查看: 2534|回復: 4
電子時鐘編程 如有不對請指正 謝謝
ID:296899 發(fā)表于 2018-3-25 20:06 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
sbit key1=P2^0;
sbit key2=P2^1;
sbit key3=P2^2;
uchar num=0,temp=0,count=0;
uchar aa;
uchar hour,min,sec;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void delay(uint z);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f,uchar aa);
void read_key();
void led();
void time_change();
void main()        //主函數(shù)
        P2=0xff;
        hour=12;
        min=0;
        sec=0;
        TMOD=0x11;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TH1=(65536-50000)/256;
        TL1=(65536-50000)%256;
        EA=1;
        ET0=1;
        ET1=1;
        TR0=1;
        TR1=1;
        aa=0xff;
                time_change();
                display(table[hour/10],table[hour%10],table[min/10],table[min%10],table[sec/10],table[sec%10],0xff);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f,uchar aa)        //顯示函數(shù)
         if(num==1){P1=0x01&aa;P0=a;delay(2);}else{P1=0x01;P0=a;delay(2);}   //hour
            if(num==1){P1=0x02&aa;P0=b;delay(2);}else{P1=0x02;P0=b;delay(2);}  //hour
     if(num==2){P1=0x04&aa;P0=c;delay(2);}else{P1=0x04;P0=c;delay(2);} //min
     if(num==2){P1=0x08&aa;P0=d;delay(2);}else{P1=0x08;P0=d;delay(2);} //min
     if(num==3){P1=0x10&aa;P0=e;delay(2);}else{P1=0x10;P0=e;delay(2);} //sec
     if(num==3){P1=0x20&aa;P0=f;delay(2);}else{P1=0x20;P0=f;delay(2);} //sec
void timer0() interrupt 1        //定時器0中斷函數(shù)
        temp++;
void timer1() interrupt 3        //定時器1中斷函數(shù)
        count++;
        if(count>=20)
        count=0;
void delay(uint z)        //延時函數(shù)
        uint j,k;
        for(j=z;j>0;j--)
        for(k=120;k>0;k--);
void read_key()        //讀按鍵函數(shù)
        if(key1==0)
                _led=0;
                delay(100);
                if(key1==0)
                        delay(100);
                        _led=1;
                        num++;
                        if(num>3)
                                num=0;
                                if(key1==0)
                                        _led=0;
                                        delay(10);
                                        if(key1==0)
                                                num++;
                                                if(num>3)
                                                        num=0;
                                                        break;
                                                while(!key1);
                                                delay(10);
                                                while(!key1);
                                                _led=1;
                                        if(key2==0)
                                                _led=0;
                                                delay(80);
                                                if(key2==0)
                                                          if(num==1){hour++;if(hour==24)hour=0;}
                                                          if(num==2){min++;if(min==60)min=0;}
                                                          if(num==3){sec++;if(sec==60)sec=0;}
                                                while(!key1);
                                                delay(10);
                                                while(!key1);
                                                _led=1;
                                        if(key3==0)
                                                _led=0;
                                                delay(80);
                                                if(key3==0)
                                                        if(num==1)
        hour--;
        if(hour==0)
        hour=23;
                                                        if(num==2)
        min--;
        if(min==0)
        min=59;
                                                        if(num==3)
        sec--;
        if(sec==59)
        sec=59;
                                                        while(!key1);
                                                        delay(10);
                                                        while(!key1);
                                                        _led=1;
                                                if(count<=15)
                                                if(count>15)
                                                display(table[hour/10],table[hour%10],table[min/10],table[min%10],table[sec/10],table[sec%10],0x00);
                                while(!key1);
                                delay(10);
                                while(!key1);
                                _led=1;
void time_change()        //時間調(diào)整函數(shù)
        read_key();
        if(temp>=20)
        temp=0;
        sec++;
        if(sec>=60)
                sec=0;
                min++;
                if(min>=60)
                        min=0;
                        hour++;
                        if(hour>=24)
                                hour=0;
參與人數(shù) 3黑幣 +66 收起 理由
jizhongtian + 8 6666666666666666666666666666666666666666
zjzjzjz + 8 很給力!
admin + 50 共享資料的黑幣獎勵!
ID:1 發(fā)表于 2018-3-25 20:17 | 顯示全部樓層
電路圖呢?
ID:296899 發(fā)表于 2018-3-26 18:56 | 顯示全部樓層
話說圖片怎么發(fā)  說是地址  但是地址搞不來
ID:296899 發(fā)表于 2018-3-26 18:59 | 顯示全部樓層
電路圖
電路圖
電路圖
ID:296899 發(fā)表于 2018-3-27 16:15 | 顯示全部樓層
嗯........   我想把 時間之間的0改成-    但是我編程能力還很差  這個編程還是參照別人的才搞出來的...    求大佬幫忙   謝謝!
