查看: 3634|回復(fù): 1
OLED9.6液晶屏底層驅(qū)動(dòng)代碼
ID:293298 發(fā)表于 2018-3-17 20:16 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "i2c/bsp_I2C.h"
#include "OLED/bsp_i2c_OLED.h"
#include "OLED/codetab.h"
/* 私有類型定義 --------------------------------------------------------------*//
向OLED寫(xiě)入命令
void WriteCmd(unsigned char I2C_Command)//寫(xiě)命令
write_i2c(OLED_DEV_ADDR,0x00, I2C_Command);
void WriteDat(unsigned char I2C_Data)//寫(xiě)數(shù)據(jù)
write_i2c(OLED_DEV_ADDR,0x40, I2C_Data);
void OLED_Init(void)
  I2C_InitGPIO();
HAL_Delay(100); //這里的延時(shí)很重要
WriteCmd(0xAE); //display off
WriteCmd(0x20); //Set Memory Addressing Mode
WriteCmd(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
WriteCmd(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
WriteCmd(0xc8); //Set COM Output Scan Direction
WriteCmd(0x00); //---set low column address
WriteCmd(0x10); //---set high column address
WriteCmd(0x40); //--set start line address
WriteCmd(0x81); //--set contrast control register
WriteCmd(0xff); //亮度調(diào)節(jié) 0x00~0xff
WriteCmd(0xa1); //--set segment re-map 0 to 127
WriteCmd(0xa6); //--set normal display
WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
WriteCmd(0x3F); //
WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
WriteCmd(0xd3); //-set display offset
WriteCmd(0x00); //-not offset
WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
WriteCmd(0xf0); //--set divide ratio
WriteCmd(0xd9); //--set pre-charge period
WriteCmd(0x22); //
WriteCmd(0xda); //--set com pins hardware configuration
WriteCmd(0x12);
WriteCmd(0xdb); //--set vcomh
WriteCmd(0x20); //0x20,0.77xVcc
WriteCmd(0x8d); //--set DC-DC enable
WriteCmd(0x14); //
WriteCmd(0xaf); //--turn on oled panel
void OLED_SetPos(unsigned char x, unsigned char y) //設(shè)置起始點(diǎn)坐標(biāo)
WriteCmd(0xb0+y);
WriteCmd(((x&0xf0)>>4)|0x10);
WriteCmd((x&0x0f)|0x01);
  * @brief  OLED_Fill,填充整個(gè)屏幕
  * @param  fill_Data:要填充的數(shù)據(jù)
* @retval 無(wú)
  * @brief  OLED_CLS,清屏
  * @param  無(wú)
* @retval 無(wú)
void OLED_CLS(void)//清屏
OLED_Fill(0x00);
  * @brief  OLED_ON,將OLED從休眠中喚醒
  * @param  無(wú)
* @retval 無(wú)
void OLED_ON(void)
WriteCmd(0X8D);  //設(shè)置電荷泵
WriteCmd(0X14);  //開(kāi)啟電荷泵
WriteCmd(0XAF);  //OLED喚醒
  * @brief  OLED_OFF,讓OLED休眠 -- 休眠模式下,OLED功耗不到10uA
  * @param  無(wú)
* @retval 無(wú)
void OLED_OFF(void)
WriteCmd(0X10);  //關(guān)閉電荷泵
WriteCmd(0XAE);  //OLED休眠
void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
unsigned char c = 0,i = 0,j = 0;
switch(TextSize)
  case 1:
   while(ch[j] != '\0')
    c = ch[j] - 32;
    if(x > 126)
     x = 0;
     y++;
    OLED_SetPos(x,y);
    for(i=0;i<6;i++)
     WriteDat(F6x8[c][i]);
    x += 6;
    j++;
  }break;
  case 2:
    c = ch[j] - 32;
    if(x > 120)
     x = 0;
     y++;
    OLED_SetPos(x,y);
    for(i=0;i<8;i++)
     WriteDat(F8X16[c*16+i]);
    OLED_SetPos(x,y+1);
    for(i=0;i<8;i++)
     WriteDat(F8X16[c*16+i+8]);
    x += 8;
    j++;
  }break;
  * @brief  OLED_ShowCN,顯示codetab.h中的漢字,16*16點(diǎn)陣
  * @param  x,y: 起始點(diǎn)坐標(biāo)(x:0~127, y:0~7);
*     N:漢字在codetab.h中的索引
* @retval 無(wú)
void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N)
unsigned char wm=0;
unsigned int  adder=32*N;
OLED_SetPos(x , y);
for(wm = 0;wm < 16;wm++)
  WriteDat(F16x16[adder]);
  adder += 1;
OLED_SetPos(x,y + 1);
  adder += 1;
ID:685056 發(fā)表于 2020-2-8 22:06 | 只看該作者
您好,能問(wèn)問(wèn)WriteDat(F8X16[c*16+i]);
這行代碼是什么意思嗎,我編譯的時(shí)候報(bào)錯(cuò)了TAT
