ADXL重力加速度傳感器實(shí)現(xiàn)計(jì)步器程序,利用MSP430F135實(shí)現(xiàn),代碼功能完整。
可用按鍵控制。
- //存儲(chǔ)器沒(méi)有文件系統(tǒng),一次采集,一次上載
- #include "delay.h"
- #include "Key.h"
- #include <msp430x13x.h>
- #include <string.h>
- #include <math.h>
- #include <stdio.h>
- #include"ADC12.h"
- #include "hzlib.h"
- #include "LCD.h"
- #include "SD2608.h"
- #define MEM_IN 0x02 //P3.1
- #define MEM_OUT 0x04 //P3.2
- #define SCLK 0x08 //P3.3
- #define ATRDY 0x40 //AT45DB161 RDY/BUSY P2.6
- #define ATCS 0x80 //AT45DB161 AT/CS P2.7
- #define TIME_MS 10000 //采樣頻率為100
- #define X_CHANNEL 0
- #define Y_CHANNEL 1
- #define Z_CHANNEL 2
- //#define TIMEWINDOW_MIN 8 //時(shí)間窗,×0.02s=0.2s
- //#define TIMEWINDOW_MAX 30 //時(shí)間窗,×0.02s=0.8s
- #define REGULATION 8 //認(rèn)為找到穩(wěn)定規(guī)律所需要的步數(shù)
- unsigned char itemp,jtemp,temp;
- unsigned char TIMEWINDOW_MIN =11; //時(shí)間窗,×0.02s=0.2
- unsigned char TIMEWINDOW_MAX =30 ; //時(shí)間窗,×0.02s=0.8s
- unsigned int Adresult;
- unsigned char _bad_flag[3];
- unsigned char sampling_counter;
- unsigned int _adresult[3];
- unsigned int _max[3]={0,0,0};
- unsigned int _min[3]={5000,5000,5000};
- unsigned int _dc[3]={500,500,500};
- unsigned int _vpp[3]={30,30,30};
- unsigned int _precision[3]={5,5,5};
- unsigned int _old_fixed[3];
- unsigned int _new_fixed[3];
- unsigned long int STEPS;
- unsigned long int STEPS_Temp;
- unsigned int _array0[3]={1,1,1};
- unsigned int _array1[3]={1,1,1};
- unsigned int _array2[3]={0,0,0};
- unsigned int _array3[3]={0,0,0};
- unsigned int _array4[3]={0,0,0};
- unsigned int ADXYZ[3] ;
- unsigned long int totalxyz[3];
- unsigned int averagexyz[3];
- unsigned char avxyz;
- unsigned char counter;
- unsigned char counterx=0;
- unsigned char countery=0;
- unsigned char counterz=0;
- unsigned char Interval=0; //記錄時(shí)間間隔數(shù)
- unsigned char TempSteps=0; //記步緩存
- unsigned char InvalidSteps=0; //無(wú)效步緩存
- unsigned char ReReg=1;
- // 1-已經(jīng)開(kāi)始,但是還沒(méi)有找到規(guī)律
- // 0-已經(jīng)找到規(guī)律
- unsigned char high_or_low=0,k=0;
- unsigned char recieve;
- unsigned char date[7];
- unsigned char wdata[7]={0,0,128,0,1,1,0};
- void fnClkInit(void)
- unsigned int a;
- WDTCTL = WDTPW +WDTHOLD; //關(guān)閉看門(mén)狗
- BCSCTL1|=XTS; //XT1口為高頻 XTS=1,ACLK = LFXT1
- do
- IFG1&=~OFIFG; //清除振蕩器失效標(biāo)志
- for (a=0xFF;a>0;a--); //延時(shí) 等待XT1口起振
- while ((IFG1&OFIFG)!=0); //判斷XT1口是否起振
- BCSCTL2 |= SELM_3; //選擇LFXT1CLK為MCLK時(shí)鐘源
- BCSCTL1 |= XT2OFF+DIVA0+DIVA1; //禁止XT2口 ACLK 8分頻
- /*******************定時(shí)器初始化定時(shí)5MS*******************/
- void TimerBInit(void)
- TBCTL = TBSSEL_1 + TBCLR ; //ACLK為定時(shí)器時(shí)鐘
- TBCCTL0 = CCIE; //開(kāi)定時(shí)器中斷
- TBCCR0 = TIME_MS; //5MS
- //TBCTL |= MC0; //增計(jì)數(shù)模式
- void main(void)
- fnClkInit();
- TimerBInit();
- //usart_Init();
- Init_ADC();
- Init_keyPort();
- vdLCD_Init();
- vdDisp_Main();
- clock();
- _EINT();
- while(1)
- Iskey ();
- vdDisp_bushu(STEPS);
- #pragma vector=TIMERB0_VECTOR
- __interrupt void Timer_B (void)
- ADC12CTL0 &= ~ENC;
- if(recieve==0x04)
- //----------------------------------------------ADC采樣----------------------//
- ADXYZ[0] =ADC12MEM0;//AX
- ADXYZ[1]=ADC12MEM1;//AY
- ADXYZ[2]=ADC12MEM2;//AZ
- //----------------------------------------------開(kāi)機(jī)求平均值判斷放置位置----------------------//
- if(avxyz==0)
- counter=counter+1;
- totalxyz[0]=totalxyz[0]+ADXYZ[0];
- totalxyz[1]=totalxyz[1]+ADXYZ[1];
- totalxyz[2]=totalxyz[2]+ADXYZ[2];
- if(counter>=40)
- counter=0;
- counterx=0;
- countery=0;
- counterz=0;
- averagexyz[0]= (int)(totalxyz[0]/40);
- averagexyz[1]= (int)(totalxyz[1]/40);
- averagexyz[2]= (int)(totalxyz[2]/40);
- totalxyz[0]=0;
- totalxyz[1]=0;
- totalxyz[2]=0;
- avxyz=1;
- //----------------------------------------------x方向?yàn)榇怪蔽恢?---------------------//
- if (( averagexyz[0]>= averagexyz[1])&&( averagexyz[0]>= averagexyz[2])&& (averagexyz[0]>3500))
- counterx=1;
- countery=0;
- counterz=0;
- else if (( averagexyz[0]<= averagexyz[1])&&( averagexyz[0]<= averagexyz[2])&& (averagexyz[0]<1800))
- counterx=1;
- countery=0;
- counterz=0;
- //----------------------------------------------y方向?yàn)榇怪蔽恢?---------------------//
- else if (( averagexyz[1]>= averagexyz[0])&&( averagexyz[1]>= averagexyz[2])&& (averagexyz[1]>3500))
- counterx=0;
- countery=1;
- counterz=0;
- else if(( averagexyz[1]<= averagexyz[0])&&( averagexyz[1]<= averagexyz[2])&& (averagexyz[1]<1800))
- counterx=0;
- countery=1;
- counterz=0;
- //----------------------------------------------z方向?yàn)榇怪蔽恢?---------------------//
- else if (( averagexyz[2]>= averagexyz[0])&&( averagexyz[2]>= averagexyz[1])&& (averagexyz[2]>3500))
- counterx=0;
- countery=0;
- counterz=1;
- else if (( averagexyz[2]<= averagexyz[0])&&( averagexyz[2]<= averagexyz[1])&& (averagexyz[2]<1800))
- counterx=0;
- countery=0;
- counterz=1;
- //----------------------------------------------未能確定方向重現(xiàn)找----------------------//
- else
- avxyz=0;
- //----------------------------------------------加速度濾波----------------------//
- if(avxyz==1)
- for(jtemp=X_CHANNEL;jtemp<=Z_CHANNEL;jtemp++)
- _array4[jtemp]=_array3[jtemp];
- _array3[jtemp]=_array2[jtemp];
- _array2[jtemp]=_array1[jtemp];
- _array1[jtemp]=_array0[jtemp];
- _array0[jtemp]= ADXYZ[jtemp];
- _adresult[jtemp]=_array0[jtemp]+_array1[jtemp]+_array2[jtemp]+_array3[jtemp]+_array4[jtemp];
- _adresult[jtemp]=_adresult[jtemp]/5;
- if (_adresult[jtemp]>_max[jtemp]) {_max[jtemp]=_adresult[jtemp];}
- if (_adresult[jtemp]<_min[jtemp]) {_min[jtemp]=_adresult[jtemp];}
- sampling_counter=sampling_counter+1;
- Interval=Interval+1;
- //----------------------------------計(jì)算動(dòng)態(tài)門(mén)限和動(dòng)態(tài)精度-----------------------//
- if (sampling_counter==50)
- sampling_counter=0;
- _vpp[jtemp]=_max[jtemp]-_min[jtemp];
- _dc[jtemp]=_min[jtemp]+_vpp[jtemp]/2;
- _max[jtemp]=0;
- _min[jtemp]=5000;
- _bad_flag[jtemp]=0;
- if (_vpp[jtemp]>=1000)
- TIMEWINDOW_MIN =20;
- TIMEWINDOW_MAX =60;
- _precision[jtemp]=40;
- else if ((_vpp[jtemp]>=400)&& (_vpp[jtemp]<1000))
- TIMEWINDOW_MIN =25;
- TIMEWINDOW_MAX =70;
- _precision[jtemp]=20;
- else if ((_vpp[jtemp]>=200) && (_vpp[jtemp]<400))
- TIMEWINDOW_MIN =35;
- TIMEWINDOW_MAX =80;
- _precision[jtemp]=10;
- else
- _precision[jtemp]=2;
- _bad_flag[jtemp]=1;
- //--------------------------線性移位寄存器--------------------------------------//
- _old_fixed[jtemp]=_new_fixed[jtemp];
- if (_adresult[jtemp]>=_new_fixed[jtemp])
- if((_adresult[jtemp]-_new_fixed[jtemp])>=_precision[jtemp])
- _new_fixed[jtemp]=_adresult[jtemp];
- if (_adresult[jtemp]<_new_fixed[jtemp])
- if((_new_fixed[jtemp]-_adresult[jtemp])>=_precision[jtemp])
- //------------------------- 動(dòng)態(tài)門(mén)限判決 ----------------------------------
- if(counterx==1)
- if ((_old_fixed[X_CHANNEL]>=_dc[X_CHANNEL])&&(_new_fixed[X_CHANNEL]<_dc[X_CHANNEL])&&(_bad_flag[X_CHANNEL]==0))
- if((Interval>=TIMEWINDOW_MIN)&&(Interval<=TIMEWINDOW_MAX)) //如果時(shí)間間隔在有效的時(shí)間窗內(nèi)
- if(ReReg==1) //如果還沒(méi)有找到規(guī)律
- TempSteps++; //記步緩存加1
- if(TempSteps>=REGULATION) //如果記步緩存達(dá)到所要求的規(guī)律數(shù)
- ReReg=0; //已經(jīng)找到規(guī)律
- STEPS=STEPS+TempSteps; //更新顯示
- TempSteps=0;
- Interval=0;
- else if(ReReg==0) //如果已經(jīng)找到規(guī)律,直接更新顯示
- STEPS++;
- TempSteps=0;
- Interval=0;
- else if(Interval>TIMEWINDOW_MAX) //如果時(shí)間間隔大于時(shí)間窗上限,記步已經(jīng)間斷,重新尋找規(guī)律
- InvalidSteps=0;
- ReReg=1;
- TempSteps=1;
- Interval=0;
- if(countery==1)
- if ((_old_fixed[Y_CHANNEL]>=_dc[Y_CHANNEL])&&(_new_fixed[Y_CHANNEL]<_dc[Y_CHANNEL])&&(_bad_flag[Y_CHANNEL]==0))
- TempSteps=0;
- Interval=0;
- STEPS++;
- TempSteps=0;
- Interval=0;
- InvalidSteps=0;
- ReReg=1;
- TempSteps=1;
- Interval=0;
- if(counterz==1)
- if ((_old_fixed[Z_CHANNEL]>=_dc[Z_CHANNEL])&&(_new_fixed[Z_CHANNEL]<_dc[Z_CHANNEL])&&(_bad_flag[Z_CHANNEL]==0))
ADXL重力加速度傳感器實(shí)現(xiàn)計(jì)步器程序(利用MSP430F135實(shí)現(xiàn)).zip
(120.55 KB, 下載次數(shù): 35)
2018-3-11 19:13 上傳
點(diǎn)擊文件名下載附件
