查看: 4620|回復: 2
基于STM32F103C8T6的SHT1X溫濕度監(jiān)測程序,測試通過
ID:99484 發(fā)表于 2018-3-30 16:33 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
基于STM32F103C8T6的溫濕度監(jiān)測程序,測試通過!
單片機源程序如下:
  1. //實驗平臺:ALIENTEK Mini STM32開發(fā)板
  2. //實驗名稱:SHT10溫濕度傳感器顯示實驗
  3. #include "led.h"
  4. #include "delay.h"
  5. #include "sys.h"
  6. #include "usart.h"
  7. #include "lcd.h"
  8. #include "SHT10.h"
  9. SHT1x sht1x; //定義傳感器結構體
  10. int main(void)
  11. {
  12.     u8 t=0,error=0,checksum,value=0;
  13.     volatile u8 T_Display=0,H_Display=0;
  14.     u16 T_Value=0,H_Value=0;
  15.     delay_init(); //延時函數初始化
  16.         uart_init(9600); //USART1初始化
  17.         LED_Init(); //LED初始化
  18.     LCD_Init();
  19.     SHT1x_Init();
  20.
  21.     POINT_COLOR=RED;//設置字體為紅色
  22.         LCD_ShowString(60,120,200,16,16,"SHT1X Test");
  23.         POINT_COLOR=BLUE;//設置字體為藍色
  24.         LCD_ShowString(60,150,200,16,16,"Temp:   .   C");
  25.         LCD_ShowString(60,170,200,16,16,"Humi:   .   %RH");
  26.
  27.     if(!SHT1X_read_statusreg(&value))
  28.     {
  29.         if(value&0x07)
  30.         {
  31.             for(value=5;value!=0;value--)
  32.             {
  33.                 if(!SHT1X_write_statusreg(0))break;
  34.                 else SHT1X_softreset();
  35.             }
  36.         }
  37.     }
  38.         while(1)
  39.         {
  40. //------------------------讀取SHT1X傳感器數據--------------------------------------
  41.         error+=SHT1x_Measure( &T_Value,&checksum,0);  //measure temperature
  42.         error+=SHT1x_Measure( &H_Value,&checksum,1);  //measure humidity
  43.
  44.         if(error!=0)SHT1x_Reset(); //通訊故障,復位傳感器
  45.         else
  46.         {
  47.             sht1x.T_Result = T_Value;
  48.             sht1x.H_Result = H_Value;
  49.             SHT1X_Caculation1((float*)&sht1x.T_Result, (float*)&sht1x.H_Result );
  50.
  51.             sht1x.Temperature=sht1x.T_Result;
  52.             sht1x.Humidity=(u16)sht1x.H_Result;
  53.             sht1x.DEW=SHT1X_dewpoint1(sht1x.T_Result, sht1x.H_Result);
  54.         }
  55. //------------------------------------------------------------------------------
  56.
  57. //顯示函數處理
  58. //-------------------溫度顯示-------------------------------------------------
  59.
  60.         if(sht1x.Temperature<0)
  61.         {
  62.             LCD_ShowChar(60+40,150,'-',16,0);                        //顯示負號
  63.             sht1x.Temperature=-sht1x.Temperature;    //轉為正數
  64.         }
  65.         else LCD_ShowChar(60+40,150,' ',16,0);  //去掉負號
  66.
  67.         LCD_ShowNum(60+40+8,150,sht1x.Temperature/100,2,16);        //顯示正數部分
  68.         if((sht1x.Temperature%100)>=0 && (sht1x.Temperature%100)<=9 )
  69.         {
  70.             LCD_ShowNum(60+40+32,150,sht1x.Temperature%100,1,16);        //顯示小數部分
  71.         }
  72.         else
  73.         {
  74.             LCD_ShowNum(60+40+32,150,sht1x.Temperature%100,2,16);        //顯示小數部分
  75.         }
  76.
  77. //-------------------------濕度顯示-----------------------------------------------
  78.         LCD_ShowNum(60+40+8,170,sht1x.Humidity/100,2,16);        //顯示正數部分
  79.         if((sht1x.Humidity%100)>=0 && (sht1x.Humidity%100)<=9 )
  80.         {
  81.             LCD_ShowNum(60+40+32,170,sht1x.Humidity%100,1,16);        //顯示小數部分
  82.         }
  83.         else
  84.         {
  85.             LCD_ShowNum(60+40+32,170,sht1x.Humidity%100,2,16);        //顯示小數部分
  86.         }
  87. //--------------------------------------------------------------------------------
  88.         t++;
  89.         if(t==20)
  90.         {
  91.                 t=0;
  92.                         LED0=!LED0;
  93.         }
  94.         }
  95. }
復制代碼
下載:
STM32-SHT1X程序.zip (386.53 KB, 下載次數: 92)
成序
成序
ID:305939 發(fā)表于 2018-4-11 16:23 | 只看該作者
能仿真嗎
ID:624648 發(fā)表于 2021-5-1 18:42 | 只看該作者
能看下原理圖嗎
Powered by 單片機教程網
