物聯(lián)網(wǎng)國賽題單片機(jī)源程序如下:
- Filename: ZMain.c
- Revised: $Date: 2009-09-17 20:35:33 -0700 (Thu, 17 Sep 2009) $
- Revision: $Revision: 20782 $
- Description: Startup and shutdown code for ZStack
- Notes: This version targets the Chipcon CC2530
- Copyright 2005-2009 Texas Instruments Incorporated. All rights reserved.
- IMPORTANT: Your use of this Software is limited to those specific rights
- granted under the terms of a software license agreement between the user
- who downloaded the software, his/her employer (which must be your employer)
- and Texas Instruments Incorporated (the "License"). You may not use this
- Software unless you agree to abide by the terms of the License. The License
- limits your use, and you acknowledge, that the Software may not be modified,
- copied or distributed unless embedded on a Texas Instruments microcontroller
- or used solely and exclusively in conjunction with a Texas Instruments radio
- frequency transceiver, which is integrated into your product. Other than for
- the foregoing purpose, you may not use, reproduce, copy, prepare derivative
- works of, modify, distribute, perform, display or sell this Software and/or
- its documentation for any purpose.
- YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
- PROVIDED 揂S IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
- INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
- NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
- TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
- NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
- LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
- INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
- OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
- OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
- (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
- Should you have any questions regarding your right to use this Software,
- contact Texas Instruments Incorporated at www.TI.com.
- * INCLUDES
- #include "ZComDef.h"
- #include "OSAL.h"
- #include "OSAL_Nv.h"
- #include "OnBoard.h"
- #include "ZMAC.h"
- #ifndef NONWK
- #include "AF.h"
- #endif
- /* Hal */
- #include "hal_lcd.h"
- #include "hal_led.h"
- #include "hal_adc.h"
- #include "hal_drivers.h"
- #include "hal_assert.h"
- #include "hal_flash.h"
- * MACROS
- * CONSTANTS
- // Maximun number of Vdd samples checked before go on
- #define MAX_VDD_SAMPLES 3
- #define ZMAIN_VDD_LIMIT HAL_ADC_VDD_LIMIT_4
- * TYPEDEFS
- * GLOBAL VARIABLES
- * EXTERNAL VARIABLES
- * EXTERNAL FUNCTIONS
- extern bool HalAdcCheckVdd (uint8 limit);
- * LOCAL VARIABLES
- * LOCAL FUNCTIONS
- static void zmain_dev_info( void );
- static void zmain_ext_addr( void );
- static void zmain_vdd_check( void );
- #ifdef LCD_SUPPORTED
- static void zmain_lcd_init( void );
- #endif
- void test_sh10(void);
- * @fn main
- * @brief First function called after startup.
- * @return don't care
- int main( void )
- // Turn off interrupts
- osal_int_disable( INTS_ALL );
- // Initialization for board related stuff such as LEDs
- HAL_BOARD_INIT();
- // Make sure supply voltage is high enough to run
- zmain_vdd_check();
- // Initialize board I/O
- InitBoard( OB_COLD );
- // Initialze HAL drivers
- HalDriverInit();
- // Initialize NV System
- osal_nv_init( NULL );
- // Initialize the MAC
- ZMacInit();
- // Determine the extended address
- zmain_ext_addr();
- // Initialize basic NV items
- zgInit();
- #ifndef NONWK
- // Since the AF isn't a task, call it's initialization routine
- afInit();
- #endif
- // Initialize the operating system
- osal_init_system();
- // Allow interrupts
- osal_int_enable( INTS_ALL );
- // Final board initialization
- InitBoard( OB_READY );
- // Display information about this device
- zmain_dev_info();
- /* Display the device info on the LCD */
- zmain_lcd_init();
- #endif
- #ifdef WDT_IN_PM1
- /* If WDT is used, this is a good place to enable it. */
- WatchDogEnable( WDTIMX );
- #endif
- osal_start_system(); // No Return from here
- return 0; // Shouldn't get here.
- } // main()
- * @fn zmain_vdd_check
- * @brief Check if the Vdd is OK to run the processor.
- * @return Return if Vdd is ok; otherwise, flash LED, then reset
- uint8 vdd_passed_count = 0;
- bool toggle = 0;
- // Repeat getting the sample until number of failures or successes hits MAX
- // then based on the count value, determine if the device is ready or not
- while ( vdd_passed_count < MAX_VDD_SAMPLES )
- if ( HalAdcCheckVdd (ZMAIN_VDD_LIMIT) )
- vdd_passed_count++; // Keep track # times Vdd passes in a row
- MicroWait (10000); // Wait 10ms to try again
- else
- vdd_passed_count = 0; // Reset passed counter
- MicroWait (50000); // Wait 50ms
- MicroWait (50000); // Wait another 50ms to try again
- /* toggle LED1 and LED2 */
- if (vdd_passed_count == 0)
- if ((toggle = !(toggle)))
- HAL_TOGGLE_LED1();
- else
- HAL_TOGGLE_LED2();
- /* turn off LED1 */
- HAL_TURN_OFF_LED1();
- HAL_TURN_OFF_LED2();
- * @fn zmain_ext_addr
- * @brief Execute a prioritized search for a valid extended address and write the results
- * into the OSAL NV system for use by the system. Temporary address not saved to NV.
- * input parameters
- * None.
- * output parameters
- * None.
- * @return None.
- static void zmain_ext_addr(void)
- uint8 nullAddr[Z_EXTADDR_LEN] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- uint8 writeNV = TRUE;
- // First check whether a non-erased extended address exists in the OSAL NV.
- if ((SUCCESS != osal_nv_item_init(ZCD_NV_EXTADDR, Z_EXTADDR_LEN, NULL)) ||
- (SUCCESS != osal_nv_read(ZCD_NV_EXTADDR, 0, Z_EXTADDR_LEN, aExtendedAddress)) ||
- (osal_memcmp(aExtendedAddress, nullAddr, Z_EXTADDR_LEN)))
- // Attempt to read the extended address from the location on the lock bits page
- // where the programming tools know to reserve it.
- HalFlashRead(HAL_FLASH_IEEE_PAGE, HAL_FLASH_IEEE_OSET, aExtendedAddress, Z_EXTADDR_LEN);
- if (osal_memcmp(aExtendedAddress, nullAddr, Z_EXTADDR_LEN))
- // Attempt to read the extended address from the designated location in the Info Page.
- if (!osal_memcmp((uint8 *)(P_INFOPAGE+HAL_INFOP_IEEE_OSET), nullAddr, Z_EXTADDR_LEN))
- osal_memcpy(aExtendedAddress, (uint8 *)(P_INFOPAGE+HAL_INFOP_IEEE_OSET), Z_EXTADDR_LEN);
- else // No valid extended address was found.
- uint8 idx;
- #if !defined ( NV_RESTORE )
- writeNV = FALSE; // Make this a temporary IEEE address
- #endif
- /* Attempt to create a sufficiently random extended address for expediency.
- * Note: this is only valid/legal in a test environment and
- * must never be used for a commercial product.
- for (idx = 0; idx < (Z_EXTADDR_LEN - 2);)
- uint16 randy = osal_rand();
- aExtendedAddress[idx++] = LO_UINT16(randy);
- aExtendedAddress[idx++] = HI_UINT16(randy);
- // Next-to-MSB identifies ZigBee devicetype.
- #if ZG_BUILD_COORDINATOR_TYPE && !ZG_BUILD_JOINING_TYPE
- aExtendedAddress[idx++] = 0x10;
- #elif ZG_BUILD_RTRONLY_TYPE
- aExtendedAddress[idx++] = 0x20;
- #else
- aExtendedAddress[idx++] = 0x30;
- #endif
- // MSB has historical signficance.
- aExtendedAddress[idx] = 0xF8;
- if (writeNV)
- (void)osal_nv_write(ZCD_NV_EXTADDR, 0, Z_EXTADDR_LEN, aExtendedAddress);
- // Set the MAC PIB extended address according to results from above.
- (void)ZMacSetReq(MAC_EXTENDED_ADDRESS, aExtendedAddress);
- * @fn zmain_dev_info
- * @brief This displays the IEEE (MSB to LSB) on the LCD.
- * None.
- * None.
- * @return None.
- static void zmain_dev_info(void)
- uint8 i;
- uint8 *xad;
- uint8 lcd_buf[Z_EXTADDR_LEN*2+1];
- // Display the extended address.
- xad = aExtendedAddress + Z_EXTADDR_LEN - 1;
- for (i = 0; i < Z_EXTADDR_LEN*2; xad--)
- uint8 ch;
- ch = (*xad >> 4) & 0x0F;
- lcd_buf[i++] = ch + (( ch < 10 ) ? '0' : '7');
- ch = *xad & 0x0F;
- lcd_buf[Z_EXTADDR_LEN*2] = '\0';
- HalLcdWriteString( "IEEE: ", HAL_LCD_LINE_1 );
- HalLcdWriteString( (char*)lcd_buf, HAL_LCD_LINE_2 );
- #endif
- * @fn zmain_lcd_init
- * @brief Initialize LCD at start up.
- * @return none
- static void zmain_lcd_init ( void )
- #ifdef SERIAL_DEBUG_SUPPORTED
- HalLcdWriteString( "TexasInstruments", HAL_LCD_LINE_1 );
- #if defined( MT_MAC_FUNC )
- #if defined( ZDO_COORDINATOR )
- HalLcdWriteString( "MAC-MT Coord", HAL_LCD_LINE_2 );
- #else
- HalLcdWriteString( "MAC-MT Device", HAL_LCD_LINE_2 );
- #endif // ZDO
- #elif defined( MT_NWK_FUNC )
- HalLcdWriteString( "NWK Coordinator", HAL_LCD_LINE_2 );
- #else
- HalLcdWriteString( "NWK Device", HAL_LCD_LINE_2 );
- #endif // ZDO
- #endif // MT_FUNC
- #endif // SERIAL_DEBUG_SUPPORTED
- #endif
題3.rar
(6.24 MB, 下載次數(shù): 6)
2018-3-18 11:14 上傳
點擊文件名下載附件
物聯(lián)網(wǎng)國賽賽題 下載積分: 黑幣 -5
