //接收數(shù)據(jù)緩存區(qū)
uchar ge,shi,bai,qian,wan;          //顯示變量
int  dis_data;                       //變量
int  data_xyz[3];
void delay(unsigned int k);
void InitLcd();                     //初始化lcd1602
void Init_ADXL345(void);            //初始化ADXL345
void WriteDataLCM(uchar dataW);
void WriteCommandLCM(uchar CMD,uchar Attribc);
void DisplayOneChar(uchar X,uchar Y,uchar DData);
void conversion(uint temp_data);
void Single_Write_ADXL345(uchar REG_Address,uchar REG_data);   //單個(gè)寫(xiě)入數(shù)據(jù)
uchar Single_Read_ADXL345(uchar REG_Address);                   //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
void Multiple_Read_ADXL345();                                  //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
void Delay5us();
void Delay5ms();
void ADXL345_Start();
void ADXL345_Stop();
void ADXL345_SendACK(bit ack);
bit  ADXL345_RecvACK();
void ADXL345_SendByte(BYTE dat);
BYTE ADXL345_RecvByte();
void ADXL345_ReadPage();
void ADXL345_WritePage();
    wan=temp_data/10000+0x30 ;
   temp_data=temp_data%10000;   //取余運(yùn)算
       qian=temp_data/1000+0x30;
   temp_data=temp_data%1000;    //取余運(yùn)算
   bai=temp_data/100+0x30   ;
    temp_data=temp_data%100;     //取余運(yùn)算
    shi=temp_data/10+0x30    ;
   temp_data=temp_data%10;      //取余運(yùn)算
    ge=temp_data+0x30;
unsigned int i,j;
for(i=0;i<k;i++)
for(j=0;j<121;j++)
void WaitForEnable(void)
DataPort=0xff;
LCM_RS=0;LCM_RW=1;_nop_();
LCM_EN=1;_nop_();_nop_();
while(DataPort&0x80);
LCM_EN=0;
if(Attribc)WaitForEnable();
LCM_RS=0;LCM_RW=0;_nop_();
DataPort=CMD;_nop_();
LCM_EN=1;_nop_();_nop_();LCM_EN=0;
WaitForEnable();
LCM_RS=1;LCM_RW=0;_nop_();
DataPort=dataW;_nop_();
void InitLcd()               //液晶顯示器的設(shè)置
WriteCommandLCM(0x38,1);
WriteCommandLCM(0x08,1);
WriteCommandLCM(0x01,1);
WriteCommandLCM(0x06,1);
WriteCommandLCM(0x0c,1);
Y&=1;
X&=15;
if(Y)X|=0x40;
X|=0x80;
WriteCommandLCM(X,0);
WriteDataLCM(DData);
延時(shí)5微秒(STC90C52RC@12M)
不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過(guò)快時(shí)需要修改
當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
void Delay5us()
   _nop_();_nop_();_nop_();_nop_();
延時(shí)5毫秒(STC90C52RC@12M)
void Delay5ms()
    WORD n = 560;
    while (n--);
起始信號(hào)
    SDA = 1;                    //拉高數(shù)據(jù)線
    SCL = 1;                    //拉高時(shí)鐘線
    Delay5us();                 //延時(shí)
    SDA = 0;                    //產(chǎn)生下降沿
    SCL = 0;                    //拉低時(shí)鐘線
停止信號(hào)
void ADXL345_Stop()
    SDA = 0;                    //拉低數(shù)據(jù)線
    SDA = 1;                    //產(chǎn)生上升沿
發(fā)送應(yīng)答信號(hào)
入口參數(shù):ack (0:ACK 1:NAK)
    SDA = ack;                  //寫(xiě)應(yīng)答信號(hào)
接收應(yīng)答信號(hào)
    CY = SDA;                   //讀應(yīng)答信號(hào)
    return CY;
向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
    BYTE i;
    for (i=0; i<8;i++)         //8位計(jì)數(shù)器
        dat <<= 1;              //移出數(shù)據(jù)的最高位
        SDA = CY;               //送數(shù)據(jù)口
    ADXL345_RecvACK();
從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
    BYTE i;
    BYTE dat = 0;
    SDA = 1;                    //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
        dat <<= 1;
        dat |= SDA;             //讀數(shù)據(jù)
    return dat;
//******單字節(jié)寫(xiě)入*******************************************
    ADXL345_Start();                  //起始信號(hào)
   ADXL345_SendByte(SlaveAddress);  //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
   ADXL345_SendByte(REG_Address);   //內(nèi)部寄存器地址,請(qǐng)參考中文pdf22頁(yè)
   ADXL345_SendByte(REG_data);      //內(nèi)部寄存器數(shù)據(jù),請(qǐng)參考中文pdf22頁(yè)
    ADXL345_Stop();                   //發(fā)送停止信號(hào)
//********單字節(jié)讀取*****************************************
{  uchar REG_data;
   ADXL345_SendByte(REG_Address);                   //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
   ADXL345_SendByte(SlaveAddress+1);        //發(fā)送設(shè)備地址+讀信號(hào)
   REG_data=ADXL345_RecvByte();             //讀出寄存器數(shù)據(jù)
       ADXL345_SendACK(1);
       ADXL345_Stop();                           //停止信號(hào)
    return REG_data;
//連續(xù)讀出ADXL345內(nèi)部加速度數(shù)據(jù),地址范圍0x32~0x37
void Multiple_read_ADXL345(void)
{   uchar i;
   ADXL345_SendByte(0x32);                  //發(fā)送存儲(chǔ)單元地址,從0x32開(kāi)始
        for (i=0; i<6; i++)                      //連續(xù)讀取6個(gè)地址數(shù)據(jù),存儲(chǔ)中BUF
        BUF =ADXL345_RecvByte();          //BUF[0]存儲(chǔ)0x32地址中的數(shù)據(jù)
        if (i == 5)
           ADXL345_SendACK(1);                //最后一個(gè)數(shù)據(jù)需要回NOACK
         ADXL345_SendACK(0);               //回應(yīng)ACK
    Delay5ms();
//初始化ADXL345,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改************************
void Init_ADXL345()
  Single_Write_ADXL345(0x31,0x0B);  //測(cè)量范圍,正負(fù)16g,13位模式
  Single_Write_ADXL345(0x2C,0x08);  //速率設(shè)定為12.5 參考pdf13頁(yè)
  Single_Write_ADXL345(0x2D,0x08);  //選擇電源模式   參考pdf24頁(yè)
  Single_Write_ADXL345(0x2E,0x80);  //使能 DATA_READY 中斷
  Single_Write_ADXL345(0x1E,0x00);  //X 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
  Single_Write_ADXL345(0x1F,0x00);  //Y 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
  Single_Write_ADXL345(0x20,0x05);  //Z 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
//顯示x軸
void display_x()
{   float temp;
   dis_data=(BUF[1]<<8)+BUF[0]; //合成數(shù)據(jù)
       if(dis_data<0){
       dis_data=-dis_data;
   DisplayOneChar(2,0,'-');      //顯示正負(fù)符號(hào)位
       elseDisplayOneChar(2,0,' '); //顯示空格
   temp=(float)dis_data*3.9;  //計(jì)算數(shù)據(jù)和顯示,查考ADXL345快速入門(mén)第4頁(yè)
    conversion(temp);          //轉(zhuǎn)換出顯示需要的數(shù)據(jù)
       DisplayOneChar(0,0,'X');   //第0行,第0列 顯示X
    DisplayOneChar(1,0,':');
    DisplayOneChar(3,0,qian);
       DisplayOneChar(4,0,'.');
    DisplayOneChar(5,0,bai);
    DisplayOneChar(6,0,shi);
       DisplayOneChar(7,0,'g');
//顯示y軸
void display_y()
{     float temp;
    dis_data=(BUF[3]<<8)+BUF[2];  //合成數(shù)據(jù)
       if(dis_data<0){
       dis_data=-dis_data;
   DisplayOneChar(2,1,'-');      //顯示正負(fù)符號(hào)位
       elseDisplayOneChar(2,1,' '); //顯示空格
       DisplayOneChar(0,1,'Y');   //第1行,第0列 顯示y
    DisplayOneChar(1,1,':');
    DisplayOneChar(3,1,qian);
       DisplayOneChar(4,1,'.');
    DisplayOneChar(5,1,bai);
   DisplayOneChar(6,1,shi);
       DisplayOneChar(7,1,'g');
//顯示z軸
void display_z()
{      float temp;
   dis_data=(BUF[5]<<8)+BUF[4];   //合成數(shù)據(jù)
       if(dis_data<0){
       dis_data=-dis_data;
   DisplayOneChar(10,1,'-');       //顯示負(fù)符號(hào)位
       elseDisplayOneChar(10,1,' ');  //顯示空格
       DisplayOneChar(10,0,'Z');  //第0行,第10列 顯示Z
    DisplayOneChar(11,0,':');
    DisplayOneChar(11,1,qian);
       DisplayOneChar(12,1,'.');
    DisplayOneChar(13,1,bai);
    DisplayOneChar(14,1,shi);
       DisplayOneChar(15,1,'g');
//******主程序********
  uchar devid;
float Roll,Pitch,Q,T,K;
  delay(500);                    //上電延時(shí)
  InitLcd();                      //液晶初始化ADXL345
  Init_ADXL345();                 //初始化ADXL345
devid=Single_Read_ADXL345(0X00);//讀出的數(shù)據(jù)為0XE5,表示正確
  while(1)                         //循環(huán)
   Multiple_Read_ADXL345();       //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
data_xyz[0]=(BUF[1]<<8)+BUF[0];  //合成數(shù)據(jù)
data_xyz[1]=(BUF[3]<<8)+BUF[2];  //合成數(shù)據(jù)
data_xyz[2]=(BUF[5]<<8)+BUF[4];  //合成數(shù)據(jù)
//分別是加速度X,Y,Z的原始數(shù)據(jù),10位的
Q=(float)data_xyz[0]*3.9;
T=(float)data_xyz[1]*3.9;
K=(float)data_xyz[2]*3.9;
Q=-Q;
Roll=(float)(((atan2(K,Q)*180)/3.14159265)+180);    //X軸角度值
Pitch=(float)(((atan2(K,T)*180)/3.14159265)+180);  //Y軸角度值
    conversion(Roll);          //轉(zhuǎn)換出顯示需要的數(shù)據(jù)X軸,或者Y軸
    DisplayOneChar(9,1,'A');
       DisplayOneChar(10,1,':');
    DisplayOneChar(11,1,bai);
    DisplayOneChar(12,1,shi);
       DisplayOneChar(13,1,ge);
    delay(200);                    //延時(shí)
ID:501960 發(fā)表于 2019-3-31 20:25 | 顯示全部樓層
為什么我的單片機(jī)不顯示示數(shù)
