查看: 4515|回復(fù): 1
求助max7219點(diǎn)陣顯示問題
ID:299298 發(fā)表于 2018-4-2 15:47 | 顯示全部樓層 |閱讀模式
本人是單片機(jī)小白,在學(xué)習(xí)驅(qū)動(dòng)max7219做個(gè)小時(shí)鐘;請(qǐng)教下面圖片中一個(gè)字符拆分開,在兩塊點(diǎn)陣屏上顯示怎么做的,目前只會(huì)一個(gè)屏顯示一個(gè)字符;
另外,中間那個(gè)冒號(hào)怎么顯示?
這是網(wǎng)上找來的7219驅(qū)動(dòng)程序,要怎么修改才能實(shí)現(xiàn)自己的需求
#include <reg52.h>
#include <intrins.h>
#define uint  unsigned int
//定義Max7219端口
sbit Max7219_pinCLK = P2^2;
sbit Max7219_pinCS  = P2^1;
sbit Max7219_pinDIN = P2^0;
uchar code disp1[3][8]={
{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E}, //2
{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},    //3
{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},   //4
/*n毫秒的延時(shí)程序*/
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
//向MAX7219(U3)寫入字節(jié)
void Write_Max7219_byte(uchar DATA)
        uchar i;
        Max7219_pinCS=0;                //CS=0有效,CS=1鎖存
        for(i=8;i>=1;i--)
            Max7219_pinCLK=0;
            Max7219_pinDIN=DATA&0x80; //&10000000, 編譯器對(duì)位操作的理解:非0即為1
            DATA=DATA<<1;
            Max7219_pinCLK=1;       //上升沿把數(shù)據(jù)送出去
/*向M第一片MAX7219寫入數(shù)據(jù)*/
void Write_Max7219_1(uchar add1,uchar dat1)
     Max7219_pinCS=0;
     Write_Max7219_byte(add1);           //寫入地址,即數(shù)碼管編號(hào)
     Write_Max7219_byte(dat1);               //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
     Max7219_pinCS=1;
/*第二片MAX7219的寫入數(shù)據(jù)*/
void Write_Max7219_2(uchar add2,uchar dat2)
    Max7219_pinCS=0;
    Write_Max7219_byte(add2);
    Write_Max7219_byte(dat2);
    Max7219_pinCLK=1;
    Write_Max7219_byte(0x00);  //片1寫入空
    Max7219_pinCS=1;
/*第三片MAX7219的寫入數(shù)據(jù)*/
void Write_Max7219_3(uchar add3,uchar dat3)
    Max7219_pinCS=0;
    Write_Max7219_byte(add3);
    Write_Max7219_byte(dat3);
    Max7219_pinCLK=1;
    Write_Max7219_byte(0x00); //片2寫入空
    Max7219_pinCS=1;
/*初始化芯片*/
void Init_MAX7219(void)
Write_Max7219_1(0x09, 0x00);       //譯碼方式:BCD碼
Write_Max7219_1(0x0a, 0x03);       //亮度
Write_Max7219_1(0x0b, 0x07);       //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219_1(0x0c, 0x01);       //掉電模式:0,普通模式:1
Write_Max7219_1(0x0f, 0x00);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
Write_Max7219_2(0x09, 0x00);       //譯碼方式:BCD碼
Write_Max7219_2(0x0a, 0x03);       //亮度
Write_Max7219_2(0x0b, 0x07);       //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219_2(0x0c, 0x01);       //掉電模式:0,普通模式:1
Write_Max7219_2(0x0f, 0x00);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
Write_Max7219_3(0x09, 0x00);       //譯碼方式:BCD碼
Write_Max7219_3(0x0a, 0x03);       //亮度
Write_Max7219_3(0x0b, 0x07);       //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219_3(0x0c, 0x01);       //掉電模式:0,普通模式:1
Write_Max7219_3(0x0f, 0x00);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
/**********************主程序**************************/
void main(void)
uchar i,j;
Delay_xms(50);
Init_MAX7219();
  for(j=0;j<3;j++)
   for(i=1;i<9;i++)
    Write_Max7219_1(i,disp1[2][i-1]);
    Write_Max7219_2(i,disp1[3][i-1]);
    Write_Max7219_3(i,disp1[4][i-1]);
   Delay_xms(1000);
ID:123289 發(fā)表于 2018-4-3 00:52 | 顯示全部樓層
你要現(xiàn)進(jìn)行字符拆裝分解組合,考的是你對(duì)掃描顯示、以及對(duì)點(diǎn)陣真正理解。
