查看: 2360|回復(fù): 3
關(guān)于89C52單片機(jī)串行通信的數(shù)據(jù)定時(shí)發(fā)送要怎么實(shí)現(xiàn)呢?
ID:296121 發(fā)表于 2018-3-23 21:02 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
    我是進(jìn)行了一點(diǎn)基礎(chǔ)學(xué)習(xí)的單片機(jī)的小白一枚,但是現(xiàn)在有項(xiàng)目急需使用到單片機(jī)的串行通信。想請(qǐng)教各位數(shù)據(jù)定時(shí)發(fā)送要怎樣在單片機(jī)中實(shí)現(xiàn)呢?
    是使用串口通信中斷實(shí)現(xiàn)還是直接用定時(shí)器中斷就能實(shí)現(xiàn)呢?定時(shí)的要求比較高,每10ms能從串口發(fā)送一次數(shù)據(jù)出去。各位大佬支支招!
ID:287575 發(fā)表于 2018-3-23 22:41 | 只看該作者
每10MS發(fā)一次數(shù)據(jù),當(dāng)然用定時(shí)器中斷了
ID:237354 發(fā)表于 2018-3-23 23:10 | 只看該作者
既然定時(shí)要求高當(dāng)然要用定時(shí)器,在中斷代碼中發(fā)串口數(shù)據(jù)
#include "reg51.h"
#include "intrins.h"
sfr T2CON  = 0xC8;          //timer2 control register
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2    = 0xCC;
sfr TH2    = 0xCD;
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 18432000L      //System frequency
#define BAUD 115200       //UART baudrate
/*Define UART parity mode*/
#define NONE_PARITY     0   //None parity
#define ODD_PARITY      1   //Odd parity
#define EVEN_PARITY     2   //Even parity
#define MARK_PARITY     3   //Mark parity
#define SPACE_PARITY    4   //Space parity
#define PARITYBIT EVEN_PARITY   //Testing even parity
sbit bit9 = P2^2;           //P2.2 show UART data bit9
bit busy;
void SendData(BYTE dat);
void SendString(char *s);
#if (PARITYBIT == NONE_PARITY)
    SCON = 0x50;            //8-bit variable UART
#elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
    SCON = 0xda;            //9-bit variable UART, parity bit initial to 1
#elif (PARITYBIT == SPACE_PARITY)
    SCON = 0xd2;            //9-bit variable UART, parity bit initial to 0
#endif
    TL2 = RCAP2L = (65536-(FOSC/32/BAUD)); //Set auto-reload vaule
    TH2 = RCAP2H = (65536-(FOSC/32/BAUD)) >> 8;
    T2CON = 0x34;           //Timer2 start run
    ES = 1;                 //Enable UART interrupt
    EA = 1;                 //Open master interrupt switch
    SendString("STC89-90xx\r\nUart Test !\r\n");
    while(1);
UART interrupt service routine
void Uart_Isr() interrupt 4 using 1
    if (RI)
        RI = 0;             //Clear receive interrupt flag
        P0 = SBUF;          //P0 show UART data
        bit9 = RB8;         //P2.2 show parity bit
    if (TI)
        TI = 0;             //Clear transmit interrupt flag
        busy = 0;           //Clear transmit busy flag
Send a byte data to UART
Input: dat (data to be sent)
Output:None
    while (busy);           //Wait for the completion of the previous data is sent
    ACC = dat;              //Calculate the even parity bit P (PSW.0)
    if (P)                  //Set the parity bit according to P
#if (PARITYBIT == ODD_PARITY)
        TB8 = 0;            //Set parity bit to 0
#elif (PARITYBIT == EVEN_PARITY)
        TB8 = 1;            //Set parity bit to 1
#endif
#endif
    busy = 1;
    SBUF = ACC;             //Send data to UART buffer
Send a string to UART
Input: s (address of string)
Output:None
    while (*s)              //Check the end of the string
        SendData(*s++);     //Send current char and increment string ptr
ID:296121 發(fā)表于 2018-3-25 15:05 | 只看該作者
zhangxiaozi 發(fā)表于 2018-3-23 22:41
那數(shù)據(jù)發(fā)送要怎么實(shí)現(xiàn)呢?
