查看: 1785|回復(fù): 0
18B20控溫
ID:26192 發(fā)表于 2018-4-1 00:51 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <REG51.H>
#include <intrins.h>
        uint num;
sbit lcd_rs=P3^5;
sbit lcd_rw=P3^6;
sbit lcd_en=P3^7; //液晶控制端
         uchar temp;
float result;
   sbit out=P3^4;
   sbit DS=P3^0;
uchar code name[]="WangYeSheng-VOLT";
void delay(unsigned int m)
//延時(shí)函數(shù)
while(m--);
void read1602()
//忙檢測(cè)
uchar i;
i=254;
P1=0xff;
lcd_rs=0;
lcd_rw=1;
lcd_en=1;
while((i--)&&(P2&0x80));//若一段時(shí)間以后仍低,不忙
lcd_en=0;
void write1602(uchar wdata,bit rw)//向LCD1602寫(xiě)數(shù)據(jù)(rw=1)或者命令(rw=0)
read1602();
P1=wdata;
lcd_rs=rw;
lcd_rw=0;
lcd_en=1;
delay(1);
lcd_en=0;
void lcd_init()
//LCD1602液晶的初始化
delay(1500);
write1602(0x38,0);
delay(500);
write1602(0x38,0);
delay(500);
write1602(0x38,0);
write1602(0x38,0);
write1602(0x0c,0);
write1602(0x06,0);
write1602(0x01,0);
//清屏
void lcd_printf(uchar *str)//顯示字符串
while(*str!='\0')
write1602(*str,1);
//寫(xiě)入數(shù)據(jù)
str++;
void lcd_moveto(uchar x,uchar y)//指定顯示的行列坐標(biāo)
if(x==0)
write1602(0x80|y,0);
if(x==1)
write1602(0xc0|y,0);
/*************DS18B20溫度讀取模塊*************/
void tmpDelay(int num)//延時(shí)函數(shù)
        while(num--) ;
void Init_DS18B20()//初始化ds1820
        unsigned char x=0;
        DS = 1;    //DS復(fù)位
        tmpDelay(8);  //稍做延時(shí)
        DS = 0;    //單片機(jī)將DS拉低
        tmpDelay(80); //精確延時(shí) 大于 480us
        DS = 1;    //拉高總線
        tmpDelay(14);
        x=DS;      //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
        tmpDelay(20);
unsigned char ReadOneChar()//讀一個(gè)字節(jié)
        unsigned char i=0;
        unsigned char dat = 0;
        for (i=8;i>0;i--)
                DS = 0; // 給脈沖信號(hào)
                dat>>=1;
                DS = 1; // 給脈沖信號(hào)
                if(DS)
                dat|=0x80;
                tmpDelay(4);
        return(dat);
void WriteOneChar(unsigned char dat)//寫(xiě)一個(gè)字節(jié)
        unsigned char i=0;
        for (i=8; i>0; i--)
                DS = 0;
                DS = dat&0x01;
                tmpDelay(5);
                DS = 1;
                dat>>=1;
unsigned int Readtemp()//讀取溫度
        unsigned char a=0;
        unsigned char b=0;
        unsigned int t=0;
        float tt=0;
        Init_DS18B20();
        WriteOneChar(0xCC); // 跳過(guò)讀序號(hào)列號(hào)的操作
        WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
        Init_DS18B20();
        WriteOneChar(0xCC); //跳過(guò)讀序號(hào)列號(hào)的操作
        WriteOneChar(0xBE); //讀取溫度寄存器
        a=ReadOneChar();   //連續(xù)讀兩個(gè)字節(jié)數(shù)據(jù)   //讀低8位
        b=ReadOneChar();                          //讀高8位
        t=b;
        t<<=8;
        t=t|a;                         //兩字節(jié)合成一個(gè)整型變量。
        tt=t*0.0625;          //得到真實(shí)十進(jìn)制溫度值,因?yàn)镈S18B20可以精確到0.0625度,所以讀回?cái)?shù)據(jù)的最低位代表的是0.0625度
        t= tt*10+0.5;         //放大十倍,這樣做的目的將小數(shù)點(diǎn)后第一位也轉(zhuǎn)換為可顯示數(shù)字,同時(shí)進(jìn)行一個(gè)四舍五入操作。
        return(t);
void display1()
                  //定義的時(shí)候用uchar宏定義就會(huì)出錯(cuò)
        uint shi,ge,xiaoshu;            //這里的num,shi,ge,xiaoshu 必須用uint無(wú)符號(hào)整數(shù)來(lái)表示,用uchar字符型則顯示錯(cuò)誤
        num=Readtemp();
        shi=num/100;
        ge=num/10%10;
        xiaoshu=num%10;
  lcd_moveto(1,4);
    temp=(uchar)(shi);//取得電壓值的整數(shù)部分
write1602(temp+48,1);//顯示電壓值的整數(shù)部分
   temp=(uchar)(ge);//取得電壓值的整數(shù)部分
write1602('.',1);//顯示小數(shù)點(diǎn)
   temp=(uchar)(xiaoshu);//取得電壓值的整數(shù)部分
void main()//測(cè)試用MAIN函數(shù)
lcd_init();
delay(50000);
   display1();
   if(num<500){out=1;}
   else if          (num>500){out=0;}
