查看: 7549|回復(fù): 5
BL5372-USB功能RTC時鐘程序源碼電路板原理圖和PCB工程文件
ID:300076 發(fā)表于 2018-3-31 20:07 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
BL5372-USB功能RTC時鐘電路板AD格式的電路原理圖和PCB工程:
Demo演示用的固件(程序),出貨前已經(jīng)燒錄好,給PCBA通電即可工作!
如果您需要再次燒錄,請按此HEX文件進(jìn)行燒錄即可。
燒錄工具一般用 ST-LINK/V2, 或者J-LINK都可以!
R8、R9兩者只能焊接一個
焊接R8則選擇IIC接口
焊接R9則選擇SPI接口
stm32程序源碼:
  1. /*
  2. 作者:紫電青霜
  3. */
  4. /*Includes ------------------------------------------------------------------*/
  5. #include "main.h"
  6. #include "stm32f0xx_hal.h"
  7. #include "usb_device.h"
  8. #include "BL5372_IIC.h"
  9. #include "usbd_cdc_if.h"
  10. uint8_t  RRTCiic_buf[16];
  11. uint8_t  RRTCiic_Buf_Out[26]={0x32,0x30,0x31,0x37,0xC4,0xEA,0x30,0x32,0xD4,0xC2,
  12.                              0x32,0x35,0xC8,0xD5,0x32,0x32,0x3A,0x35,0x36,0x3A,0x00,0x00,0x0D,0x0A,0x0D,0x0A};
  13.
  14. extern unsigned char Set_Year ;
  15. extern unsigned char Set_Month ;
  16. extern unsigned char Set_Day ;
  17. extern unsigned char Set_Hour ;
  18. extern unsigned char Set_Minute ;
  19. extern unsigned char Set_Second ;
  20.
  21. uint8_t   Rec_buff[18]={0};
  22. /* Private variables ---------------------------------------------------------*/
  23. SPI_HandleTypeDef hspi1;
  24. /* Private function prototypes -----------------------------------------------*/
  25. void SystemClock_Config(void);
  26. void Error_Handler(void);
  27. static void MX_GPIO_Init(void);
  28. static void MX_SPI1_Init(void);
  29. void My_GPIO_Init(void);
  30. unsigned char  DataStr[]=__DATE__;
  31. unsigned char  TimeStr[]=__TIME__;
  32. extern uint8_t UserRxBufferFS[];
  33. int main(void)
  34. {
  35.   unsigned char i=0;
  36.         unsigned char Miao_mark = 0;
  37.
  38.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  39.   HAL_Init();
  40.   /* Configure the system clock */
  41.   SystemClock_Config();
  42.   /* Initialize all configured peripherals */
  43.   MX_GPIO_Init();
  44.   MX_SPI1_Init();
  45.   MX_USB_DEVICE_Init();
  46.         IIC_Init();
  47.
  48.         My_GPIO_Init();
  49.         if(HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_7) == 0)//讀取PB7管腳的電平,為低電平,則初始化BL5372時間
  50.         {
  51.                 BL5372_init();
  52.         }
  53.   while (1)
  54.   {
  55.
  56.
  57.                         HAL_Delay(50);
  58.                         if(UserRxBufferFS[0] == 'S'  && UserRxBufferFS[1] == 'T'  && UserRxBufferFS[10] == 'F' && UserRxBufferFS[11] == 'N' )
  59.                         {
  60.                                 CDC_Transmit_FS("設(shè)置年月日\r\n",12);
  61.                                 Set_Year = ((UserRxBufferFS[4]-0x30)<<4)+(UserRxBufferFS[5]-0x30);
  62.                                 Set_Month = ((UserRxBufferFS[6]-0x30)<<4)+(UserRxBufferFS[7]-0x30);
  63.                                 Set_Day = ((UserRxBufferFS[8]-0x30)<<4)+(UserRxBufferFS[9]-0x30);
  64.                                 BL5372_init();
  65.                         }
  66.                         else if(UserRxBufferFS[0] == 'S'  && UserRxBufferFS[1] == 'T'  && UserRxBufferFS[8] == 'F' && UserRxBufferFS[9] == 'I' )
  67.                         {
  68.                                 CDC_Transmit_FS("設(shè)置時分秒\r\n",12);
  69.                                 Set_Hour = ((UserRxBufferFS[2]-0x30)<<4)+(UserRxBufferFS[3]-0x30);
  70.                                 Set_Minute = ((UserRxBufferFS[4]-0x30)<<4)+(UserRxBufferFS[5]-0x30);
  71.                                 Set_Second = ((UserRxBufferFS[6]-0x30)<<4)+(UserRxBufferFS[7]-0x30);
  72.                                 BL5372_init();
  73.                         }
  74.
  75.                                 for(i=0;i<18;i++)
  76.                                 {
  77.                                         UserRxBufferFS[i] = 0;
  78.                                 }
  79. //                                        HAL_Delay(5);
  80.                                         BL5372_Read(0x00,RRTCiic_buf,7);
  81.                                         if(RRTCiic_buf[0] != Miao_mark)
  82.                                         {
  83.        //秒
  84.        RRTCiic_Buf_Out[20] = ((RRTCiic_buf[0]>>4)&0x0f) +0x30;
  85.        RRTCiic_Buf_Out[21] = (RRTCiic_buf[0]&0x0f) +0x30;
  86.
  87.        //分
  88.        RRTCiic_Buf_Out[17] = ((RRTCiic_buf[1]>>4)&0x0f) +0x30;
  89.        RRTCiic_Buf_Out[18] = (RRTCiic_buf[1]&0x0f) +0x30;
  90.
  91.        //時
  92.        RRTCiic_Buf_Out[14] = ((RRTCiic_buf[2]>>4)&0x0f) +0x30;
  93.        RRTCiic_Buf_Out[15] = (RRTCiic_buf[2]&0x0f) +0x30;
  94.        //日
  95.        RRTCiic_Buf_Out[10] = ((RRTCiic_buf[4]>>4)&0x0f) +0x30;
  96.        RRTCiic_Buf_Out[11] = (RRTCiic_buf[4]&0x0f) +0x30;
  97.
  98.        //月
  99.        RRTCiic_Buf_Out[6] = ((RRTCiic_buf[5]>>4)&0x0f) +0x30;
  100.        RRTCiic_Buf_Out[7] = (RRTCiic_buf[5]&0x0f) +0x30;
  101.
  102.        //年
  103.        RRTCiic_Buf_Out[2] = ((RRTCiic_buf[6]>>4)&0x0f) +0x30;
  104.        RRTCiic_Buf_Out[3] = (RRTCiic_buf[6]&0x0f) +0x30;
  105.                                                         CDC_Transmit_FS((uint8_t *)RRTCiic_Buf_Out,26);
  106.
  107.                                         }
  108.                                         Miao_mark = RRTCiic_buf[0] ;
  109.                                         for(i=0;i<16;i++)
  110.                                         {
  111.                                                 RRTCiic_buf[i] = 0;
  112.                                         }
  113.   }
  114.   /* USER CODE END 3 */
  115. }
  116. /** System Clock Configuration
  117. */
  118. void SystemClock_Config(void)
  119. {
  120.   RCC_OscInitTypeDef RCC_OscInitStruct;
  121.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  122.   RCC_PeriphCLKInitTypeDef PeriphClkInit;
  123.     /**Initializes the CPU, AHB and APB busses clocks
  124.     */
  125.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48;
  126.   RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
  127.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  128.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  129.   {
  130.     Error_Handler();
  131.   }
  132.     /**Initializes the CPU, AHB and APB busses clocks
  133.     */
  134.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  135.                               |RCC_CLOCKTYPE_PCLK1;
  136.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI48;
  137.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  138.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  139.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
  140.   {
  141.     Error_Handler();
  142.   }
  143.   PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB;
  144.   PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_HSI48;
  145.   if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
  146.   {
  147.     Error_Handler();
  148.   }
  149.     /**Configure the Systick interrupt time
  150.     */
  151.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  152.     /**Configure the Systick
  153.     */
  154.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  155.   /* SysTick_IRQn interrupt configuration */
  156.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  157. }
  158. /* SPI1 init function */
  159. static void MX_SPI1_Init(void)
  160. {
  161.   hspi1.Instance = SPI1;
  162.   hspi1.Init.Mode = SPI_MODE_MASTER;
  163.   hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  164.   hspi1.Init.DataSize = SPI_DATASIZE_4BIT;
  165.   hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  166.   hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  167.   hspi1.Init.NSS = SPI_NSS_SOFT;
  168.   hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_4;
  169.   hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  170.   hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  171.   hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  172.   hspi1.Init.CRCPolynomial = 7;
  173.   hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
  174.   hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
  175.   if (HAL_SPI_Init(&hspi1) != HAL_OK)
  176.   {
  177.     Error_Handler();
  178.   }
  179. }
  180. /** Pinout Configuration
  181. */
  182. static void MX_GPIO_Init(void)
  183. {
  184.   /* GPIO Ports Clock Enable */
  185.   __HAL_RCC_GPIOA_CLK_ENABLE();
  186. }
  187. void My_GPIO_Init(void)
  188. {
  189.                 GPIO_InitTypeDef GPIO_InitStruct;
  190.          __HAL_RCC_GPIOB_CLK_ENABLE();
  191.
  192.           /*Configure GPIO pin : PB7 */
  193.   GPIO_InitStruct.Pin = GPIO_PIN_7 ;
  194.   GPIO_InitStruct.Mode = GPIO_MODE_INPUT;//輸入
  195.   GPIO_InitStruct.Pull = GPIO_PULLUP;//上拉輸入
  196.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  197.   HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  198.
  199.
  200. }
  201. /* USER CODE BEGIN 4 */
  202. /* USER CODE END 4 */
  203. /**
  204.   * @brief  This function is executed in case of error occurrence.
  205.   * @param  None
  206.   * @retval None
  207.   */
  208. void Error_Handler(void)
  209. {
  210.   /* USER CODE BEGIN Error_Handler */
  211.   /* User can add his own implementation to report the HAL error return state */
  212.   while(1)
  213.   {
  214.   }
  215.   /* USER CODE END Error_Handler */
  216. }
  217. #ifdef USE_FULL_ASSERT
  218. /**
  219.    * @brief Reports the name of the source file and the source line number
  220.    * where the assert_param error has occurred.
  221.    * @param file: pointer to the source file name
  222.    * @param line: assert_param error line source number
  223.    * @retval None
  224.    */
  225. void assert_failed(uint8_t* file, uint32_t line)
  226. {
  227.   /* USER CODE BEGIN 6 */
  228.   /* User can add his own implementation to report the file name and line number,
  229.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  230.   /* USER CODE END 6 */
  231. }
  232. #endif
  233. /**
  234.   * @}
  235.   */
  236. /**
  237.   * @}
  238. */
  239. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
下載:
BL5372-USB功能RTC時鐘電路板原理圖和PCB.zip (17.33 MB, 下載次數(shù): 60)
BL5372.pdf (144.14 KB, 下載次數(shù): 38)
RTC時鐘電路板程序源碼.zip (3.63 MB, 下載次數(shù): 90)
收藏收藏3 分享淘帖 頂 踩
ID:326234 發(fā)表于 2018-5-9 20:05 | 只看該作者
這個資源很好啊,準(zhǔn)備弄BL5372
ID:464148 發(fā)表于 2019-1-7 21:28 | 只看該作者
看下BL5372源碼
ID:714984 發(fā)表于 2020-3-24 18:34 | 只看該作者
很不錯的帖子,正好用到BL5372,這個帖子里的源碼可以參考一下。
ID:545576 發(fā)表于 2021-8-7 12:33 | 只看該作者
感謝分享,測試一下,替代缺貨的3231
ID:834913 發(fā)表于 2022-4-18 15:21 | 只看該作者
在使用BL5372的時候有遇到時鐘不準(zhǔn)的問題(大約四個小時走快一秒) 樓主有什么解決方法嗎
