查看: 7947|回復(fù): 11
stm32單片機(jī)OLED四行多級(jí)菜單顯示源碼
ID:259453 發(fā)表于 2018-4-2 14:53 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
stm33f103c8t6 OLED菜單例程分享給大家
  1. /***
  2.   *****************************************************************************
  3.   * @file                menu.c
  4.   * @author                原作:張子墨
  5.   * @version        V1.0
  6.   * @brief                 OLED四行多級(jí)菜單
  7.   *****************************************************************************
  8. ***/
  9. #include "menu.h"
  10. #include "oled.h"
  11. #include "key.h"
  12. #include "delay.h"
  13. #include "text.h"
  14. #include "fontupd.h"
  15. /*菜單結(jié)構(gòu)定義*/
  16. struct Option
  17. {
  18.     unsigned char KeyLevel;       //菜單選項(xiàng)所屬菜單表號(hào)
  19.     unsigned char EnterIndex;     //選項(xiàng)進(jìn)入索引號(hào)
  20.     unsigned char CancelIndex;    //選項(xiàng)退出索引號(hào)
  21.     unsigned char *KeyWord;       //菜單選項(xiàng)文字描述指針
  22.     unsigned char WordMete;       //菜單選項(xiàng)描述文字字節(jié)數(shù)
  23. };
  24. /**
  25. *        具體菜單選項(xiàng)定義,定義一個(gè)結(jié)構(gòu)數(shù)組
  26. *        存儲(chǔ)在編碼區(qū),節(jié)省內(nèi)存RAM
  27. **/
  28. struct Option sOption[OPTIONMETE] =
  29. {
  30. /*菜單表號(hào) 進(jìn)入索引 退出索引 菜單選項(xiàng)文字 菜單選項(xiàng)文字字節(jié)數(shù)*/
  31.         {0, OPTIONMETE - 1, 0, "1.亮度調(diào)節(jié)",   10},//0
  32.         {0, 6,                                 1, "2.時(shí)間設(shè)置",   10},//1
  33.         {0, OPTIONMETE - 1, 2, "3.系統(tǒng)檢測",   10},//2
  34.         {0, OPTIONMETE - 1, 3, "4.修改密碼",   10},//3
  35.         {0, OPTIONMETE - 1, 4, "5.幫助說明",   10},//4
  36.         {0, OPTIONMETE - 1, 5, "6.系統(tǒng)信息",   12},//5
  37.         {1, OPTIONMETE - 1, 1, "1.時(shí)鐘設(shè)置",   10},//6
  38.         {1, OPTIONMETE - 1, 1, "2.日期設(shè)置",   10},//7
  39. };
  40. /*菜單表分類數(shù)組*/
  41. unsigned char Level[MENULEVEL][3] =
  42. {
  43. /*每層表單對(duì)應(yīng)的開始索引  結(jié)束索引  選項(xiàng)數(shù)目*/
  44.     {0, 5, 6},
  45.     {6, 7, 2},
  46. };
  47. /*菜單索引定義*/
  48. unsigned char FirstLineDisIndex = 0;    //屏幕第一行顯示的索引號(hào)
  49. unsigned char SelectLine_L = 1;                    //原來選中行
  50. unsigned char SelectLine = 1;                      //當(dāng)前選擇的行
  51. unsigned char SelectIndex = 0;                     //當(dāng)前選定行對(duì)應(yīng)的索引號(hào)
  52. unsigned char LastIndex = 0;                      //進(jìn)入功能函數(shù)前的索引號(hào),判斷具體功能使用
  53. /**
  54.   * @name        void Select_Line(unsigned char line, unsigned char clear)
  55.   * @brief  選中行反白顯示
  56.   * @param        line:選中行                clear:1,選中行清除反白 0,選中行反白顯示
  57.   * @retval        none
  58.   */
  59. void Select_Line(unsigned char line, unsigned char clear)
  60. {
  61.         switch (line)        //選擇行
  62.         {
  63.                 case 1:
  64.                         OLED_Fill(0, 0, 127, 15, 0);        //清除原來的顯示
  65.                         Show_Str(0, 0, sOption[FirstLineDisIndex].WordMete*8, 16, \
  66.                                 sOption[FirstLineDisIndex].KeyWord, 16, clear);
  67.                         break;
  68.                 case 2:
  69.                         OLED_Fill(0, 16, 127, 31, 0);        //清除原來的顯示
  70.                         Show_Str(0, 16, sOption[FirstLineDisIndex+1].WordMete*8, 16, \
  71.                                 sOption[FirstLineDisIndex+1].KeyWord, 16, clear);
  72.                         break;
  73.                 case 3:
  74.                         OLED_Fill(0, 32, 127, 47, 0);        //清除原來的顯示
  75.                         Show_Str(0, 32, sOption[FirstLineDisIndex+2].WordMete*8, 16, \
  76.                                 sOption[FirstLineDisIndex+2].KeyWord, 16, clear);
  77.                         break;
  78.                 case 4:
  79.                         OLED_Fill(0, 48, 127, 63, 0);        //清除原來的顯示
  80.                         Show_Str(0, 48, sOption[FirstLineDisIndex+3].WordMete*8, 16, \
  81.                                 sOption[FirstLineDisIndex+3].KeyWord, 16, clear);
  82.                         break;
  83.                 default :
  84.                         break;
  85.         }
  86.         delay_ms(10);
  87. }
  88. /**
  89.   * @name        void Display_OLEDMenu (void)
  90.   * @brief  刷新菜單功能函數(shù)
  91.   * @param        none
  92.   * @retval        none
  93.   */
  94. void Display_OLEDMenu (void)
  95. {
  96.     unsigned char LineMete =  Level[sOption[SelectIndex].KeyLevel][2]; //循環(huán)量,顯示行數(shù)
  97.         OLED_Fill(0, 0, 128, 64, 0);        //清屏,否則會(huì)出現(xiàn)一些亂碼
  98.         delay_ms(10);
  99.     do                  //分別顯示各行菜單項(xiàng)
  100.     {
  101.                 OLED_Fill(0, 0, 127, 15, 0);
  102.                 Show_Str(0, 0, sOption[FirstLineDisIndex].WordMete*8, 16, \
  103.                                 sOption[FirstLineDisIndex].KeyWord, 16, 1);
  104.         if(--LineMete == 0) break;
  105.                 OLED_Fill(0, 16, 127, 31, 0);
  106.                 Show_Str(0, 16, sOption[FirstLineDisIndex+1].WordMete*8, 16, \
  107.                                 sOption[FirstLineDisIndex+1].KeyWord, 16, 1);
  108.         if(--LineMete == 0) break;
  109.                 OLED_Fill(0, 32, 127, 47, 0);
  110.                 Show_Str(0, 32, sOption[FirstLineDisIndex+2].WordMete*8, 16, \
  111.                                 sOption[FirstLineDisIndex+2].KeyWord, 16, 1);
  112.         if(--LineMete == 0) break;
  113.                 OLED_Fill(0, 48, 127, 63, 0);
  114.                 Show_Str(0, 48, sOption[FirstLineDisIndex+3].WordMete*8, 16, \
  115.                                 sOption[FirstLineDisIndex+3].KeyWord, 16, 1);
  116.     }
  117.     while(0);
  118.         Select_Line(SelectLine_L, 1);        //消除上一行反白
  119.         Select_Line(SelectLine, 0);        //填充所需反白
  120. }
  121. /**
  122.   * @name        bool MenuLevelStart (void)
  123.   * @brief  判斷當(dāng)前索引是否是表單第一項(xiàng)功能函數(shù)
  124.   * @param        none
  125.   * @retval        返回Bit標(biāo)志,是第一項(xiàng)返回TURE,不是返回FALSE
  126.   */
  127. bool MenuLevelStart (void)
  128. {
  129.     unsigned char i = MENULEVEL;
  130.     do
  131.     {
  132.         i--;
  133.         if(SelectIndex == Level[i][0])
  134.             return TURE;
  135.     }
  136.     while(i);
  137.     return FALSE;
  138. }
  139. /**
  140.   * @name        bool MenuLevelEnd (void)
  141.   * @brief  判斷當(dāng)前索引是否是表單最后一項(xiàng)功能函數(shù)
  142.   * @param        none
  143.   * @retval        返回Bit標(biāo)志,是最后一項(xiàng)返回TURE,不是返回FALSE
  144.   */
  145. bool MenuLevelEnd (void)
  146. {
  147.     unsigned char i = MENULEVEL;
  148.     do
  149.     {
  150.         i--;
  151.         if(SelectIndex == Level[i][1])
  152.             return TURE;
  153.     }
  154.     while(i);
  155.     return FALSE;
  156. }
  157. /**
  158.   * @name        void MenuUpOneOption (void)
  159.   * @brief  菜單上移一項(xiàng)函數(shù)
  160.   * @param        none
  161.   * @retval        none
  162.   */
  163. void MenuUpOneOption (void)
  164. {
  165.     if(MenuLevelStart ())         //如果當(dāng)前為表單第一項(xiàng)
  166.     {
  167.         if(Level[sOption[SelectIndex].KeyLevel][2] >= 4) //并且表單中選項(xiàng)數(shù)目大于等于4個(gè)
  168.         {
  169.             FirstLineDisIndex = Level[sOption[SelectIndex].KeyLevel][1] - 3; //第一行顯示索引號(hào)為倒數(shù)第四項(xiàng)
  170.             SelectIndex = Level[sOption[SelectIndex].KeyLevel][1];   //選擇索引為表單最后一項(xiàng)
  171.             SelectLine_L = SelectLine;        //記錄原來行
  172.                         SelectLine = 4;             //標(biāo)記選擇行為第四行
  173.         }
  174.         else            //如果選項(xiàng)數(shù)目并不大于四個(gè)
  175.         {
  176.             SelectIndex = Level[sOption[SelectIndex].KeyLevel][1];   //選擇索引為當(dāng)前表單最后一個(gè)
  177.             SelectLine_L = SelectLine;        //記錄原來行
  178.                         SelectLine = Level[sOption[SelectIndex].KeyLevel][2];   //顯示行表單數(shù)目(最后一個(gè))
  179.         }
  180.     }
  181.     else        //如果當(dāng)前不是開始索引
  182.     {
  183.         if(SelectLine == 1)  //并且已經(jīng)在屏幕最上邊一行
  184.         {
  185.             FirstLineDisIndex--;  //顯示索引上移
  186.             SelectIndex--;    //選擇索引自減
  187.                         SelectLine_L = SelectLine;        //記錄原來行
  188.             SelectLine = 1;    //選擇行還是第一行
  189.         }
  190.         else       //如果不是第一行
  191.         {
  192.                         SelectLine_L = SelectLine;        //記錄原來行
  193.             SelectLine--;    //選擇行自減
  194.             SelectIndex--;    //選擇索引自減
  195.         }
  196.     }
  197.         Display_OLEDMenu();    //刷新屏幕顯示
  198. }
  199. /**
  200.   * @name        void MenuDownOneOption (void)
  201.   * @brief  菜單下移一項(xiàng)函數(shù)
  202.   * @param        none
  203.   * @retval        none
  204.   */
  205. void MenuDownOneOption (void)
  206. {
  207.     if(MenuLevelEnd ())        //如果當(dāng)前是表單最后一個(gè)索引
  208.     {
  209.         FirstLineDisIndex = Level[sOption[SelectIndex].KeyLevel][0]; //第一行顯示索引為表單第一個(gè)選項(xiàng)
  210.         SelectIndex = Level[sOption[SelectIndex].KeyLevel][0];   //選擇索引為表單第一個(gè)選項(xiàng)索引
  211.         SelectLine_L = SelectLine;        //記錄原來行
  212.                 SelectLine = 1;             //選擇行為第一行
  213.     }
  214.     else           //如果不是最后的索引
  215.     {
  216.         if(SelectLine != 4)     //如果當(dāng)前不是屏幕最底行
  217.         {
  218.                         SelectIndex++;       //選擇索引自加
  219.             SelectLine_L = SelectLine;        //記錄原來行
  220.                         SelectLine++;       //選擇行下移
  221.         }
  222.         else          //如果是屏幕最低行
  223.         {
  224.             FirstLineDisIndex++;     //第一行顯示下移
  225.             SelectIndex++;       //選擇索引自加
  226.         }
  227.     }
  228.         Display_OLEDMenu();    //刷新屏幕顯示
  229. }
  230. /**
  231.   * @name        void MenuEnterOption (void)
  232.   * @brief  進(jìn)入某項(xiàng)功能函數(shù)
  233.   * @param        none
  234.   * @retval        none
  235.   */
  236. void MenuEnterOption (void)
  237. {
  238.     LastIndex = SelectIndex;           //標(biāo)記進(jìn)入前的索引號(hào)(以便判斷具體功能)
  239.     SelectIndex = sOption[SelectIndex].EnterIndex;      //更新選擇索引為之前索引號(hào)對(duì)應(yīng)進(jìn)入索引
  240.     if(SelectIndex != OPTIONMETE - 1)        //如果當(dāng)前索引不是功能選擇索引
  241.     {
  242.         FirstLineDisIndex = Level[sOption[SelectIndex].KeyLevel][0]; //第一行顯示為進(jìn)入表單第一項(xiàng)
  243.         SelectLine_L = SelectLine;
  244.                 SelectLine = 1;             //設(shè)定第一行為選擇行
  245.         Display_OLEDMenu ();                    //刷新菜單
  246.     }
  247.     else
  248.         {
  249.         FunctionAction ();           //如果是功能選擇項(xiàng),進(jìn)入功能分支判斷函數(shù)
  250.         }
  251. }
  252. /**
  253.   * @name        void MenuCancelOption (void)
  254.   * @brief  菜單退出功能函數(shù)
  255.   * @param        none
  256.   * @retval        none
  257.   */
  258. void MenuCancelOption (void)
  259. {
  260.     if(SelectIndex != OPTIONMETE - 1)        //如果不是從功能返回
  261.         {
  262.         SelectIndex = sOption[SelectIndex].CancelIndex;     //選擇索引為選項(xiàng)返回索引
  263.         }
  264.     else                //如果是從功能返回
  265.         {
  266.         SelectIndex = LastIndex;          //索引等于進(jìn)入前保存索引
  267.         }
  268.     if(Level[sOption[SelectIndex].KeyLevel][2] >= 4)    //如果返回表單選項(xiàng)數(shù)目大于4個(gè)
  269.     {
  270.         if(SelectIndex > Level[sOption[SelectIndex].KeyLevel][1] - 3) //根據(jù)返回選項(xiàng)確定顯示首項(xiàng)
  271.         {
  272.             FirstLineDisIndex = Level[sOption[SelectIndex].KeyLevel][1] - 3;
  273.             SelectLine_L = SelectLine;
  274.                         SelectLine =  4 - (Level[sOption[SelectIndex].KeyLevel][1] - SelectIndex);
  275.         }
  276.         else               //一般顯示方式
  277.         {
  278.             FirstLineDisIndex = SelectIndex;       //第一行顯示索引
  279.                         SelectLine_L = SelectLine;
  280.             SelectLine = 1;            //選擇第一行
  281.         }
  282.     }
  283.     else                //如果返回表單選項(xiàng)數(shù)目不足4個(gè)
  284.     {
  285.         FirstLineDisIndex = Level[sOption[SelectIndex].KeyLevel][0];   //第一行顯示索引為表單第一項(xiàng)
  286.         SelectLine_L = SelectLine;
  287.                 SelectLine = SelectIndex -  Level[sOption[SelectIndex].KeyLevel][0] + 1; //選擇行標(biāo)志為當(dāng)前選擇索引對(duì)應(yīng)行
  288.     }
  289.         Display_OLEDMenu ();               //刷新菜單
  290. }
  291. /**
  292.   * @name        void ShutDown (void)
  293.   * @brief  某一項(xiàng)功能函數(shù)     實(shí)際應(yīng)該改為實(shí)際功能函數(shù)
  294.   * @param        none
  295.   * @retval        none
  296.   */
  297. void SystemState (void)
  298. {
  299.         OLED_Clear();        //清屏
  300.         delay_ms(1);
  301.         Show_Str(16, 29, 128, 16, "系統(tǒng)版本V1.0", 16, 1);
  302. }
  303. void System_Help (void)
  304. {
  305.         OLED_Clear();        //清屏
  306.         delay_ms(1);
  307.         Show_Str(0, 0,  128, 16, "1.上下鍵選擇", 16, 1);
  308.         Show_Str(0, 16, 128, 16, "2.左鍵確定", 16, 1);
  309.         Show_Str(0, 32, 128, 16, "3.右鍵退出", 16, 1);
  310. }
  311. void SystemTest (void)
  312. {
  313.         OLED_Clear();        //清屏
  314.         delay_ms(1);
  315.         if (font_init())
  316.         {
  317.                 OLED_Fill(0, 16, 128, 31, 0);
  318.                 Show_Str(32, 16, 128, 16, "字庫錯(cuò)誤", 16, 1);
  319.         }
  320.         else
  321.         {
  322.                 OLED_Fill(0, 16, 128, 31, 0);
  323.                 Show_Str(32, 16, 128, 16, "字庫正常", 16, 1);
  324.         }
  325. }
  326. u16 radio = 0x7F;
  327. void OLED_Light (void)
  328. {
  329.         u8 flag = 1;
  330.         OLED_Clear();        //清屏
  331.         delay_ms(1);
  332.         Show_Str(32, 0, 128, 16, "亮度調(diào)節(jié)", 16, 1);
  333.         OLED_DrawRectangle(0, 16, 93, 31, 1);        //畫進(jìn)度條的邊框
  334.         while (1)
  335.         {
  336.                 /*限制進(jìn)度條的范圍*/
  337.                 if (radio <= 2)
  338.                 {
  339.                         radio = 2;
  340.                 }
  341.                 else if (radio >= 255)
  342.                 {
  343.                         radio = 255;
  344.                 }
  345.                 OLED_Write_Com(0x81); //對(duì)比度設(shè)置
  346.                 OLED_Write_Com(radio); //1~255;默認(rèn)0X7F (亮度設(shè)置,越大越亮)
  347.                 if (flag == 1)
  348.                 {
  349.                         flag = 0;
  350.                         OLED_Fill(1+(92 * radio / 255), 17, 93, 31, 0);        //消除進(jìn)度條的多余部分
  351.                         OLED_Fill(1, 17, 1+(92 * radio / 255), 31, 1);        //填充進(jìn)度條
  352.                         OLED_ShowNum(94, 16, (100 * radio / 255), 3, 16, 1);        //顯示進(jìn)度百分比
  353.                         OLED_ShowChar(120, 16, '%', 16, 1);
  354.                 }
  355.                 delay_ms(10);
  356.                 switch (KEY_Scan(1))        //按鍵掃描
  357.                 {
  358.                         case KEY_UP :        //按上鍵增加亮度
  359.                                 flag = 1;
  360.                                 radio += 2;
  361.                                 break;
  362.                         case KEY_DOWN :        //按下鍵減小亮度
  363.                                 flag = 1;
  364.                                 radio -= 2;
  365.                                 break;
  366.                         case KEY_RIGHT :        //按右鍵退出
  367.                                 MenuCancelOption();
  368.                                 return;
  369.                         default :
  370.                                 break;
  371.                 }
  372.         }
  373. }
  374. void NoThisFunction (void)
  375. {
  376.     unsigned char Font[] = {"沒有這個(gè)功能"};
  377.         OLED_Clear();        //清屏
  378.         delay_ms(1);
  379.         Show_Str(16, 16, 128, 16, Font, 16, 1);
  380.         delay_ms(500);
  381.     MenuCancelOption();
  382. }
  383. /**
  384.   * @name        void FunctionAction (void)
  385.   * @brief  具體功能散轉(zhuǎn)函數(shù)
  386.   * @param        none
  387.   * @retval        none
  388.   */
  389. void FunctionAction (void)
  390. {
  391.     switch (LastIndex)            //根據(jù)進(jìn)入前的索引判斷具體函數(shù)
  392.     {
  393.                 case 0:
  394.                         OLED_Light();
  395.                         break;
  396. //                case 1:
  397. //                        break;
  398. //                case 2:
  399. //                        break;
  400.                 case 2:
  401.                         SystemTest();
  402.                         break;
  403. //                case 4:
  404. //                        break;
  405.                 case 4:
  406.                         System_Help();
  407.                         break;
  408.                 case 5:
  409.                         SystemState();
  410.                         break;
  411.                 default:
  412.                         NoThisFunction();
  413.                         break;      //如果沒有具體操作,顯示沒有這個(gè)功能
  414.     }
  415. }
  416. /**
  417.   * @name        void KeyCodeAction (unsigned char KeyCode)
  418.   * @brief  菜單操作按鍵處理散轉(zhuǎn)函數(shù)
  419.   * @param        KeyCode:按鍵值   實(shí)際使用應(yīng)根據(jù)自己的按鍵重新編寫case項(xiàng)
  420.   * @retval        none
  421.   */
  422. void KeyCodeAction (unsigned char KeyCode)
  423. {
  424.     switch (KeyCode)
  425.     {
  426.                 case KEY_UP:
  427.                         MenuUpOneOption();
  428.                         break;   //如果是向上按鍵,則菜單向上,以下類似
  429.                 case KEY_DOWN:
  430.                         MenuDownOneOption();
  431.                         break;
  432.                 case KEY_LEFT:
  433.                         MenuEnterOption();
  434.                         break;
  435.                 case KEY_RIGHT:
  436.                         MenuCancelOption();
  437.                         break;
  438.                 default:
  439.                         break;
  440.     }
  441. }
  442. /**
  443.   * @name        void MenuReflash (void)
  444.   * @brief  菜單更新函數(shù)
  445.   * @param        none
  446.   * @retval        none
  447.   */
  448. void MenuReflash (void)
  449. {
  450.     unsigned char Keytemp;       //保存按鍵編碼變量
  451.     Keytemp = KEY_Scan(0);       //保存按鍵編碼
  452.     if(Keytemp)          //如果按鍵編碼有效
  453.     {
  454.         KeyCodeAction (Keytemp);     //根據(jù)按鍵說明字母散轉(zhuǎn)
  455.     }
  456. }
這個(gè)工程只能用Keil4來編譯,如果用Keil5的話 會(huì)失敗:
OLED菜單程序.rar (1.09 MB, 下載次數(shù): 261)
收藏收藏10 分享淘帖 頂2 踩
ID:302293 發(fā)表于 2024-3-1 10:09 | 只看該作者
有stm32103的源碼嗎?
ID:82944 發(fā)表于 2022-7-20 20:16 | 只看該作者
感謝樓主,正愁控制不知道怎么去做
ID:828786 發(fā)表于 2021-1-6 10:01 | 只看該作者
蓬萊羽客 發(fā)表于 2020-12-23 10:24
F407的能不能移植到103上面用
肯定可以,只需要修改底層配置
ID:850319 發(fā)表于 2020-12-23 10:24 | 只看該作者
F407的能不能移植到103上面用
ID:367149 發(fā)表于 2020-3-18 09:50 | 只看該作者
好資料
ID:502526 發(fā)表于 2020-3-3 22:58 | 只看該作者
F407的代碼
ID:239855 發(fā)表于 2020-2-20 20:20 | 只看該作者
正在用于做項(xiàng)目的菜單,看著不錯(cuò),參考參考
ID:239855 發(fā)表于 2020-2-8 15:24 | 只看該作者
作為學(xué)習(xí)參考參考,謝謝
ID:270390 發(fā)表于 2020-2-7 21:26 | 只看該作者
非常好的資料
ID:96552 發(fā)表于 2019-10-4 10:14 | 只看該作者
好資料
ID:606020 發(fā)表于 2019-9-1 11:36 | 只看該作者
值得學(xué)習(xí)
