查看: 1849|回復(fù): 0
mfrc522 51單片機(jī)代碼
ID:290546 發(fā)表于 2018-3-24 17:26 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
/**********************RC522實(shí)驗(yàn)開(kāi)發(fā)板例程************************
*  CPU:STC89C52RC
*  晶振:11.0592MHZ
#include <reg52.h>
#include  <STDIO.H>
#include <string.h>
#include "main.h"
#include "mfrc522.h"
#include<intrins.h>
unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
//M1卡的某一塊寫(xiě)為如下格式,則該塊為錢(qián)包,可接收扣款和充值命令
//4字節(jié)金額(低字節(jié)在前)+4字節(jié)金額取反+4字節(jié)金額+1字節(jié)塊地址+1字節(jié)塊地址取反+1字節(jié)塊地址+1字節(jié)塊地址取反
unsigned char code data2[4]  = {0,0,0,0x01};
unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
unsigned char g_ucTempbuf[20];
void delay1(unsigned int z)
        unsigned int x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void send(char A)//串口發(fā)送程序
        SBUF = A;
        while(!TI)                   //如果發(fā)送完畢,硬件會(huì)置位TI
                _nop_();
        TI = 0;                                //TI清零
void main( )
     unsigned char status,i,j;
          unsigned int temp;
     InitializeSystem( );
     PcdReset();
     PcdAntennaOff();
     PcdAntennaOn();
     while ( 1 )
         status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
         if (status != MI_OK)
     PcdReset();
     PcdAntennaOff();
     PcdAntennaOn();
                          continue;
                printf("卡的類(lèi)型:");
            for(i=0;i<2;i++)
                                                temp=g_ucTempbuf[i];
                                                printf("%X",temp);
         status = PcdAnticoll(g_ucTempbuf);//防沖撞
         {    continue;    }
                                        ////////以下為超級(jí)終端打印出的內(nèi)容////////////////////////
                                //        printf("卡序列號(hào):");        //超級(jí)終端顯示,
                                        for(i=0;i<1;i++)
                                                if(temp==0xE0)
                                                        temp=1;
                                                        send(1);
                                           if(temp==0xB3)
                                                        temp=2;
                                                        send(2);
                                                 if(temp==0x80)
                                                        temp=3;
                                                        send(3);
                                                if(temp==0xC1)
                                                        temp=4;
                                                        send(4);
                                                if(temp==0xA2)
                                                        temp=5;
                                                        send(5);
                                                if(temp==0x24)
                                                        temp=6;
                                                        send(6);
                                                if(temp==0x90)
                                                        temp=7;
                                                        send(7);
                                                if(temp==0x31)
                                                        temp=8;
                                                        send(8);
                                                if(temp==0x63)
                                                        temp=9;
                                                        send(9);
         status = PcdSelect(g_ucTempbuf);//選定卡片
         {    continue;    }
         status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗(yàn)證卡片密碼
         {    continue;    }
         status = PcdWrite(1, data1);//寫(xiě)塊
         {    continue;    }
     PcdReset();
     PcdAntennaOff();
     PcdAntennaOn();
                          continue;
         {    continue;    }
         {    continue;    }
         {    continue;    }
         status = PcdValue(PICC_DECREMENT,1,data2);//扣款
         {    continue;    }
         status = PcdBakValue(1, 2);//塊備份
         {    continue;    }
         status = PcdRead(2, g_ucTempbuf);//讀塊
         {    continue;    }
//                printf("卡讀塊:");        //超級(jí)終端顯示,
//         for(i=0;i<16;i++)
//                                                temp=g_ucTempbuf[i];
//                                                printf("%X",temp);
//                 printf("\n");
                LED_GREEN = 0;
            for(i=0;i<250;i++)//先輸出一種頻率的聲音
         for(j=0;j<80;j++);
         Speaker=~Speaker;
                delay1(100);
                LED_GREEN = 1;
                delay1(100);
                LED_GREEN = 0;
                delay1(200);
                LED_GREEN = 1;
                 PcdHalt();
//系統(tǒng)初始化
void InitializeSystem()
/*        P0M1 = 0x0; P0M2 = 0x0;
        P1M1 = 0x0;        P1M2 = 0x0;
        P3M1 = 0x0; P3M2 = 0xFF;
*/        P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
        TMOD=0x21;                   //設(shè)T0為方式1,GATE=1;
        SCON=0x50;
        TH1=0xF4;          //波特率為2400bps
        TL1=0xF4;
        TH0=0;
        TL0=0;
        TR0=1;
        ET0=1;             //允許T0中斷
        TR1=1;                           //開(kāi)啟定時(shí)器
        TI=1;
        EA=1;                                   //開(kāi)啟總中斷
        ES = 1;
        RI = 1;
MFRC522測(cè)試程序.zip
71.69 KB, 下載次數(shù): 14, 下載積分: 黑幣 -5
