查看: 1676|回復(fù): 0
音樂盒程序
ID:253605 發(fā)表于 2018-3-27 15:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
   #include<reg51.h>
   sbit P14=P1^4;
   sbit P15=P1^5;
   sbit P16=P1^6;
   sbit P17=P1^7;
   unsigned char keyval;
   sbit sound =P3^7;
   unsigned int C;
   unsigned int f;
   #define l_dao 262
   #define l_re 286
   #define l_mi 311
   #define l_fa 349
   #define l_sao 392
   #define l_la 440
   #define l_xi 494
   #define dao 523
   #define re 587
   #define mi 659
   #define fa 698
   #define sao 784
   #define la 880
   #define xi 987
   #define h_dao 1046
   #define h_re 1174
   #define h_mi 1318
   #define h_fa 1396
   #define h_sao 1567
   #define h_la 1760
   #define h_xi 1975
   void delay20ms(void)
       unsigned char i,j;
           for(i=0;i<100;i++)
           for(j=0;j<60;j++);
   void delay()
     unsigned char i,j;
         for(i=0;i<250;i++)
           for(j=0;j<250;j++);
         void output_sound(void)
            C=(46083/f)*10;
                TH0=(8192-C)/32;
                TL0=(8192-C)%32;
                TR0=1;
                delay();
                TR0=0;
                sound=1;
                keyval=0xff;
         void main(void)
            EA= 1;
                ET0=1;
                ET1=1;
                TR1=1;
                TMOD=0x10;
                TH1=(65536-500)/256;
                TL1=(65536-500)%256;
                  switch(keyval)
                        case 1:f=dao;
                            output_sound();
                                break;
                                case 2:f=l_xi;
                            output_sound();
                                break;
                                case 3:f=l_la;
                            output_sound();
                                break;
                                case 4:f=l_sao;
                            output_sound();
                                break;
                                case 5:f=sao;
                            output_sound();
                                break;
                                case 6:f=fa;
                            output_sound();
                                break;
                                case 7:f=mi;
                            output_sound();
                                break;
                                case 8:f=re;
                            output_sound();
                                break;
                                case 9:f=h_re;
                            output_sound();
                                break;
                                case 10:f=h_dao;
                            output_sound();
                                break;
                                case 11:f=xi;
                            output_sound();
                                break;
                                case 12:f=la;
                            output_sound();
                                break;
                                case 13:f=h_la;
                            output_sound();
                                break;
                                case 14:f=h_sao;
                            output_sound();
                                break;
                                case 15:f=h_fa;
                            output_sound();
                                break;
                                case 16:f=h_mi;
                            output_sound();
                                break;
        void timer0_serve(void)interrupt 1 using  1
           TH0=(8192-C)/32;
                TL0=(8192-C)%32;
                sound=!sound;
        void timer1_serve(void)interrupt 3 using 2
           TR1=0;
           P1=0xf0;
           if((P1&0xf0)!=0xf0)
           {delay20ms();
           if((P1&0xf0)!=0xf0)
           P1=0xfe;
           if(P14==0)
           keyval=1;
           if(P15==0)
           keyval=2;
           if(P16==0)
           keyval=3;
           if(P17==0)
           keyval=4;
           P1=0xfd;
           if(P14==0)
           keyval=5;
           if(P15==0)
           keyval=6;
           if(P16==0)
           keyval=7;
           if(P17==0)
           keyval=8;
           P1=0xfb;
           if(P14==0)
           keyval=9;
           if(P15==0)
           keyval=10;
           if(P16==0)
           keyval=11;
           if(P17==0)
           keyval=12;
           P1=0xf7;
           if(P14==0)
           keyval=13;
           if(P15==0)
           keyval=14;
           if(P16==0)
           keyval=15;
           if(P17==0)
           keyval=16;
           TR1=1;
